View Full Version : Acura Integra
- GSR struct bar
- Install question for an intake!
- gsr tranny question
- does anybody has a diagram of ABS removal and reinstall non-abs??
- WILL NOT START ON 4 CYL. BUT WILL START ON ANY 3
- 2001 gsr dyno results w/out sk2st2 and w/sk2st2
- help on adding side markers(turn signals)
- B18B crank pulley not coming off!!!
- CEL 700 & 740?
- Smog Check Q
- Exhaust Help?
- how to uninstall/install a hatch?
- Is this common on the rear window on the TEG?
- Headlight adjustment (searched - specific prob)
- How hard to change transmission? Anyone have a write up?
- JDM look here
- ls/vtec gsr/ls crank pulley question
- where to buy top fuel lip kit?
- Turbo Question
- 1.5 Year old Apex'i N1 exhaust rusting out?
- obd2a-obd1 harness /VS/ obd2b-obd1 harness?? H E L P
- VA inspection???
- master cylinder differences
- P72 ECU troubles (Code 22)
- windshield washer fluid problem!!
- my car is broken!!
- how does a butterfly intake manifold on gsr works?
- HELP ME!!!
- whay type of gas?
- fuel pressure for stock ls/vtec?
- Sparco Brackets EK/EM1=DC?
- Slotted rotors + Other stuff
- integra LS's w/ B16 trannies
- Bored to 2L, how to break in & how to tune freshly built motor?
- Wings West/Comptech Itr lip
- key in ignition
- 92-95 EG and 94+ teg suspension
- OEM Radiator Question/ Mysterious coolant leak
- GSR "cuts out" or "hiccups" when stomping gas, what the heck?
- Need help connecting the module
- Catback Exhaust for 99 Ls Turbo
- distribtor help ???? please help??
- radio antenna motor problem please help
- 90 Integra LS moonroof stuck...help
- Tranny wont shift after 5k rpm.. possible problems?
- Anyone else carrying a full size spare?
- Replacing Rear Brakes, Help!
- bit of a dumb question...
- Do I need to disconnect my battery for this?
- JDM ITR headers question ???
- Dyno in 3rd or 4th?
- GSR Cluster Differences???
- Problem and a question
- Can you identify this front body kit...
- water into sparkplug area
- Bad o2 sensor?
- PR3 B18C vtec problem
- o2 simulator isnt working....
- Comptech Swaybar End Links
- VIN Check up
- heads up guys stolen integra (recovered now) PIcs
- What do you guys think of these they are new!
- Need part number for exhaust manifold stud
- body styles
- Cold stopping power with Axxis pads
- JRSC Sound Clips/Vids anyone?
- Will a USDM and a JDM TYPE R exhaust fit a 95 LS?
- the thought of a k20a2 in a 90-93 da 4 door
- has anybody heard of this company?
- would 13" steelies fit on a teg???
- 5-speed vs auto cam profile
- Can someone tell me how to connect a Autometer Fuel level guage in a 95 GSR??? THANKS
- ** stolen in philly**
- Need Rear Brakes for Integra!!
- Wings West / Comptech 94-97 ITR lip
- s2000 seats in integra please post a pic
- Front Lip
- Stock LS Rod Limit?
- act clutch pictures help me determine
- Pop between shifts, is this having to do with a warn timing belt
- Whats wrong with my gas milage? I dont understand :(
- are 2 tonne axel stands safe enough to support my gs-r?
- high compression pistons
- ball joint problem
- Back fire...
- BEST PLACE TO DYNO AND TUNE WITH HONDATA ON SOCAL???
- oxidation
- top speed for a GSR
- 90 Integra rs just turned off when spark plug was removed ?
- intake
- h22 integra
- Pistons
- Stock GSR Exhaust
- Silencer on T1Racing exhaust!
- JDM ITR cluster on DC2 GSR????
- where can i find a......
- No Brakes on 92 Civic DX
- Spring or Coilover?
- CTR in GSR
- Low compression numbers.
- shortest short shifter?
- itr or ctr piston in b20?
- b20-vtec in a 92 teg
- is this concievable?
- Exhaust & oil residue
- Code 22 only in 5th
- New kid on the block
- Car is running too rich? help?
- Ls Vtec Swap
- about pressure plate
- Steering ratio for all Integra 94 - 01???
- burning alot of oil?
- Integra Bogging On 2RPM
- Safe to run NOS ?
- Need a Pretty Rare Part... HELP!
- engine swap
- GSR Hi Power HKS exhaust question.
- Holy sh*t! My H&R sports dropped my car 2.5 inches! help!
- brake light is still on. please help
- ** STOLEN TONIGHT, Need Help in KC MO ASAP!!!!!!
- trouble starting
- Ski Rack for 00 integra
- swap problem need help asap
- Intake question, Is this important?
