View Full Version : Acura Integra
- Electrical Short
- rear seats
- low or high compresion?
- cams cap
- all motor or turbo???
- are the axles wit abs the same as the ones with out abs?
- integra transmission help
- annoying exhaust rattle
- Should i keep my DA?
- Guage needle removal?
- b18 crankshaft?
- valve stem seals.. which ones to go with?
- Speedo Problems, checked all wiring and VSS. now im stuck....
- code p0420 help!
- 94 GSR wont start
- my new(ish) da
- skunk 2 intake manifold whistle, fixed!
- b18a into a obdII Integra
- vtec contoller
- 94 rear bumper q
- Electrical Problem: Cluster, Radio, nd cig lighter lost power & "key reminder" beep wont stop
- OBD0 ecu diagram pin outs needed
- Will an OBD1 P06 converter to P28 ECU chipped and tuned w/ ChromePro run a 2000 Integra GSR w/Jackso
- Which integra is DOHC???
- DA and DC full coilovers the same?
- Will a 99 si Iacv fir on a 01 gsr?
- Pic request of the BPI veloctiy stack with K&N Filter on a GSR.
- gsr seats
- transmission governors...
- Headlights do not retract.
- oil leak...
- Connecting Rod Question
- Aftermarket Aluminum radiator and slim fans. What do you use to mount the fans?
- Wanna rebuild my Motor....No of any good shops in Oregon
- 1991 4dr window problem
- E-brake 1994 integra
- sleeving questions
- what dizzy do i buy
- ignition switch problem
- hey does anyone know were I can buy this clamp/bracket please...
- front end shakes
- how to clean
- looking to buy a gsr/possibly ls
- Im replacing my axles
- upper control arm question
- squeaking and leak
- B20z2 head bolt torque specs and order?
- valve adjustment problem????
- seats
- pulley problem!!
- weight savings?
- Engine Light.
- Should i buy it
- Car just shut off
- question about apexi ws2 catback
- Found source of water leak, but how to fix?
- Lsvtec build motor problem
- 1990 integra b18a1 4 door worth it???
- whats a good compression ratio for a 91?
- what kinda of car do i have?
- will a b16 crank pulley fit on a b18c1?
- do pipes affect what the muffler sound like?
- Video: LS Vtec First Start up
- Brake Clicking Noise ??
- Integra owners with HKS Hi-Power exhausts.. Got pics?
- Bogging problem
- Idle problem
- 2000 integra ls fuse box diagram
- carsound cat
- Clutch Problem...Please Help!
- Smoke coming from intake
- HELP PLEASE!!!!-- limits on cylinder wall hone??
- VTEC Swap and Turbo: Question about Compression Ratio
- Will a stock 99-00 Civic EX exhaust work on a 99 LS Integra?
- totalled my 96 LS, pics
- Installing Suspension?
- Gas Smell
- B18 Swap
- Looking to pick up a Integra
- pass smog
- engine swap
- does 96 integra front leathers come with the adjuster on the side
- 93 integra ? got some question
- noob in need of help/advise
- suspension prblems! please help...
- blox LCA install...links?
- Swapping shift linkage, Am i missing anything??
- Another intake mani. question
- Sky High Idle
- apexi v-tec airflow converter II (Apexi V-AFCII)
- exhaust decision
- What rims for this integra *pic inside*
- No more integra?
- Pulling A/C
- ls/vtec
- Greddy turbo kit for '96 integra work on '95?
- replacing front end?
- shake and bake?
- Turbocharged runs harder on LS non vtec or LS Vtec??
- Coolant Line Issue
- Pic request!!! 98-01 GSR Upper interior
- Engines
- bad piston rings???how can tell??
- I'm back biiiiiii&@#$es..got me a 99 integra
- quick question about exhaust.
- Sooooo I ordered window visors..
- New tranny
- What size tire? 1990 DA
- i need information
- car stock weights?
- DC2 Recaros vs. DC5 Recaros
- Aftermarket Horn Button Install
- Need Torque mount
- p1399
- Integra LS engine takes a few minutes to shut off??!@#
- Bad lower ball joint
- tranny
- DA hood dampers?
- Catalytic Heatshield - Need to thighten.
- 98 gsr
- Axle too short?
- A few questions ambout my new valve springs
- Moisture in headlight...
- ek sides to an integ
- will a b16 oilpan fit a gsr??
