View Full Version : Acura Integra
- Jackson Racing SC for DA integra
- Account for DB2 owners here!!
- Electronic Helms
- import replacement parts.com?
- a few questions ( b18c1 into LS)
- 90-91 headers fit 92-93 integra?
- Motor mounts and b18 vtec swap
- 5 speed swap vs sell the car
- Apexi WS2 for 00 gsr ???
- Strong Potent Burning Smell in Exhaust area....anyone know what it could be?
- where to find JDM integra bumper reinforcement bar??
- differences between RS and LS integras
- 2000-2001 Gsr Gauge cluster wiring diagram
- selling my acura manual
- stupid ass key question
- Clutch Masters Clutch Need New Is Act Disc Okay ?
- 90 integra gsr questions
- Need some advice b16 w/ ctr pistons or b18 w/ ctr pistons
- VSS plug on transmission end help 96 GS-R OBD2A
- 17 inch gunmetal rims with tires for trade
- Need STAT! DC integra or EG civic front driver side A ARM!
- ?????About 4 door GSR seats
- connecting rods
- Gunk and Grime between head/block, losing oil....
- What set of tires would you guys pick for the Teg?
- Brake PAD....for GSR 98....what do you recommended?
- Does OBD1 and OBD2 has the same timing belt cover (2 external, 1 internal) on all B series?
- adjusting cam gears to tdc???
- Stolen Integra Prevention
- Need Help!!!!! Radiator fan not working
- Raising Integra Redline
- underside of the integra?
- bang for buck? (sc content)
- See ya - no more Integra
- What parts do I need to get?
- Timing Belt Tension and position
- ls turbo set up?
- Need Help: b20 has bad compression what could the problem be??
- GSR BLADES W/ TIRES FALKAN ZIEX FOR TRADE?
- How to pull engine codes
- Does any USDM type R exhaust fit my 2001 LS???
- Need Suggestions on a quiet muffler A.S.A.P!!!!
- 2nd Gen Clutch release bearing help
- NSX REAR calipers on a EG6???
- 90 DA b16 obd1 cable or hydro???
- ecu code 9 -- No 1 Cylinder Position
- Where can i get this?
- Need help on adjusting the height on Buddy club damper kit...
- Why does my battery keep dying?
- Looking for pics/ Info On burgundy colored integras, 3rd gen style$$$$$
- leakin oil in spark plug
- Rubber exhaust hangers!!!!
- TEG STRUT BARS...
- smoke
- auto to manual swap for 90 da
- looking into buying 4dr. what do you guys think?
- SRS question
- So Cal Paint/Body Shop question
- How do I get the highest compression ratio for LS/VTEC...........
- white guages
- exhaust rust
- would a 94-00 integra dash fit in my 91 integra?
- The "How Low Does Your Header Go" Thread
- What is an engine rebuild?
- burning Flywheel Question!
- qcktegls's 403 install (56k go for a long walk)
- Quick question about tranny?
- My car feels slower with the lighten flywheel..
- just got a gs-r
- cel PO141??
- ::What to use and Where to buy Spark Plug for my GSR::
- Will these modifications break me into mid to low 14's?
- how to test which axles is bad?
- 16inch motegi ff7 rims gloss black machine lip625 obo
- uh oh!!!
- new pair VIS Z3 fenders 94- up integra $$75
- Troubles with my GSR.. opinions wanted???????
- genertion 2 bumpers
- searched...Gsr engine
- What turbo kit for ls/vtec?
- changin spark plug.
- Manifold Swap Injector Noise?
- protection againist theives?
- Help, stuck in Macon, GA!!
- stock ob1 injectors!!
- my car is running rich
- paint codes
- Skunk 2
- looking to buy
- Gas Door wont close HELP
- TEIN Flex on a 97 GSR...how good is it?
- not loud enough
- J's racing intakes
- look what i found
- brand new OE distributors on ebay... r they OEM?
- HELP IM LOOKING FOR A NEW CAR
- 99 Si DC 4-2-1 Header on my integra... any gains on my RS?
- nos installation question?
- DA owners with rotas
- Installing Header with 2.5 “ collector to a STOCK cat
- Smog Issue: Emitting High NOx Levels-- Is it the radiator?
- best parts for my db8
- interior 4dr & hatch interchangeable with 94-01?
- Valves Too Tight?
- Please help me estimate how much my car is worth
- Exedy Clutchs in a boosted gsr...
- obd0 to obd1
- importance of dowel pin on crankshaft to flywheel
- BUSTED STRUTS??
- help! motor mount insert is a yotch
- windshield wiper arms
- Pics of new teg with dynamat
- STOLEN - 98 GS-R - Miami, Fl
- GSR LSD??
- Help with shock and springs please
- Looking for a integra 94 and up 2500
- dash wiring harnesses
- bypass evap purge control solenoid
- How do you get your car on jackstands?
- quickquestion: sportline or prokit?
