View Full Version : Acura Integra
- leaking compression from cyl 2 to cyl 1??
- 1990 Acura integra help
- Are Koni yellows (sport) gas shocks? Also help with issue
- Main Relay Question
- Timing belt broke, need advice
- Shifter wiggles L to R in gear as if in neutral.
- need help from any one about.going turbo. on this set up i just got
- I jinxed it...spark plug blown!
- Acura idle bouncing?
- 92 integra engine and dash harness
- Integra cylinder 3 misfire
- CAPA Certified Fender
- Knock Sensor Troubles
- GSR crank damaged, what are my options?
- Intakes, Throttle bodies and more air
- 1996 integra rs will crank but not start
- Thermostat: Aside from OE, what's a reputable brand?
- P0505 Engine code on 1998 GSR
- Gen 1 Mugen Spoiler/ DA9 Hiro Spoiler
- 1998 gsr oil leak *pics*
- ASAP help please??? I need my car by tomorrow!
- timing
- ABS Light on in rain, 5 Lug Conversion 98 LS
- Parts that will fit DA chassis
- 94 integra shuts off under acceleration
- She wont start
- RS-R ExMag Gasket size?
- Turning Signal issue
- 00 GSR shell b16 motor I need help
- 1994 GSR MAJOR Overheating problem
- Need advice on what size exhaust to run on my supercharged LS
- Smoking POS!
- map sensor wiring, LS
- Spring install/swap issue w/kyb agx.
- Wet exhaust ports
- will a bumper fit inside the car?
- is this why my heater doesnt blow air ?
- Flywheel worth keeping?
- DA9 K-Swap
- Code 23 knock sensor help
- my messy bAy
- Taurus Cupholders with pics DA
- Acura Integra fuel injector ohm spec,
- performance shocks/springs
- Distributor and starting troubleshooting, 1993 Integra LS,
- D16A1 87 integra LS transmission problem HELP!?!
- 95 RS teg autotranny problem.
- Integra LSVtec Build idea, help needed
- tranny swapped now cant start
- How to: Bringing a little curb appeal to your honda
- obd1,obd2 GSR/b20 intake manifold sensors
- POWER STEERING LEAK!
- Wire Identification
- 98 integra ls, starter doesnt spin, power to everything
- B20 Valve COVER ?
- Engine ???
- 94 Integra (automatic) starting issues
- Remove head fittings
- Interior color
- PCV valve. OEM or Aftermarket?
- Help with this wire?
- CV Axle knock at 20 mph...or is it?
- 90 sedan with b20b
- Is my A/C compressor seized/dead?
- CD PLAYER WONT TURN ON / WIRING help
- 25psi Oil pressure cold? Gsr oil pump HELP!
- 90 integra obd1 conversion rough idle bogs and stutters under 4k
- NEED HELP PLZZZZZ 94 Integra RS Wiring
- 92 gsr question (videos)
- JDM front, PWJDM headlight harness
- Rear Seat Removal
- 95 integra LS random running issue
- hard start after car gets up to temp
- STP Injector Cleaner Review.
- Oil pan
- Car shakes at 60mph+ after axel replacemant.
- Civic eg outer tie rod fit on 94+ integra rack?
- 99 Integ with b16a2 swap issue
- EG Hatch/95 GSR Swap/CEL Trouble Shooting
- transmission question for DAs
- alternator brush assembly replace
- 91DA Sway bar end links from Energy Suspension
- b16a 1st gen head on b20b4 in obd2 teg
- Supercharger
- b18b1 is having trouble starting
- 1994 integra worth buying?
- 01 gsr w/ b20b4 idle problems
- gsr issue
- Ls-vtec wont start with obd1 ecu
- RPMs Jumping
- Help ! what just happened to my axel oil everywhere+ripped boot >pics<
- Apexi ws2 piping with DC sports muffler?
- Gen 3 integra fuel injectors the same for Gen 2 integras?
- KYB AGX's w/H&R springs. lopsided ride...
- power steerning delete question(s) on GS-R
- intake cam for my b20b
- Top of Cylinder Chipped. Ok to rebuild???
- HELP!!! Transmission problems on 99 GSR
- What kind of rims are these?
- Replacing front right brake hard line question
- Replaced bad clutch master cylinder, car wont start!
- Moog 94-97 upper control arm vs. 98+
- Hey guys! My 2000 LS is running hot!
- car door handles integra help
- tranny leak issues!
- Da Integra ls-v build not starting.
- Need answer ASAP - Teg typeR diff damage
- spark plugs
- Compression and leakdown numbersSssSsss....
- b20v help!
- 91 DA At freeway speeds, car sways like boat
- B18a pcv box question
- turn signls work hazards do not?
- Trunk issue!!
- Fully built GSR turbo, stock mani no iab question
- da color help
- What did you do to your teg today?
- Which year TB is this???
- 5 lug conversion issue
- Spare tire size for 99 gsr?
