View Full Version : Acura Integra
- Need jdm starter...
- ABS problem...pls help 97 integra gsr
- clutch adjustment
- Taking apart the top end??? can i do it without messing it up?
- Weird Starting Problem
- need a lot of help......
- 00 GSR FORGED INTERNALS, 12.5:1 COMP, OIL IN CYLINDERS....WTF
- 2006 Honda Accord wiring diagram factory service manual?
- eng swap problem
- angel eyes headlights???
- secondary 02 sensor issue - Where to buy L shaped Anti-Fouler?
- speedo stopped working after dash was torn apart. Tach works fine...coincidence???
- TYpe R grill on DA Integra
- door hinges
- stock injectors
- 96-97 fuse box diagram
- are Clutch Locks safe? any stories?
- ABS light coming on!!! HELP!!!!
- Leaking Air - Drivers side window
- car experts - i need help
- Hey guys, had a couple of questions, swapping out my 97 ls motor for a B20B vtech
- can anyone help me in a suspension install?
- Radiator Fan ??? not sure
- Wierd idle and steering wheel problem.
- help please?
- CEL Bank one running rich?????????
- bracket help!!!
- picture request
- B20C1 Head gasket choices
- Question about sizing vs 96-00 Civic
- Gimme your opinion on my jdm front
- MSD Distributor Cap
- Help me solve this mistery.
- GSR tranny
- OBD2A head on ODB2B block.
- Official DA ABS removal thread
- tackling the impossible
- Painting Help!!
- 98-01 Conversion.
- Symptoms of a bad fan relay and a bad thermo. fan switch?
- Good clutch?
- What is this on the thermo. housing? (photos inside)
- what is this?
- ABS delete help 6 wires ?
- tanabe springs.... need opinions
- what size???
- Cruise control after auto-to-5spd swap
- DA code 12
- Type R tranny vs. b16 tranny
- Eagle crank
- 2 door itr spoiler on a 4 door will it work?
- my car and what i need help with
- Im new but take a look 98 GSR
- HELP!!! VTEC PROBLEM
- new to the boards
- Pick and choose 94 GSR head 96 GSR Block 00 Si Head and 2 B18B1 motors
- im bout 2 go Turbo, should i use S2k oil filter?
- 98 DB8 B18c: ELECTRICAL ISSUE!!!!!
- Help!!! Integra Flooded!!!
- WTB: ACURA 94 LS TEG POLISHED HEADERS
- lower control arm bolt snapped please help!!!!
- ecu pinouts
- oil leak after head install on GSR !!PLEASE HELP!!
- needing new clutch? suggestions...
- 1998 integra 5 speed
- 1992 Acura Integra GS-R
- What should I use to seal my leaky gas tank?
- '97spec ITR swap into '00 GSR SHELL
- how do you remove the rear glass from the hatch?
- speedo way off!!!
- Picked up an Integra and have a couple questions
- Wheel Bearing
- integra 5 lug conversion
- my integra got stolen
- How much to rebuild a GSR transmission? or cheaper to buy a used one?
- I need Help?????
- injectors
- got a ? about lean/rich running
- post pics of ur sportmax 501's
- 2001 LS
- integra projector headlights are too small
- PR3 question
- Help!! Integra flooded
- I think I bent a valve in my GSR.
- i need help =/
- Check Engine Code: 22 VTEC pressure valve
- Help!!! buying rim/tire combo today
- Having problems changing the clutch MC.
- megan racing header
- ???? What car is the S80 tranny from? someone please help me out ????
- Just bought a dissassembled B18, Need advise
- stock injectors?
- GSR Oil Pan
- Shift Issues (Searched)
- OBX Catalytic Converter??? :thumbup: :thumbdown:
- 92 gsr bogging..
- integra steelies
- Need help with possible car for my sister:
- ? on a 92 ls integra...
- ARP part #208-4302 or 4303 or 4306?
- Engine Problem??
- Crazy problem
- turbo
- *** ((( Need Help, Jumpy RPM gauge ))) *** LOOK===>
- How to install a cf trunk on a dc??
- Code reader problem
- ECU question?
- will DA ABS sensors in front swap to DC?
- 98 LS REVS at 5000RPM?>?? .....
- What conventional oil do you use?
- My '94 teg keeps dyin' on me. Help!
- high beam low beam
- EM1 ground controls on a DC
- Transmission work
- B18B1 Turbo Build HELP
- WTB NOW: mint condition Dc integra fenders, doesnt matter color/scratched
- Thermal R&D exhaust
- turbo
- 95 integra gsr noise problem
- LS B18A1
- weird problem: climate control
- for sale: oem 98 integra white front end!! everything is there!!! ^ ^
- TUNING SHOP IN LA
- used oem 98+ integra gsr muffler
- Rear wheel noise...wheel bearing or brake problem?