- structural
- GSR turbo questions
- Cel 92?? Evaporative Emission Control System ??
- Clutch Problems
- Help : GSR making weird noises after 6k plus
- Tuning and Turboing an Integra GSR
- secondary O2 sensor problem
- 16x7 or 17x7 or 18x7 - for a daily driven lowered 4 door Teg
- Blox Rear Sway Bar....what endlinks to use?
- 94-97 Si Vtec lip
- Purchasing a TEGGY!!!!
- Tuning Software/Program Preferences.
- What a deal, got a DA for ~$600
- best clutch from exedy for a 95 integra ls turbo?
- getting 404's for the Ls
- coolant reserve tank relocation
- looking for some parts
- Good turbo?
- My Oem JDM Integra type r 98+ HID Went out ! Need a new one, anyone know where i can get one?
- Replacing head gasket and need tq. specs
- rattling noise at low RPM
- squeeking noise at loww rpms??? (94 GSR)
- Greddy header for GSR????
- Wings West Lip Kit for 95 Integra LS 2Dr...
- Fields VAFC
- Help Me out here... 96 GS-R VSS wire location
- changed the valve cover...got smoke
- JDM B16 Throttle Body Gasket HELP !
- feel like a nub...
- Does anyone know how to install an Electronic AutoMeter Oil Pressure Gauge?
- gsr exhaust on a ls
- 90 Integra with obd1 harness convertion HELP
- What pistons should i use on stock ls motor?
- Guage question
- Brothers, After basic bolt-ons...civic type R cam best mod? $400 to spend..
- Clicking noise from power steering pump
- E brake handle
- 97 ls ecu used for itr swap?
- Taillight problems
- Putting half core radiator in teg?
- wtb itr front end conversion
- New DC5 Type r or my eyes playing tricks!!!
- self diagnostic testing for check engine light signal
- CTR Cams
- jdm console into usdm teggie... can it work ???
- Energy Suspension Bushings
- i have a CEL i cant pass smog??
- how to
- DA: Minimum Flywheel Thickness/Weight
- ls vtec
- Can I change the filter without jacking up the car? (looks hard)
- curious, dc2 k20
- Took my a/c out. Radiator fn not working?
- bottom end build question
- where to buy an integra type r lip
- 96 Cluster Question (what is this Plug for)
- people with b16
- Those with Amps
- getting a CEL 45 (too rich, too lean)
- SEARCHED: Got this weird noise, help me out.
- Power steering question
- HELP!!!
- Volk Gram light wheel question
- Tranny Trogs Unite!!!!!!!
- SI i-VTEC like SOHC VTEC?
- Time to sell the gsr???
- just got crower 404
- Help CARsound hi flow cat doesn't fit on 99 GSR?
- Integra Stolen in Maryland
- gs-r head work
- Door closing sound
- problems with auto. trans...
- itr climate control help..
- Free runs at GREAT LAKES DRAGWAY
- Too much transmission fluid??
- Blinker Stoped Working HELP Plz
- Squealing from Dash area
- Tranny match up
- What is the most common problem with an Integra?
- A/C belt removal
- Difference between GSR, GS, RS, LS, etc...
- Clutch problem
- Exedy/NKK clutch kit???
- throw out bearing and pilot bearing
- can u start a engine with AT without tranny fluid?
- Skunk 2 Stage 2 Shafts vs stage 3's
- possible to attain 250whp with major bolt ons in gsr?
- Check Engine...P1457...Please Help!
- brakes making noises
- Comptech R wing
- hyper blink relay trick? diy?
- DC2 lighting specs... i need help!
- what are the DC for integras?
- disconnecting exhaust after headers/manifold
- ls gas mileage??
- Looking for REAR OEM (Not fiber glass) Rear Skirts
- ::::Full Coolent Question::::
- My brake lights wont go off! also airbag problem... please help me!
- reverse kights stopped working on my 94 teg ls???
- which would you recommend?
- Would a steering hub from a 95 accord fit a 95 integra?
- 94-97 GSR ABS Pump / 94-97 LS???
- Swap Question
- irradic idle on 91 b18 non v-tec
- new guy in il 96 ls
- O2 Sensor Diagram
- REMOVING ABS.... Help!
- replacing an obdI steering wheel with an obdII
- engine or tranny 4 sale?
- rear engine mount???
- integra starter swap. Searched... Help
- 1991 Integra speed problem
- apexi gt spec header: question
- Back in the Game
- gotta ? for u ITR guys
- what is stock rear speaker size on a 91 LS?
- Tegra Heated Seats?????
- 90 Integra Halo Headlights help
- b16 da?
- What's all needed for the Skunk2 IM install?
- acura's free service!
- question for gsr owners
- Need Help With Code 90 ...Please read
- windsheild wipers are crazy
- pix of integra with cf m3 style mirror?
- VTEC!! :-)
- AEM Question "Searched"
- dead gsr
- Basic Question!!!!
- head gasket p/n ?