- what is this 92-93 lip called? where do i get it?
- GS-R Rear Brakes
- how do i post a pic???
- OT : Air compressor w/ complete set of tools
- CEL CODE 13 on 91 integ
- loking for a 90-93 sedan integra 5 spd
- whats the stock HP on the 90-93 integs?
- Automatic tranny shifting woes
- upgrades for an auto?
- What kinda clutch?
- Ok, I searched, and still cant find it...
- Questions on 88 integra....
- hands down
- how much to pay for salvage 90-93 teg ?
- LCA (lower control arms) ?
- Can you drive with ticking vavles?
- hey i got something new to ask plzzzzzzzzz read this...
- what's the point of that plastic divider in the backseat?
- N1 exhaust on a integra
- O2 SENSOR GONE?
- 4x114.3 Prelude Hub on Integra
- INSTALLED OEM ECU AND STILL HAVING PROBLEMS!!!!HELP!!!newblar here
- what cc is a oem gsr injector?
- apexi n1 or stage 2 clutch which one should i go for next??
- how do i fix the window rattling on a g3 teg when i close the door?
- poor man's type r emissions
- Hey: Quick Question Will B16 headers/mani fit in A Ls/B18b......
- Recaro Seats
- Bride Seat Rail Question
- My custom exhaust @ uglyiiI!
- Need some parts
- ACCIDENTLY OVERTORQUED HSTUDS
- head question
- Exhaust Question
- dc header fitment?
- Integra rear bumper
- How to disable clock light?
- bad O2 sensor? help
- tires for 16s
- CEl Code 9 Questions
- Smoked Taillights
- 98 Front End Fitment
- New spring tensioner with rubber around it! Please help fast
- swap
- Final Track time of the year
- Clutch for '87 integra RS
- where can i get aftermarket crossmember for my 91 teg (dc 4-1 header)
- newbie question...
- my car was finally broken into....
- center cap on rota slipstream
- Question about the value of a integra 1995
- own 98 LS have mods need more???
- WOW
- 98-up rear question
- Turn signals blinking REALLY fast
- DC Sports Exhaust
- program 99 ecu to 2001 ecu for BAR puropose
- Vafc 2 question
- question for you gsr motor owners . .
- air/fuel gauge i made
- Rattling!
- Apexi N1
- Little Advise!
- obd0-obd1 wiring
- ls wiring
- Lagging
- horn button wont stay on
- 95 automatic tranny
- new to the import scene, had some questions.
- greddy sp vs. apexi worldsport vs. comptech sport
- front and rear lower tie bars
- GSR or LS Tranny
- check engine light
- Question about integra rear seats???/
- what is needed
- reasons to NOT buy a salvage titled vehicle (9 pics)
- Help Power windows sticking on 2000 LS
- Teg broken into Tonight
- LS-R
- guages
- I need new spark plugs, what brand is the Best for our tegs?
- SRS light
- running without the ac belt for whole winter safe?
- integra gauge cluster not working
- Center Console Question
- Does anybody know the license plate bulb #?
- Who runs 13's?
- Quick Center Console Question
- side skirts
- Question about exhaust for GSR?
- can this setup be revved safely to 8000+ rpms?
- where is a good website to order paint? ppg
- tail lights (pics)
- jdm 23mm sway bar and neuspeed rear lower tie bar
- camshaft question
- WINDSHIELD WIPER RELAY????? LOCATION OF WINDSHIELD WIPER RELAY??? ASAP!!!!
- what is ur RATING (1-10) for OMNI Front camber kit
- Flat spot on header
- *NEED TO KNOW* Civic/Integra Exhaust Interchange?????
- Q about ITR springs on GSR
- Tsudo n1 axel back exhaust!
- Stripped 12 mm bolt from installing 4-1 Headers *advice?
- Engine won't start, Need help
- where is the windshield wiper relay??
- got my car back today... some problems
- 4dr gsr weight compaired to 2dr?
- For those who installed oem optional side skirts
- Blew motor, possible reasons?
- LSD in stock LS tranny?
- Modifying 94-97 front bumper--PICS.
- Need color code for Gold Lenso rims ASAP (PICS) Please help!!!!
- B18A1 Surges and misses
- b21 vtec?
- crank pulley bolt
- Quick ??
- suspemsion for my GS-R
- Type R and LS Thermostat, Thermoswitch, & Water Pump?
- MSD Blaster 3 Coil and Ballast Resistor
- Going to buy a GSR plan to rebuild engine
- overheated and coolant all over my engine bay! DAMMIT!!!!
- horrid gas mileage..
- Anyone have information on Team Empire or Vista Empire???
- a squeaking nosie in my clutch
- Did honda change their oil filter size?
- ITB's with turbo setup ??? is it possible
- NEED HELP?? Manual Transmission Problems
