View Full Version : Acura Integra
- Yellow fog inserts in jdm one pieces!?!
- my 1992 DA9, very slow build thread
- xtd flywheels
- Rear Motor Mount Removal
- da integra wire tuck
- b18 swap with running issuse
- car wont start...
- Batt light while stepping on gas?
- b20b pcv valve question
- What Kind of Brake Fluid Are You Using
- Wiring Issues anyones thoughts
- Best place to purchase a fuel pump? And best kind?
- Just bought a 91 Integra GS that has a code 9...
- Help save my GS-R
- Speedometer Problems
- throw out bearing or input shaft bearing??
- Engine Miss Problem
- 1998 lsvtec timing problem
- Where Can I Find A Good Transmission?
- Need entire 97 ls engine harness schematic
- adjusting valves....
- Seats- I have $400-600 to blow...
- proper way to remove abs?
- Rev limiter @ 5000 rpms?? Wtf..?
- Solid Billet Front Torque Mounts
- custom bracket. ls tb on gsr manifold in ls integra
- Exhaust hitting swaybar?
- CA smog: how to lower HC(failed)
- Does anyone make an AC delete ONLY crank pulley?
- B18B1 Crank TDC, and Pulley TDC not lining up.
- cheap radiator?
- starter issues
- what obd is my motor?
- 2000 RPM idle after freeway drive
- What code is this?
- hey i have a few dc questions
- b18c-r into gsr obd1 what i need??
- How do I disable ABS?
- hard to get in gear
- Quick Brake question
- GSR Cooling Lines
- Db1 problem
- GSR dipstick lenght....HELP!
- Silver 97' LS
- Gear Console Kit Carbon Fiber/Aluminum 94-00
- Car will not crank, Constant beep noise when trying to start
- Help? ITR lip?
- Good trade?
- blown shocks ?
- fuel pump/srs fuse problem
- 2000 JDM B18C swap need help CEL/LOW idle
- Help: Motor mounts and slamming your car
- is this an itr? or sir-g??
- temperature gauge showing low
- JDM b18c starters?
- can someone please help me locate where this wire goes?
- Lsv Blue Smoke
- what a nightmare. motor mount bolts snapped
- Headers
- Camshaft Question
- starting problem!
- Im pretty good with honda/acura im stumped tho.. tach
- What specific things should I consider when rebuilding my engine??
- Noob question
- Flip Out Head Unit in a DC
- SI-VTEC LIP
- What do i swap???
- Type R floor mats
- any shops in jacksonville fl?
- gsr or ls rods?
- ls/vtec setup opinions!!!
- Lack of knock sensor =?
- STOLEN INTEGRA
- 94-97 turn signal options?
- pass axle question
- 2.5" Exhaust- Which Cat do I need???
- Driver Side Axle Removal Help!!
- Car Shakes When Put In Gear
- Mechanic changed timing belt & water pump..
- my 10 second monster build
- craigslist acura integra, is it worth it?
- 8500 for this integra?
- turning signal keeps blowing
- 91 integra idle problem
- 2001 Acura Integra ls turbo
- teggy clutch issues
- Fans not working
- Small hole bottomside intake near TB, not for breather
- High NOx - opinions needed
- no idle when warm?
- Gsr Integra Idle Problem
- Replacing 94-01 Integra LS - non abs master cylinder and brake booster on 93 Del Sol
- Car doesn't start, bad battery?
- New build won't start.
- inexpensive Honda Tuning and mechanical work in MD
- Jdm One-Piece Headlight
- Anyone using DURALAST Spark plug wires?
- jdm front end conversion worries
- bumper piece need help
- Replacing battery cables, 94 Integra LS w/ B18C JDM
- bad water pump or alt pulley making grinding noise?
- 96 DB8 GSR overheating problems
- DA9 problem???
- Help!! 98+ Splash/Mud Guard Fitment Question!!
- idling issues
- Advanced dizzy problem
- Turn signals don't work!?!?
- '94 Integra - Weird starting and overheating problem. *VIDEO*
- Low Idle... Somewhat Fluctating
- Need help install a clutch cable for 92 integra
- turbo lsvtec wont start?
- 1989 Acura Integra
- Da9 H22a Build
- 95 b18c1 dies on 4th, 5th gear pulls
- Hawkman13's Integra Build
- New to H-T Acura owner.
- check engine lights stays on...obd1 pr4 ecu problem...
- 95 teg rough cold starts...(searched)
- how to remove OEM fuel rail fitting ?
- Acura integra DA help!!! Pulled out spark plugs
- Help my teggy out "/
- marine in need of lots of help
- let the UKDM Dc2 build start ;)
- New to the Forum
- Sunroof problems
- smog
- check engine light code help
- HELP! CAR DOESN'T START
- >.< Tips on maintaining a cheap paint job.
