View Full Version : Acura Integra
- help decide on a vtech
- motor?!?!?!?!?
- need help to adjust valves
- Power Steering and A/c removal ?
- rsx type s motor in 99 teg??? lots of questions
- Differences in Power Steering Pumps?
- Buddy Club Spec IV Exhaust
- I'm new and have a question.
- Obd2-Obd1 Converson harness with a simple question???
- WHAT RPM DOES VTEC ENGAGE ON A P72
- Valve adjustment with aftermarket valve train????
- Hydro YS1??
- Need Help...94 integra pissing me off
- A question about compatibility of Power Steering
- more radiator problems...
- skunk2 manifold
- CEL: running Lean...
- 95 Integra Gsr: What's the average MPG you get off your tank?
- DA engine/trans swap
- Should or Should Not . Change Tranny Fluid
- replacing DC4 ignition cylinder for auto, will 5spd ignition work?
- throw out bearing
- A question about OEM Honda/Acura CD radios
- Code 2?????
- ECU
- DA head and DC head "LS"
- help!, car is shaking while driving.
- Help: Blitz BOV - Paid 170 new, but Real or Fake? Knockoffs?
- what calipers fit a da's knuckles?
- Can needing a valve adjustment affect shifting?
- how much does a 1990 to 1993 intregra weigh?
- my new axles 5 lug or not?
- Wheel bearings. Avg price to have new ones pressed in post what you expect to pay
- Maintenance Required light?
- been changing oil for years.. but this time oil dipstick questoin is fckin botherin me..
- Water temperature switch for radiator fan
- KINKED EXHAUST PICS???
- Blown motor!! Need Options?
- tokico illuminas
- Radius Rod Bushing, question :)
- Help with jutter in the steering wheel...
- 12" Front and 11.1" Rear Integra rotors
- ECU Code, anyone know what this is ?
- axle or suspension issue.. question
- upgrading intake mani/intake. question on fitment
- transmission problem
- blown headgasket (searched)
- tranny stuck in third gear
- Anyone ever try Edelbrock SDT Muffler
- B18C1 vavle springs
- Noisy Power Steering Pump? Normal?
- hand brake light stays on when cold
- crank stroke fro b18c block
- How do u Tighten the T-Belt ?
- Timing belt and Clutch being installed any words of experianced wisdom?
- are ALT wheels good?
- Mugen lip? ITR Lip?
- 95 GSR compression/distributor
- jg edlebrock headers
- b20a3 head onto a b21a1 block
- From where can I order Integra engine mounts?
- Ok I need help with a question with my 96 gsr's ecu
- 97 gsr...WHAT THE HELL SHOULD I DO?!
- 1996 Gear Position Indicator light...
- Need Lights 89 teg.
- Lowering problames
- Cable tranny: How do I pull off the pin-type linkage?
- supercharge ?
- coil over sleeves from ebay
- Ending my RHD conversion. Questions if anyone can answer them.
- wats up peeps. im new here, need sum help.
- b series maintenance
- snaping axles?2x autozone ones just in one day
- crower cams 404?
- Problems with 2000 LS
- Stroke on a b18c
- fender question
- hi im new to the site
- Type r transmission a bolt on?
- HELP! bleeding 96 Tegi brakes
- shocks
- lowering a car, your thoughts?
- Will a b18a1 head fit on a b20 long block for more ft/lbs?
- FS:LS parts
- What All-Season are you running on your tires?
- B17 or B18A1
- hondata s100
- throttle pulley on blox manifold...(searched)
- New Member and ive been looking/searching for the past 5 days :D
- need HELP!! with integra front hub
- rear bumper turning black. why? HELP!
- 92 gs-r headers
- weather
- share tire cover searcheD Help
- I need HEAD TORQUE sequence QUICK!!! 4:01 pst
- white box coilovers???
- 15's or 16's
- Throttle body
- where can i get some license plate plugs for my front bubmper?
- head serial number question.
- HELP!
- can an alternator cut off and on?
- Starter not working.
- Is 2.2 the largest stroker kit available?
- ******* QUICK QUESTION, PLEASE RESPOND! ************
- suspension install
- New Winter Tires Pull Car All Over
- Best place online to get o2 sensors for my gsr?
- i need help with my tegg shell
- ITR wheel bearing fit gsr ?
- LOOKED EVERYWHERE, need help installing JDM SIDE MARKERS on DC2
- Would we need bigger injectors?
- Are the BLOX intakes really the same as SKUNK?
- wanting to buy a lip! need help!
- k-sport coilovers
- short the battery or fuse?
- aem tru power oulley kits
- need answer quick!
- will EG6 OEM fogs fit on 94-97 tegs?
- What could be the problem?
- Questions about my Engine
- installing blitz turbo timer
- Hydrolocked? i think
- my car wont start or turn over
- need serious help! throttle problems!
- save this integra!!!!....
