View Full Version : Acura Integra
- took the 4 door to the track for the frist time
- shift boot falling in
- lets talk ls/vtec!!!
- camber kits
- ABS Light Stays on , JDM cluster
- Camber Problem need help ASAP
- Integra Engines
- 97 GSR rims
- wtt cf clear tails for you all reds (4DR)
- Should i buy?
- ECU for b20z2 non-vtec
- car bogs when vtec engages...
- ITR Sway Bar
- How can I tell the difference between JDM ITr front brakes and +97 up Prelude???
- Stereo Installation??
- Stripped bolt, Gator Grip... GOOD? BAD? HELP!
- Does anyone make 2.5in cat-back for the 4 door GSR??
- pulleys
- ls clutch not fully disengaging
- anyone know where i can get a comptech sport exhaust cheap?
- H&R Race / Koni Yellow question
- installing b&m fuel pressure regulator what psi
- Shifter help installation...
- Anyone Have teg 1995 LS/GS/RS Valve Cover?
- ls and gsr clutch differences
- Glow guages for 2nd Gen Integra
- 1/4 mile times for 91 Integra RS
- what is done at 80k mile service check?
- cheapest place to buy iceman cold air
- new integra guy here
- zc 1.6 crank
- was wondering about vafc......
- wondering if aem pulleys are worth doing
- J's vs. APEX'i N1 or GT-SPEC
- Whining Noise: Accelerating in first
- pacesetter exhaust?
- will a Type R style spoiler fit a DA?
- attn: GSR skunk2 IM owners... ecu question.
- Hi everyone
- How much "reliable" power can be made from a b16a1?
- Buying used gsr tranny. How do I know if its a gsr?
- where should i go for a paint job
- weird noise at 6k rpms in a ls
- questions about ecu wiring
- 94 teg lip????????
- Type R muffler?
- VAFC II throttle opening settings
- help, i need to know the fuses on the engine bay.
- ITR sway bar question
- catalytic converter
- hey everyone.... just introducing myself
- TuRbO LS questions
- had the Skunk2 shifter and ES bushings installed yesterday (TONNES OF PLAY)......
- Can you lower an Integra that are on 17s?
- skunk 2 manifold questions
- what to do to the ls
- LS Turbo
- pr4 pinout....
- replica headers
- light rims
- cat back
- Which sway bar?
- toda headers, wasup with them which headers are good
- I need a pic of 94-7 fogs from behind in bumper
- problem after fitting skunk2 IM
- i am getting sooo tired of this
- wanting to boost
- 96-00 Civic Koni Reds - Will they fit?
- WTB or trade.
- Sprayed water in my GSR Stock Muffler and now its like stuck in there!!! help
- Rims 17s or upgrade suspension first?
- what tranny is best.
- LSVTEC Question's
- Crazy Video.... RWD Integra
- my car is leaning out
- Results from DIY projects
- quit question RSR ExMag Catbacks
- custom piping? muffler? cat?header?
- Acura Legend seat in a 4 door(DB1) integra?
- best e.t in a four door integra?
- gsr headers
- i need a decent suspension
- recommend suspension? Tein-basic coilover vs. Ground control/KYB?
- SPARK PLUG on my 94 LS keeps popping off!!!
- Championship White color code?
- pulling codes from 91 integra
- What Flywheel should I get for NA GS-R?
- Recommendations for quality exhausts?
- jdm p72 ecu
- Pipe Diameter on Thermal Exhaust for the GSR, N/A????
- mass oil consumption lastnight.
- Top Fuel vs. J's Intake
- i really need help w/slipping clutch!
- need help!?
- Mugen MF8
- Damn Thieves
- rotors???
- running with no oil
- Vtec System Malfunction
- need some help....hit a curb....steering isn't right....tried searching.....
- JDM Front end conversion, Headlight/Foglight question
- From 310cc injectors to stock
- should i turbo my car?
- turbo kit
- help
- How much power should I make
- best drivetrain setup....
- catalytic converter choices
- Gsr Fuel pressure.
- wheres the best deal on a clutch masters st 4 and act prolite
- my heatshield came off. what to do?
- how to tell difference between skunk2 IM and b16/type R IM
- SIR JDM 1996 Integra > recommended Octane ??
- Gas prices and mileage
- Bought New Tires, Yokohama AVS ES100, discussion inside
- 99 Integra GSR window sticker
- what are the best shocks for neuspeed race springs on 4 door gsr
- A big F*CK YOU to tire shops
- VAFC help...
- My hood won't open. i need help
- Energy Suspension Bushing Set Compatability
- bushings
- arghhh teggy won't start
- Clutch master cyl. install
- Experiences with Tanabe Sustec Strut Tower Bar
- gsr motor in g2: throttle cable?