- JDM header, what cat size ?
- service manuals
- Hatch Release Issue
- k20a swap
- E85
- oil in intake ports
- What size Injectors??
- CEL was cleared, can it still be there?
- Shaved engine bay hard to DIY?
- fogs for interga
- some dreams were meant to be broken......
- chance to own greg leones dc2 (famous rhd integra on mtv)
- Bpi velocity stack custom intake
- 93 integra axle questions HELP PLZ!
- I was a good samaritan today for a stranded DA owner.
- does anyone make a rear lip for a 95 db7?
- PIC Coilovers Vs. Tein Flex
- Rain+CAI = Problems Engaging VTEC
- REQUEST: fuse box cover diagram. searched.
- load resistor kit install help
- Couple questions about jdm front
- will allignment will fix a camber wear on my 92 db ?
- natural to hear oil noise burning while starting up the car?
- Y1 TRANNY...
- how do i post up pictures
- throttle body pulley
- b17 cel?
- Manual Seatbelts HELP!!!
- Fittings on the bottom of the radiator?
- Buy full coil-over kit
- 4 door rear seat mounts
- buddy club exhuast spec2,3,or 4 which would you go with? opinion?
- Difference between OBD2b and OBD2a ECU. questionable S02SG wire
- Injectors witch to go with....?
- buddy club spec 3
- Is there any differance...
- Video On Vtec
- Where can I get the best deal on a jdm hood?
- Integra 92 tail lights
- Clutch Problem
- Does anyone know the speed distribution for 94-01 GSR
- is ther a way?
- B18c1 build--- limits of cylinder wall thickness???
- DB8 License Plate Connector
- ukdm conversion?
- another abs delete question
- Grind at High RPM
- type r cams, cam gears, valvetrain.
- Cluster issue
- Help! Valvesprings
- decisions decisions...
- transmissions
- rear camber kit install
- drag dr9
- removing fender liners
- just got it
- Will I notice a difference without sound deadening in the rear?
- Stolen av1 (1st gen integra)
- WILL crx full coilovers fit on a da!?!??! NEED HELP ASAP!
- crower cams worth it ?
- Is skunk 2 meagpower illegal in ca?
- Any Integra owners with an N1 exhaust system..
- apexi n1 catback good for turbo?
- Importing from the States
- Water Pump aftermath
- blox lca's candy?
- DA exhaust help plz???
- Hesitation
- Front Blinker and Running lights
- Donny Biggs Signs Up On Honda-Tech!
- very good turbo write up! turbo build
- fs. dc2 and da integra parts
- tires rubbing inside fenders
- H.I.Ds on d.a9
- I need help
- searched..b18b1 vs b18a1 bear head comparison...pros & cons
- integar ecu code p1399
- Looking 4 Opinions: Budget GS-R Rebuild
- Compression Test: One Crank Hold or 4-6 Cranks ??
- I want to slam
- Shops That Sell Rebuilt (Salvage Title) Vehicles in the Bay Area?
- airbag SRS ECU control module
- thule roof rack question???
- radiator problems
- S2k seats in a DA
- Check Engine Light
- Axle replacement question
- Which Starter??
- arp head stud torque specs...which one?
- went 500 miles overdue on oil change
- low idel
- people who have change the vtec solenoid gasket
- cat converter question
- Alignment help
- single stage vtec?
- rear mud guard question
- need help any DIY threads.....
- wiring nightmares....please help me
- omni full coilovers
- JDM ITR HEADER REPLICA?!?!
- pix of the best teal green integras
- Integra Type R vs. Non-R side skirts: The Truth
- Interior customization
- b18a cam measurements
- any da girlz out there?
- Need the part number for a CTR pulley's belt. Anybody know ???
- Is this a decent header?
- da gauge cluster wont light up
- 1/4 mile ETA on this setup?!?!?!...
- da
- turbo on acura ls
- gsr tranny hard to get in 4th
- wheel allignment
- head question b18!
- Weird vtec problem. Please look...
- car idles high and won't drop down
- k20 or k24?
- b16 or gsr tranny for b20??
- KNOCK SENSOR COMPATIBILITY
- CEL problem, turns on while on highway and turns off after restart??
- b20 problems
- VSS interchangability
- integra LS turbo question-s
- 92-93 cluster in a 91DA rewire
- gas problem car wont start help!
