View Full Version : Acura Integra
- DIY LS/VTEC KIT
- gsr intake manifold compatible with b18a1 ls???
- quick question about head swap
- Sounds like a subaru and cuts fuel @ 3K RPM or so NO CEL
- Reverse Not gripping DB1
- Doing an LS/VTEC
- how can i post on marketplace to sell my parts?
- option racing spark plugs?? pulstar spark plugs??
- b18c IAC & IAT
- quick help question
- Need help in Nor Cal!
- Weird idle issues
- how can i get better gas mileage
- DA power steering hookup
- JDM type r ecu
- 94 tail lights on a 95
- pulley?
- DA brake light blowing fuse
- DA Seat belt stopped working?
- any one ever had trouble removing the axle from the halfshaft?
- is the GSR oil strainer diff. than LS strainer, oil pan differences and all. changing oil pump
- k2 motor?
- chipping JDM P72?
- jdm itr 5lugz suspension (36mm) with axles...PLEASE HELP!!!
- ignition advance ?
- CKF help.
- Going to the Dyno, some maintenance
- Hondata S300 will not link!!!
- Help identifying these 3 wires *pics 18 year old harneess FTL
- 90' Acura Integra Right Blinker
- Please help with sunroof diag......
- Vtec Crossover when cruising.
- obd2a vs. obd2b
- HONDATA INTAKE MANIFOLD GASKET
- brakes lock up after 15 min of driving
- Cluster? Is this right?
- Another LS/VTEC Help Me Thread.
- Loud Tick and clanging
- idle problems
- ACURA INTEGRA TALLIGHT CONVERSION...HELP!!!
- AEM V2
- crank pulley issue?!?!
- Rear Caliper Piston/Rubber Boot
- 93 LS Integra Head Torque Specs
- need help!!!!!
- how to tell what cams i got???
- Stock Radio issue
- help integra stoped on me
- standard to Automatic
- leaking eng. oil
- error 24 ecu code?
- Locking Cam Gears For timing??!!
- cams in b18 or b16 head?
- clutch grabbing mad quick.. someone help.. or school me on why its ok lol
- b18 to b20b
- 95 Integra slow cranking starter and if start, won't start again... Help.. thanks
- Buying a GS-R
- Buying GSR: what is a good price range
- gsr wiring harness guestion
- Hub Centric Rings Help!?!?!?!
- 89 TEG b18 SWAP help
- Tach problem
- LS/VTEC vs. B20/Vtec
- Where Can I Find JDM Conversion!!!!
- B20/VTEC TURBO
- D series starter on a B series block?
- DA windows
- star design on my gsr head b18c1..gotta question
- anyone know how to remove the immobilizer
- New ecu,but wont start
- What needs to be replaced when...?
- DC Sports DAC Intake
- "2 stage" VTEC questions
- Rear hatch hydralics don't hold up.
- No Vtec HELP
- need help: power antenna
- Anyone know where the Mugen Intake DIY is?
- OBX racing DA9 cat-backs
- 215/40-16
- Tokico shocks
- sea foam?
- Need Advice!! What Now!!
- Does anyone know what this connector do???
- BAR QUESTION: EVAP Sensor (diagram needed)
- no fan?
- Headlights Help
- Coolant mixing with Oil, Need help!!!
- squeaky tranny release or pilot bearing?
- TuRBO JiZZER...
- what cams do you recomend for low CR
- Honda Drivers
- another possible GSR owner with some questions lol
- car won't start, weak spark, replaced dizzy
- Auto/Manual Clusters
- auto to manual questions
- 01 GSR Considering OBD2 to OBD1 switch advantages?? Input?? Tech help??
- Pic Request: GSR Head Gasket
- jdm vtec pressure switch bypass!
- building my b18c1 block, what do i need?
- Cable clutch pedal issues
- need some help on rust
- Help failed smog due to high HC and my timing was retarded!
- Stock GSR safe redline
- Driver side window replacement for DC2???
- ITR immobilizer....
- gotta love the newbies in the world of honda....
- New to the DA world.....
- Serious tranny/clutch problem!! need help fast!
- STARTING ISSUE NEED HELP ASAP!!!!
- question on the new db8 ls
- pic of installed electronic exhaust cutoff
- Affordable clutch replacement in So Cal
- compression test results for a 1995LS
- difficulty level of ls engine
- Painting Inner Spokes on GSR Blades
- gapping platinum sparkplugs
- what kinds of exhausts are on your DA
- tps problem
- 89 octane in 98 gsr.. anyone know if this is a problem?
- Help!! integra with a b16 problem
- crankshaft question 01 gsr
- 88-91 Civic suspension & lca on 90-93 teg
- buddy club vtec controller obd2???