- Where is the 'radio' fuse in a '94 Integra? HELP!!!
- Those of you that own AUTO Integras
- WHAT MAGS FOR MY DA6
- JDM ITR cluster in 00 GSR?!?
- steering column and ignition busted!
- Will spoon calipers fit a DA
- DA Brake Caliper upgrade
- half shaft question
- Transmission
- **LS/Vtec!**
- Gsr progress 1 year later(pics)
- 1991 teg LS, Vtec swap
- xenon depot HID replacement
- Question on GSR IM/TB...Difference in 94+ and 96+
- integra 96 Gs-R exhaust Question?
- Fixed overflow boiling problem..Now car still overheats???!!
- gsr engine harness
- will b16a axles work with a 97 ls tranny??
- i want standard steering,where do i get the parts
- f/t 99 gsr
- Mirror question
- power steering
- read my spark plugs
- Recommended Clutches For a 01 GSR
- da side skirts?
- weird noise coming from shifter.
- Speedo/Odo help... neither are working.
- does blue sensor plug go on tps or map sensor??
- Entire fuel injection system question/answer
- alternator belt fitment issue
- gaskets
- need manifold
- HELP...IT WON'T STAY ON!!!
- IF i see my brake calipers getting "gold" does that mean i need wheel spacers?
- Starter bad? battery bad? clutch relay? which one can it be help
- is it normal for aftermaket injectors to make clickin sounds? or is it another problem?
- compression test result good/bad
- Trying to figure out what to do with totaled '00 GS-R
- Anyone have a gsr with a 4.7 final drive?
- car ideling poblem HELP!!!!!
- No Clutch Pressure?
- water leak!!!!!!!!
- Replace or rebuild?
- Just wanna make sure...
- Paint Job Help
- integra torque mount & bracket bolts?
- quick alternator question..
- Keep my Ls Motor or B16a?
- 3 Problems that I really need to get fixed! Help!
- Type r oil pump in LS/Vtec
- Getting new headers but don't know if it will fit what i have.
- LS Budget Performance
- Hondata S300
- cable b16a2
- looking for tuner shops around philly area/SE PA/s jersey area
- suspension problem on my dc
- dc2 oem lips?
- jdm cluster into gs
- any1 of u wanna get rid of your cf hood (scratched, chipped or dmged)?
- Rumbling noise from drivers side
- hondata question
- 1994-1997 GSR RIMS question
- changed the rad and still leaking???
- which lcas?
- DA Front Windows
- A guess of hp #'s with my new mods (bolt on's) in my GSR
- Is there any way to replace the knuckle from an jdm itr 5 lug?
- Help Me Decide
- Tests
- is clutch fluid the same as brake fluid? ? ?
- automatic LS
- Better car protection
- Clicking/knocking noise HELP!!
- 92-95 civic spindles the same as 94-01 integra spindles
- Please Help ASAP. GSR transmission identifiaction *well searched already*
- If I changs my intake manifold(96gsr) will I have to change my cold air intake
- Race Bushings for GSR
- Very bored...decided to mess around with the cluster...warning....bored
- How does one identify a fake/authentic Mugen shift knob?
- Where should I put my tach???
- ground wires?
- spoiler holes
- front body kit conv.
- Have you ever heard of a company called "HAD"?
- grinding third please please help
- Wheel knock??
- Production Numbers GS-R
- Type R Cams
- FRIEND CAR GOT STOLEN IN SO CAL
- Coolant temp sensor causing bad gas mileage???????
- type r spoiler or factory or no spoiler. need some opinions
- Nitto NT01 225/45/r15?
- Where to get 60mm cluster gauge pod?
- What kind of throttle body is this???
- Charging System Question. Alternator & Battery Related (1994 Acura Integra RS Auto)
- taking the gsr out
- Where can i find?....
- My car died and now it won't start.
- intake manifold question
- honda integra '89' model is it worth doing up the motor?
- 94 accord LX for a Integra
- koni red
- im having troubles with starting my integra ls 1989 model..
- hks axleback on skunk2 exhaust?
- TYPE R WING ON MY GSR......HOW TO COVER REVEELING HOLES???
- timing belt help
- PICS REQUEST PLEASE PRETTY PLEASE 00 GSR WITH RED SWIRLESS
- installing visors?????????
- b18c intake manifold ?
- the difference between s80 & y80 tranny?...
- eg into da
- k20 swap on 97 integra?
- Thread Pitch on Caliper
- Axle popped out of my B16 LSD tranny please help
- How to tune itb w/ crome
- Integra Interior colors
- siezing calipers!!!
- JUST GOT RID OF MY SYSTEM, AND NOW I JUST WANT GOOD SPEAKERS, HELP ME DECIDE.
- door jamb sticker
- possibly going to the track....
- Crankshaft Size
- Has anyone here used Vibrant Performance mufflers?
- GSR motor
- Anyone gutted their cat-converter?
