View Full Version : Acura Integra
- new meet in ca
- code 31??
- >> Your WINTER TIP of the month! << TIRE PRESSURE
- weird noise, need help bad.
- b16a in 92 ls
- keeping integras safe, what can u do? this is mad.....
- Finding a cheap dc2
- h&r vs. neuspeed
- machine shop ass. my block/do it myself
- I need code for stock radio... what do I do
- brake bleeding questions?
- is there anyway to fix this.......
- >> Quick (faster) ratio steering rack <<
- nooB
- shocks vs. struts
- Cam Gears
- G2 & G3 gause cluster wiring diagrams
- Header install
- Going to look at a type r head today, have Q's about what to look for.......
- Installing ITR Wing
- Holley Throttle Body Applications
- Exedy clutch opinion on a DA..
- Cam Seals???
- Bumper/Oil Cooler Support Needed?
- Strut Question.....
- 120,500 Miles on supercharged gsr...run nitrous=safe? or not safe?
- Greddy Header?
- FI vs. NA...WW3
- jackson racing super charger
- Type R clutch??!!
- will this armrest fit an integra?
- This can't be good.
- What brake will fit on my 98 teg?
- Increasing HP with less than $500 bucks?
- SUPERCHARGING SYSTEMS: Vortech
- PowerBan
- Gauge pics
- Question + Pic Request: Possibly buying a DA G2 Integra
- my car did the weirdest thing today
- Comp. test results...GSR, CP 9:1 OS pistons..need opinions
- what are the locations for your grounding kit
- Can someone please explain my idle problem?
- good vendors to buy head/block internals
- my friends drunk ass dad
- can i fit an 1994-2000 gsr or ls dash in my 1992 acura integra ls?
- Alright... another ? about surging idle
- type R pistons on ebay.
- car using up oil
- wtb: 98-01 passenger headlight and bumper (green if possible...aftermarket bumpers ok too)
- integra ls engine
- anyone know the specs for the jdm b18b?
- real quick body kit question
- '95 GSR Header/Exhaust ?
- compression question
- Best bang for buck: rear or front sway bar?
- value of my car...
- STR intake manifold
- CARFAX please!!!
- extended wheel threads
- differences between LS/ITR catalytic converter?
- Tire Help!
- autometer a/f guage, what does yours do???
- stock oil cooler?
- vis coilovers any good???
- Hood...
- need ecu help FAST
- Super Charger or Turbo??
- Groupbuycenter and turbo evolution inc question, please look.
- changing brakes. do i need to replace some sort of bearing?
- HELP Air/Fuel Guage
- Gsr Mesh Wheels
- AWD tegs
- how do u post pics
- can an intercooler be used as a radiator? how can i beef up my radiator
- group buy itr lips
- Anyone know where this goes?
- jdm or not
- stock or skunk2 manifold?
- Who has a hydro tranny in their DA? - search = zero result!
- Two different LS mesh rims??
- Use cruise control switch as fog light switch?
- Pro Charger or VORTECH???
- Mobile one 5w-30 vs 15w50 in an Ls
- 4wd integra???
- gsr head options
- Need help on skunk stage1's
- car wont start, should i get a new battery?
- b17 gs-r
- whats the difference between JDM SiR-G front and JDM ITR front?
- Apex'i JDM Header Pictures Inside With Measurements
- Are Toyo RA-1 a bad idea for the street?
- Pics requst: I need pics of a stock engine rebuild (b18b)
- HELP...user rating dropped...
- lots of stolen tegs
- Ground Control Question
- How to tell a JDM from a USDM?
- Piston sizing
- Tires: Kumho ECSTA Supra 712 vs Bridgestone Bridgestone Potenza RE950
- Fix for torn rubber molding around window...
- removed rocker arms without labeling
- motor mount inserts?
- What should i do...
- Surging idle.... WTF
- swapping a 97 GSR engine into a 94 Integra LS
- Two things ...white smoke and brown water...WTF??!?!!?!?
- autometer air/fuel
- good thing to get from Japan?
- help need opinions on a car
- little help here!
- Brake Light In Cold Weather....?
- Leave tranny in the car when engine removed..yes or no?
- exhaust comparing....
- Header Q's
- taking out A/C and PS
- shifter is hard to move in a 90 ls automatic.. HELP
- Help! oil burning !!!(searched)
- Greddy EVO vs. Apexi N1
- How can you tell if
- integra shocks whick ones
- To buy this or not to buy this?
- Is my compression to low?
- Compression checked my LS before i run some mad nawz on it y0
- making a vtech??