- new to HT
- Gsr Block girdle and Main caps on Ls block? Do able?
- HID's and projector headlights
- VTEC Solenoid oil leak. looking for some pointers on how to replace
- JUST BOUGHT SOME SEAFOAM AND GOT SOME QUESITONS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Location of OEM JDM Ballast for HID DC2?
- shifting gear trouble
- idle problem...need help pleas
- Kyb GR2 and skunk 2 springs??
- Writeup for RSX Dash & K Swap into DC2 Integra?!
- integra spring rate...?
- Three possible setups for my Integra which one do you like?
- 98 dc2 oem headlight?
- Need Help Finding 93' GSR
- Brake Light On
- motor bogs out after it turns over
- Pic Request: Button to turn off Maint Required Light on 96 LS
- upper hose is hot, lower hose is cold what's wrong with my car?
- h22 vs k20a in weight difference
- GS-R Check Engine Light. Code 22?
- is 12.0:1 compression ok for a daily driver?
- Identify exhaust........
- painting mirrors... how do i take them off and apart?
- APEXi V-AFC II
- Just put some x-drilled and slotted rotors on..
- Ls exhaust and gsr...
- I NEED HELP PLZ
- Help. I broke adjusting knob on my illumina shocks
- help ls/vtec or h22w/h2b setup help please
- KYB AGX Shocks Vs. Tokico Illumina Shocks
- stock internal boosted DA's? how much hp you guys making??
- After Curb Accident....
- Which type of head is better for a B18b motor?
- Spark plug, dizzy cap? I am lost with this one?
- SLAMMING MY DC.
- Knocking Sound in front of engine.
- how do i know
- 92-93 gsr rear tranny mount interchangeable with ls motor on same car?
- HELP!!! cant get the car to run right
- tires ls and ls special
- weird clutch pedal clicking--97gs
- Cam Gears
- Racing Seats?
- 92 RS master cylinder
- Integra and prelude exhaust
- Trying to email a user. Why am I restricted?
- no spark below 1500rpm in 4th piston
- Exhaust Rattle Question
- should i trust him and swap it..or not?
- alternator! which one???
- integra front end question
- axel back exhaust
- Code 10 = Limp Mode??? -Obd1 GSR
- Will OEM exhast manifold from Integra LS fit GSR??
- How much should I sell my 98 GS-R for?
- new teg owner
- GSR map sensor?
- a few questions about my new JDM Front
- Mystery Part
- Clutch Issue/ Easy Question
- Some general questions about my car...
- Valve Adjustment ??
- Short Shifter Bushing Replacement
- hello i want to find this DB8 tail lamp please help me thank very much
- 90 integra
- bent valves????
- ITT: You help me diagnose my bogging problem.
- how to clean headlights
- ECU Upgrade
- 93 Integra Smoked Tails
- coilovers???
- b18b build .. what do you think
- Many problems, many questions (misfiring GSR)
- GSR - LS brake differences - 94 LS
- crashed my teg everything for sale
- New DC Kid!!!!me n the cousin DC & EGG
- Part # needed
- Cant decide on an exhaust.
- Tough Question!
- oil in coolant
- Should I trade...94LS Teg for 97 Coupe
- loud bang at startup
- **Attention: All 96-97 integra owners with less than 150,000 miles**
- Weird question: size of dc-sport header collector
- integra parts????
- 4Dr. Exhaust
- how do i upload photos of my da9??
- Where to get an ITR tranny
- PIC Request and Question for DA One Pice Black Housing Headlights
- Ls/Vtec ?sss
- chipped ecu vs hondata s200
- How to tighten cv boot strap?
- Things to look out for on a 1990 Integra
- keep blowing dizzy
- jdm cf shifter console piece
- can someone tell me the physical difference between an OBD1 B18a1 and an OBD0 b18a
- some teasers shots
- Identify these rims!?!?
- exhaust fitment
- Engine Question
- Which Oil Pan for LS/VTEC>
- need help with installing a fpr
- Rear Seat Removal
- steering wheel question
- help with budget
- won't go into first gear?
- Vavle Adjustment ??at lo
- Tranny question.
- spring ratio off??
- Removal Of Rear Seats
- Master and Slave cylinder
- breaking in newly built b18c1????? HELP PLEASE
- gsr header question
- Integra goodies for saleee
- exhaust leak???
- IM comparison
- 4door rear seats...
- What kinda gas mileage should I see from my 96 LS?
- Shooting or getting rid of MAP and evap system
- Will a b18b motor from a 97 mt teg work with an automatic Ls tranny?
- tranny is starting to go, what to do what to do...
- Beaks DC2 quick swap anti-swaybar work with Type-R LCA's
- i just Bought
- Auto to manual ecu questions