- Help! 90 integra rs auto randomly dying out, I need to go to work!!
- ABS light comes on after moving forward in 1st gear
- Screwed up my A/C, need to get some parts...
- obd2 wiring harness question
- buy ls motor or buy shell
- LSD TYPE R TRANNY value ?
- 94 Integra RS clutch engage adjustment
- At a full stop, car hesitates when I step on the gas
- 91 integ smoking in unidentified area
- My Integra Build :)
- My 2001 Milano Red Integra GSR
- Fuel Rail Spacers
- Where to get a RHD Triple gauge pod?
- Wiring Harness Question
- 10 yrs
- 00' Integra auto, vibration when I let off the gass in gear only
- Would Like Some Specific Help with LS/Vtec Build
- My A/C problem
- should i replace the piston rings?
- b18a1 questions and d15b2 need some help
- GSR running rich, spark plugs white (too hot). Discussion wanted
- 91 integra gs wont start
- 94 gsr brakes problem help plz
- 94-01 rear quarter patch panels?
- yep4doors's DB7 Build Thread
- Biggest mistakes you can make?
- Engine monitoring system?
- ive got a b18a da integra and i need on how you could build one.
- Help Building LS/Vtec
- my 98 gsr build. any ideas?
- da9 integra smoking white
- Honda mats for a USDM 95 GSR
- squeak squeak squeak wheel bearing?
- Car smokes need HELP!
- tranny mout
- 95 integra gsr boosting questions...
- 1994 Integra GSR acceleration noise
- 1991 integra accelerating problem
- All stock GS-R... lower??
- door open light on?!?!?!?
- DA seatbelt question
- AE Radiator came in
- Swap b18b into 91 integra questions
- 1993 integra rack n pinion removal trouble - please help
- 2000 integra tading for an EG question
- Is a 1998 spec b18c ITR plug and play in a 1998 GSR
- Which Axles and Halfshaft??
- HELP ME P1035 CODE WONT GO AWAY
- dc seats
- Price/Sale ITR cat?
- H22 or B18swap?
- DA jdm Y1 lsd passanger side fluid leak
- Leaking oil from headgasket!? i just changed it!!
- DME coilovers
- Coil Check Help (I unplugged spark wires while running)
- Starter only works half the time? i can start it by touching the + and - together
- Help integra 89 suspension! will 90+ fit?
- Also thinking of selling car, need help with price.
- Can't get the Starter bolt out!?
- 2000 integra gsr Crank shaft pulley came loose?
- Gsr Shortblock for sale
- What Power Steering pump is this?
- Turn key, hear click under dash, but starter doesn't turn
- DA LS gear set/trans
- Khoa's JDM DC2 build!
- Quick A/C question
- GSR swap Trouble Starting
- GSR w/ Blox IM what intake for EG/del Sol?
- DB8 from Farawayland
- Hi I'm New. Meet My Integra "Onyx"
- CEL on gsr
- Motor goes crazy in the rain?! stutters & stalls...wtf?
- LS/vtec problem HELP
- ls vtec fouling out plugs
- Fuel Pump not priming, Solid CEL
- 4th thermostat to fail in 2 days...
- WA emissions FAILED
- 2000 gsr hatch leak
- will a 98teg trailing arm fit a 95?
- Integra LS wont start
- upgrading the main battery ground
- Squealing noise only when driving, anyone?
- Stabilizer Bushing
- Tegiwa vs Highend vs RMF rep
- Weak distributor=bad gas mileage?????
- Coilovers locked?
- Body cutting into tire didnt happen before 205/45/16
- Pressure out of gas tank?
- Oil light blinking. Help?
- My Slow Dc Build!!!
- ======LSvtec Oil Problem====
- Great BUT affordable header?
- 1993 integra cutoff
- 2000 integra which sensor is this?
- extreme integra weight reduction in need of help
- My Integra ")
- f/s or f/t 16" Jdm Itr wheels mint with tires
- Fender Replacment
- Need Help With Type R Rear Swaybar for GSR
- Transaxle drop help
- '94 Integra LS - Window/Lock Problems
- Project rice to nice
- What kind of oil do you use?
- what spring rate should i get my ground control
- B18A1 acting up.
- ls/vtec?? gsr head with b18b1???help
- Rebuild thread haha
- Need advise for engine.
- wanting to turbo my 99
- Just got my first Integra!
- 00' Integra LS Misfire codes 71, 72, 73, 74
- Integra Gsr Exhaust question
- Timing Problem On JDM B20 Motor
- Stripping your valve cover
- my 95 DC2
- clutch wont bleed after master/slave install
- How do i remove an oil pump from ls/b20 motor
- what is this port used for?
- integra LS Questions!
- My new integra
