View Full Version : Acura Integra
- Special Edition ----LS
- i want to make this trade/swap am i getting a good deal???
- Cam Cover Studs
- The Benen rear lower tie bar is.....
- how much gas
- question about skunk2 intake manifold
- Pic request
- Will these center caps fit?
- Question about Apex'i filter with stock or aem short ram piping?
- O2 sensor Wires
- rear suspension
- Poll: Window Switches and Window Motor.
- CEL code? i dont understand
- just bought my GSR, got question
- Who's taking there 4door gsr to MIR this sunday?If its not raining
- squishy brakes
- Gained oil?
- ***Warning about company,everyone please read***
- itr lsd
- my lovely wife
- Integra lights?
- How do I install a momo steering wheel in my db8?
- For those very skilled honda fanatics... question
- question about seat harness and no roll bar/cage.
- Clutch & Shift probs
- Is the 00-01 GSR stock header the same as USDM ITR header in outlet size?
- aem big brake kit for the front please look
- Blown headgasket
- Tools for valve adjustment
- header on rs
- gs-r cat back on ls
- boosted ls
- Oil Cooler 4 my car?
- Quiet mufflers....
- GSR Center cap removal
- 16inche black or gunmetal rims for a gsr
- B18a/b with a b16a crank?
- What does the flywheel bolt to?
- do 4dr mirrors fit 2dr teg?
- Why cant i post anywhere?
- Monaco seat Pics
- exhaust bends
- what sould be done with timing belt change other than WP??
- Who knows where i can find this video????
- How do you install the typ r style strut bar?
- Clutch Problems
- gas for b18b1 motors
- will this fit in my civic?
- resonators
- new to integra land!!!
- side skirts fitment
- Are all honda fuel pumps universal?
- ABS Code: 6-4
- new here
- Has anyone converted their 421 header over to a 2.5 collector?
- Please help with shock decision
- How many 1993 GSR's produced for USDM?
- gear ratios
- Question?
- honda-tecg forums problems / conflicts
- GS-R Break System
- ITR Suspension setup + camber issues
- confused about where springs go.
- My car thinks I can't drive...
- 3 integras... empty parking structure... couple pics...
- DC Cluster Swap Finally Finished, Put Into DA Integ 92
- Bad idea:drive through car wash w/antenna up
- clutch feels funny and making wierd noise! help.
- please help w/ theft deterrent!
- pressure cleaning under the hood
- Steering wheel
- Removing lower ground effect on 2001 teg
- My cars still whining while it idles and it just had all belts changed and a 60k service
- Do CTR rear trailing arms fit DC/DA?
- 3 seconds you crash your car; part 2. Knife in guts out ;)
- Can someone please tell me what ecu this is???
- Headwork and Smog, will it work?
- where can i get a good paint job in MI??? (didnt know where i should post this)
- Cluster Question (already searched but didnt find the right answer)
- What are these cel codes?
- SS lines are the bomb!!!!
- B20Z head on B18A
- JDM non-SRS DC2 steering wheel in my DA
- Anyone know how to get in touch with Brian Wong (b18c1_powered_si)
- automatic seatbelt stopped working
- Thieves...............
- Headliner questions
- The guy that I let barrow my stock GSR intake...
- adjustable shock users...
- Flywheel weight?
- GC installation help!
- External Oil Pumps "Please Help"
- Complete ls/vtec engine swap!!!!
- GSR and Comptech wing
- Quick Spoon rear strut bar Q
- Pep Boys Lifetime Warranty Axles...?
- Sorry for the xpost....
- need a supension set up
- Who has water temperature in their GSR?
- GSR makes a new sweet noise
- 4 Sale: Brand new koni Yellows for DA intgeras
- Tried to get syncro fixed under warranty
- obd2 to obd1 ???
- o2 simulator in cali
- New brakes....are they faded? Did i mess them up?
- Autopower 6 point bolt in cage
- Apex N1 from EG
- ITR oil cooler
- Those Who Have Gone Wingless!! Question?!
- where can I download 95 ls engine assembly information
- Nasty Grinding noise, even when my car isn't in gear, any ideas???
- turbo teg.
- heater/ac control panel lights - what kind of bulb?
- Please help, suspension question!!!
- a more specific question similar to a thread on here already....
- 87 Octane in my GSR
- b18c head for integra SE..?
- jdm itr steering wheel made by momo for a dollar?
- please help me identify which hose i need from this diagram.
- Bay Area Dyno Day...June 14th
- 3 Bolts that hold the top power steering pully
- Lighted switch to control the G3 Integra power antenna. Good MOD!