- Stupid Noob Hood Question
- Thief mangled door handle and lock, easy to replace?
- difference in hp between '90 and '95 integra
- Block gouged during Head Removal, Help.
- 90 Integra GS, ac problems.
- Acura Integra GSR 1997 all motor build questions.. please help(:
- TPS voltage help
- im new from MD THIS IS MY PROJECT
- Water won't circulate in my radiator 91 Integra
- PIC Coilovers
- instrument cluster not working
- new TeG
- telling the difference between a 1990 and 1991 Integra?
- Tein S. Tech springs review
- Valve cover gasket all the same? For vtec b series
- 1990 Integra help
- 97 integra help plaease
- twin sequential turbo gsr?
- Replacement Fenders from StylinTrucks.com only $43?!
- Tach needle goes crazy after 4K rpm's ! car runs fine.
- drove through a puddle
- How Does Coolant Flow?
- gsr pistons in ls
- Flickering Battery Light - Video Inside - 1995 Integra LS
- Need help. 10mm caliper brake hose nut is rounded
- HELP poormans type R NO VTEC
- Problems with AC, cooking hot!
- HELP!!! Car drives like crap!
- Over revved b18c1 and wont start
- cannot shift while driving
- Car wont go, looking for stock oem air box intake
- Oil pressure switch wiring question
- ITR OEM Front Lip Championship White Used Mint Cond. Price Check?
- Compression test results and Mod ideas
- what the hell did this person do lol
- Buying new suspension for a normal integer dc5 2002
- Tryna get a dc4
- 1990 integra code 17
- Cluster not working at all ! tried new one.
- fuel rail ???
- Tight! 95 ls brake line popped
- Virgin GSR exhaust upgrades
- Fuel injector Q
- Mildly built gsr goes in "limp" mode help
- 94-97 USDM fog light switch
- Strange 98-01 question
- will i need to change my ecu
- I'm new here, I have some problems with my teggy.
- Help me ASAP (Jk) Considering a K swapped 93 GS-R
- spit and sputter
- Acura Integra LS 1995
- hood release cable
- Engine mount problem(driver side).
- Clean B20v FTW daily/race
- Integra gsr rpm gauge problem .
- My db8 build (itr rhd conversion)
- Jdm front headlight switch problem
- CEL P302 and P1399
- fully advanced ignition timing, pros cons ?
- need vtec help
- OIL(non synth) cheapest vs top shelf. VTEC Engines
- A/C switch as a Kill Switch?
- need help please :/
- AP1 cluster for DB8
- b18a1 starting problem
- My clutch doesn't grab as well anymore..
- Chaos Build
- Procharger installed, 2 questions
- brake problem
- Please help me identify this exhaust manifold (LS, GSR or ITR?)
- DA9: correct motor mounts for B18B1 swap
- Cel code 8 1995 gsr
- How to switch idle to 2K+ on demand?
- warped flywheel?
- GSR burning oil, New rings, 2 slightly bent valves
- B18b1 timing belt snapped
- Top hats with tower bar?
- Fuel Pump issue
- b16 head on b20 block
- Oil burning after rebuild what do you think
- NOOB question!
- What is this worth
- Clutch slipping
- GSR idle emissions FAILED
- exhaust?
- Motor mounts???
- Gen2 Integra leaking power steering from rusted metal line
- Dented header, when will it start to affect performance.
- Looking at integra things to look for?
- HELPPP!!!
- 95 gsr ignition timing problems
- Pr8 head on ls b18
- Is this "mugen" spoiler legit?
- acura integra 2001- side molding
- 5 lug question
- B18 Engine Mount BOLTS
- cel turns on after driving for 2 hours
- AT lock up clutch manual control installation.
- Integra Idle Issue.
- My built and boosted GSR daily
- 98+ conversion questions
- B18c Map Sensor voltage needed
- Found a 93 GSR Roller..
- skunk2 intake swap issues
- mystery nipple.obd1 gsr
- Warm Idle Issue.
- HELP! Distributor, Timing idk.
- Gsr Motor, Coolant getting into the oil
- shutting down problem
- CAR WONT TURN ON AT ALL PLEASE HELP!!!
- oil chart photo
- Stock 95 GSR (ISSUE)
- throttle cable help
- PatrickGSR94's broken@$$ Integra fix-it thread!
- Is this really OEM from Ebay? New to Ebay. Trailer arm bushings
- Wiper and antenna block off plug part #'s. searched
- IDLE ISSUES! GSR swapped civic - blox intake manifold, Omni Throttle Body and new TPS
- Question about half radiators for Integra
- Cable clutch and hydraulic cluch question
- Ground control's with KYB AGX's ? G3 teg.
- Wire Harness help
- 94 LS Ignition Switch
- my gsr is sputtering only when i stomp on the thottle?
- Manual Transmission Fluid Really Dark
- NOOB question
- Which ECU to use
- b20 with k20 head?
- Stupid starter question (ramble)
- Oil smell
- 2000 integra distrubtor trouble