- Bellevue, Washington
- How to adjust timing to help pass smog?
- Evotion Springs
- integra healdights different?? 94-97 and 98-01
- question about struts
- half shaft nuts???
- burning oil??? help!
- What does this pully do?
- 94 ls or newer teg???
- swapping motor help!!
- Heh, guy tried to rip me on cams - good thing for H-T
- jdm front with hood locks
- Tire Wear Bar Indicator.
- Integra stolen @ Mason In Virginia!! Damn Thieves!!
- ECU reset?
- testing spark
- stolen integra at mason, NOVA
- Video of my integra
- Oil filters all the same?
- my 90 teg wont pass ca smog
- '97 GSR STOLEN!!!
- quick question?
- BSCAN Packing Material
- have a question whether or not its worth buying back 1994 integra after accident
- +4's or regular spark plugs?
- Is this how a starter dies?
- Is there any difference between the Comptech/WW lip, and the actual OEM lip?
- how much to rebuild bottom end
- you know your a ricer if.....
- Are all 94-01 Brake Pads the same?
- engine swap in the bay area
- apexi N1???
- 96 teg ls/rs obd 1 or 2?
- fake j's intake?
- ITR Rear seat in a DA?
- Air Fuel Ratio Guage install?
- Suspension on my DA TEG
- need help building b18c1 on budget
- my car pisses me off!!
- grounding kit = bad alternator
- Car just died, will crank but wont turn over, WHAT IS WRONG!
- where to buy oem clutch cheap?
- fuel tank question and i already search...
- SPW industries??? Is this who makes the mass produced(aka "fake") JDM cams and other parts?
- driver side AXLE
- website request
- 94 oem kit question...
- Need help can't apss smog.......
- just put an OBD II motor into my 95 GSR and lost my Cruise control, can it be fixed?
- o2 sensor question
- is this common with a skunk 2 IM??
- cheap springs
- 96 SPec ITR Wheels
- b18c1 head on b17 block
- anyone with APEXi WS coilovers??
- rear pillar bar
- about to pull engine, oil pump needed?
- first time car owner here! need help
- cams??
- Spark plugs?
- Cheapest full aluminium radiator
- wtb: bike roof rack, yakima or thule
- BAH!!! battery light cant mean anything good...
- cheapest place to buy fuel injectors?
- Ground Control Coilovers
- Need Help Ls Motors, knock knock
- how heavy???
- Replacing fuel filter
- Honda Cams
- 94 gsr w/120k miles.. what do u guys think?
- 4 lug space to 5
- Changing rear glass
- question for all integra gurus.....
- Question about o2 sensors on 2001 gsr.
- nooB question about tegs
- JUN 3's
- radiator busted wide open on the freeway and it was raining green coolant
- Weird car behavior
- anti-seize on spark plug threads or no?
- My homemade trunk bar.
- Need help with rebuilt motor: won't turn with conrods torqued
- speedo question
- Freakin Problem
- b18c1 problem
- Place Racing
- My 4dr GSR got hit in my driveway (pics)
- OEM Type-R lip
- fake or real ctr cams? link inside
- can someone tell me what coilovers these are?
- ECU Options for Ls/Vtec
- 1994 GSR and up parts
- Opinions on whether this car is worth going to look at?
- ** New toys. NO 56k ***
- Interest? IM gasket superior to Hondata's
- San Francisco Bay Area Heads please help me out!
- car won't start...
- b16 build up
- how do u put stock oil cooler on ls motor
- P61 Ecu question
- PICs of OEM Acura rims?
- ITR cams in a GSR
- Can someone run a carfax for me...
- b18b into 93 integra?
- just lowered the car and need alignment
- Alternator question, Please Help!
- N00b question about GSR
- Cel code 73
- gs-r having a type r oem bumper
- advanti s112?
- Quick Q: Which UK integras had four round headlights?
- part number for JDM Integra air bag tray
- B16a in a DA....
- Prices on AGX Struts
- Ideas on rebuilding
- greddy Ti exhaust
- tranmissions
- Exhaust question.. ITR/aftermarket - looking into getting exhaust
- Intake manifold question....
- Red suspension sport Lowering shocks anyone heard of these?
- 99 integra V-TEC b18c1
- Which would you get on a budget? ACT HDSS or Exedy Organic?
- H&R Sports and Cut Bumpstops!!!!
- coil-overs on 95 RS?
- nooB
- 2nd gen linkage in a 3rd gen?
- funny idle
- 170k miles check up.