- JDM right hand drive Teg
- Need two cigarette lighters.
- How hard is it to remove stock radiator and install new radiator in Integra?
- b18c1 engine demand charts?
- jdm ctr or itr tranny?
- exhaust/smog question
- please help quick, my AEM rubbed a hole in my AC line!
- ECU problem!
- New tires?
- clutch & flywheel
- newbie suspension help!!!
- Switched out ECU...but I have a VAFC...What do I do?
- Fuel pressure??
- Acura Part Number Lookup
- Where is the firewall????
- Few questions of dynoing..
- integra antenna plug / cover ??
- b16a vs b18c1 tranny
- Things I've learned today.
- Good Deal ? Bad DEAL?
- advise on taking off the rear hatch???
- •USDM and JDM headlight ?'s•
- clamps to elminate sway bar from sliding?
- Anyone with a bottle fed B18A?
- ABS problem?
- this integra is crazy look at the mods!
- Exhaust for my 98 GSR?
- Small Grind
- flywheels
- Question
- Turbo or Ls/vtec?
- quick question about finding amber film
- Axles
- Is it safe to turbo my LS w/ a JDM ITR tranny??????
- interior roof removal
- LS/Vtec setup
- b series vtec wiring into 91 integra
- 88 Integra question
- Where can I buy some nice 97' front bumper amber lights?
- Spoiler Fit?
- Curiousity Question on head gaskets
- has any1 modified there dc door panels?
- Carbon fiber hatchback shelf/lid?
- compression ratio question
- Where can i get gsr tranny?
- Anyone else notice grinding when shifting fast, after skunk2 shifter install
- Just did a compression test
- alarm install
- $750....but for what?
- Overheating problems, need help.
- quick question: rear brake calipers????
- Anyone with RSR Catback Exhaust in a Integra?
- itr sway
- Looking for apexi...
- Check out what the Skunk Clause left on my workbench!
- JDM 4-1 + h&r/neuspeed race springs? in here!
- will my tires fit???
- Optimal Oil Viscosity for my GS?
- stock LS going bit over 5000RPM
- For everyone looking for an ITR sway bar...
- Integra Cylinder Head..help
- hairline crack on rims?
- header question..did search
- Can't Find info on if 4-2-1 is better or 4-1 is better for B18B?
- How to remove oil filter with simple tools?
- Help, Neon Lights Won't Work
- FYI: FS: Brand new rear Koni Yellow for GSR
- B18A FI or LS/vtec
- Canadian Tire vs. Acura Parts
- pics of the gsr
- Suspension setup
- Where should I go next with my GSR
- Transmission cooler install
- got busy with my teg this last week (with lots o pics)
- ITR flywheel on LS?
- 89 AT LS
- b18c5 engine swap into 90 integra with LS Tran
- type r head on a gsr block
- gs-r caliper question
- removing tranny...
- Okay, I revved past rev limiter....
- differences in stock cat conv.
- Battery Relocation
- aem short ram
- o2 Sensor taken off = decrease in power?
- what should i look for when inspecting a motor to buy?
- Anyone using the MOROSO Street/Strip oil pan ?
- anybody using the Spoon filter?
- hey everyone, link to ATS, Spoon etc parts for DC2
- Stock Exhaust ?
- Engine Swap
- gs-r insurance
- Dist. Cap.
- thinking about getting a integra gsr
- What exhaust cat back is everyone running?
- Victim of Road Rage
- Finally gettin some CASH. what would you do?
- loosening tie-rod lock nut?
- all motor or turbo.
- white smoke after valve adjustment
- Radiator Flush
- What is the stock CFM on the gsr heads?
- I really need help with my car..anyone in the Seattle area who is an expert with electrical?
- weird sound when stepping on clutch
- help with torque spec valve cover stud
- Pic of my 95 GSR - Thoughts?
- correct size muffler
- need help putting on ITR calipers in so cali
- First upgrade on integra
- best shocks with H&R springs
- Camber adjusted?
- bleeding screw is leaking!!!!
- rev hard kit
- I just got $3000
- zex plugs
- how hard is it to recharge your A/C
- 5 lug question.
- Type R and GSR rod difference
- who is the guy that makes the tail light gaskets?
- 2000 GS-R vs. 3000GT SL: pointers on how to beat this guy!
- what should i shift at ?
- GSR throttle body?????
- Question about brakes/SS lines?
- oem piston ring gap
- b18c
- Woo hooo, I have successfully installed a 99 JDM ITR SRS momo wheel on my 94-95 GSR
- Tranny is history
- Last pics of my teg