- Brake fluid overflow
- AEM V2 or comptech icebox
- Can you remove side moldings?
- Idle problem!!
- problem with my steering wheel
- 94 gsr front and rear sway bars on a 2000 civic ex?
- quick gc fitment question
- will 88-91 prelude OEM wheels fit?
- Hose thingy you remove when adjusting fuel pressure.
- best to pull this motor
- o2 censor location
- List your set up on your 97-01 gsr
- rattling noise
- should i get this gsr?
- need fuse number
- Does anyone know how to remove the heater control on a 91 Teg?
- Why do the hardcore FWD cars have wheelie bars?
- What to do next? Hmmm (Pictures) 56K Warning (3Pics)
- best shocks for neuspeed race springs
- 92 GSR!!! any idea?
- quick question
- fuel pressure
- What to do if its seazed?
- has oneone used the drag launch kit from Eibach ?
- 4D and 2D exhaust Question
- killa Cams
- I exp. understeer for the 1st time last night
- tubo
- Mugen wing knock off theory
- im sick of domestic cars
- help...
- NO bypass valve on CAI
- Basic Teg Question
- Insurance in Delaware
- TEG problem.
- '01 GSR - new rear brakes in 10k miles?
- teg won't start :c(
- Header ???
- So I'm driving my GSR and I hear a loud POP... help ;P 2 CEL's.
- best rotors? type/brand?
- Anyone know where to get a bare B18A1 block?
- Shaking through body during acceleration...Please Help!!!!
- OIL filter wont come off!!!!
- (CT Local) Port and polish needed
- Can someone run a carfax for me?
- Bad Tranny?
- kyb agx dial replacement
- skunk2 intake manifold and couple other questions.
- Do you think this is a good deal on a gsr?
- another no spark...
- ***Golden Eagle vs. STR cam seal plug - which one doesn't leak***
- its probably right under my nose HELP????
- Installing sidemarkers...
- Idle problems
- Difference between LS intake manifold and GSR manifold...
- carsound cat question
- Opinion about Turbo Kit
- 91 LS PREASURE PLATE! IS IT DIFFERENT??
- WTB or WTT for GSR blades!
- new exaust system
- Header Qwerstion
- Broken Header stud...how to get out
- Shops near LA to install my ITR front end.
- twin loop exhaust
- 90-93 Aftermarket Radiator Choices...Fluidyne, Koyo, C&R?
- NUT STUCK ON HEADER STUD.. HOW TO TAKE OFF??
- Whats involved to put a B18c1 in a 91 Integra
- Hood latch cable
- New Best Track Times!!
- 2 inch collector/2.5 inch collector..Oh no!!!
- noise between 3000 and 4000 rpms?
- where to get p28 ecu chipped with stock ITR program
- Anyone know hot to install a Greddy EBC?
- Greddy SP2
- remove abs
- radiator question.
- Is the hrdro b16 differential the same as LS/GS/Rs tranny?
- Car fax?
- price of rim
- valve seals?
- will a 98 tranny fit into a 90 integra?
- Yes/No - Will aftermarket 96-00 Civic front and rear strut bars fit 94-01 Tegs? EOM
- Momo seat question
- toyo roki oil filters
- Acura 4 to 5 lug conversion
- injectors
- Weight
- SPOON PARTS FOR SALE
- porblems after fitting a skunk2 IM
- Ground control or tein
- gsr intake manifold
- running rich
- JDM Power folding mirrors
- Differenec in LS heads?
- compression for LS short block
- Bay Area Looking for a hood and fender
- turbo gs-r
- black thing on 96 + gsr manifold but not on 94+95
- Pipping size
- exhaust size question
- New to Hondas
- Best turbo kit for a 00 GSR
- COLD AIR INTAKE??????
- H22 Mounts on 92-93 Integra
- Looking for a 94 B18C parts fiche
- A general Questiong........ plz answer........
- Is this suppose make this sound?
- WTB factory super sonic blue pearl rear bumper for 99 DC2
- 95 gsr longblock into 98 gsr
- SAFC for RC 550 injectors
- can someone tell me what's wrong with my ABS system?
- Venom 400 Control Unit
- AIRMASS HEADERS?
- help in need of some shocks!!!!
- 97 Gsr Cluster VS 01 Gsr Cluster.
- need some help from you guys - can you identify this cam (GSR?)
- SWhats the difference in all the GSR's?
- REAL gsr cams? <pix>
- so i bent my rim today...
- Which gasket set to get for my jdm sir1 b16
- Installing a VAFC?
- WTT: my Greddy SP2 rear section for your Apexi N1
- How much can I get for a 00 GSR swap with about 50k miles