- Gsr Motor Doesnt Redline Pass 6900
- auto to manual conversion
- Intermediate shaft question?
- first time swappers! and i'm not talking about spit
- New build - B18B/Sleeved/Complete Rebuild - Overheating issue
- DC cluster in a DA need help!!
- gsr block question??
- gsr tranny on an ls
- windshield wiper problem
- How to remove seatbelt
- Alright fine Ill look into getting a auto to manual swap.
- Emissions legal OBD2 tuning solutions
- Quick Question..
- will this pass smog in ca
- were to put manual trans fluid??
- trying this out soon [=
- Which engine damper: NRG vs Ingall?
- Whats the name of this gasket??
- b20 vtec help
- camber kit or not?
- Parts for 89' Integra?
- can somebody banned me or lock me out??
- JDM b18c Swap into 94 GSR...HELP ASAP...
- how low can you drop an integra? suspension questions
- Valve adjustments done and rough idle...stalls
- Need advise??Is this a decent deal?
- When is this going to stop?
- burning oil and blowing smoke
- car accident :(
- Quick question: 5w-30 or 10w-30?
- Bleeding front brakes only?
- Manual transmission replacement gears available?
- stock jdm b18b intake manifold inlet size??
- engine is boggging....
- 94 gsr trans problems
- Part # ?
- 91 integra help
- fix-it ticket greddy sp2
- Power Steering belt problem
- Down Pipes
- my integra
- Kevlar lip for '98+ USDM front
- MEGAN RACING 4-1 COLLECTOR FLANGE ISSUE? GSR 2.5" HEADER - PICS INSIDE
- boost on a stock LS
- Can anyone tell me what line goes here?
- questions about turbocharging
- 01 Teg GSR w/ LS VTEC swap Car has a miss please help!!!!
- suspension noise
- B18C1 Smoking and Exhaust Smell
- baffle needed for LS/VTEC block?
- Car shuts off while stopping..
- rear seat problem
- bike rack fits on integra?
- ITR head, gsr block turbo build. wiring question.
- JDM B18C = No ECT sensor ??
- low rumble when starting off from 1st // clutch feels like its rumbling when cruising
- 93 integra help!!!!!
- brakes!!!
- Anybody heard of a JDM Integra having TCS?
- manual to auto
- LS OIL PAN ON GSR BLOCK?
- 3rd Time someone Tried to Jack me but Failed....but left damage
- 2nd gen integra lip kits
- high idle, early redline WTF
- JUST COP A GSR. vtec issue.
- Attention StatRacing
- ****What steering rack do I use from going to p/s to manual
- Skunk2 IM HELP
- wire tuck / bay shave on da6. NEED HELP WITH A FEW THINGS
- CTR pulley and belt size
- picture request!
- gsr oil cooler hex nut size
- intake manifold ?
- noob here wit a da
- Please any suggestions would be great! ECU problems
- 94 acura integra speedometer problem
- need help
- AC condenser question!
- B18b1 - is this an OBD1 or OBD2 motor?
- da integra for sale
- Type R Oil pump and water pump on a LS. Timing Belt?
- Installing stock springs back in car.. 95 teg
- Speed sensor and VTEC
- tEh TeArDoWn!!!
- ls-v problem
- Two questions bout DA with a B16.
- CV boots repacement
- ???????????? b16 s1 tranny ???????????
- speedometer not working after engine swap
- What's wrong?
- cruise control switch/horn
- so cal only TEST FIT
- Climate Control *need assistance*
- Stripped threads on b18c block
- Overheating in the HOT
- What kind of rear Brakes?
- e-brake sticking
- do you get a more accurate fuel pressure reading at the rail or filter?
- how much boost can my b18b1 injectors take
- Possible New GSR Owner!! Questions!!
- Is this what i need or what else do i need?
- Hatch Release 99 GSR
- USDM Radiator Support
- AK1 MOTORSPORTS FAIL
- car bogs, replace wireset/spark plugs
- Will a 94 LS DC Header fit onto a 00 GSR?
- DC2 tuck, shave and overhaul // lots of pics warning
- Integra seat adjustment?
- Weird crackling noise
- 1992 Acura Integra GS 1/4 Mile Time
- Fuel pressure spikes
- help me out plz
- waht steering wheel is this?
- side moldings shaved price for two door?
- Help What is this? It broke in my Engine
- gsr alternator on b16
- custom color carpet pictures
- 91 integra GS gauge cluster removal NEED HELP
- h.i.d high beams.....
- built gsr questions
- CAR IS TOO LOW? HELP
- Yonaka Exhaust
- engine problems and i need to go racing on wednesday
- 92 acura integra foglights
- Noob Question, What is..
- Driver's Low Beam Not Working, Help!
- DC2- Finding the perfect offset?
