View Full Version : Acura Integra
- NYC: Found a Stolen Integra
- what is this part!? someone help!
- need part numbers...
- looking to turbo 1992 acura integra ls anyne know were to find manifold that allows a/c
- Will B16 header fit on B18B
- Eibach Springs
- Motor Mount Symptoms?
- why cant a jdm engine pass smog in cali
- LS/RS Integra with 130k worth? to much?
- door poppers for shaved doors questions
- Is this out there?
- Check this out!!!
- Strut Bars Mugen or ITR
- Please help
- WHICH SPRiNGS
- question about 94-95 integra fuse box
- Code 22 intermittant, help
- muffler shop won't cooperate!
- CarFax help -- Please run a VIN.
- Spark plug gap!
- ITR sway w/BSQ kit rubs abs bracket...
- Supercharging a 150,000 mile GS-R........
- STOLEN GS SEDAN turbo in Minnesota - please read
- instructions on how to bleed the brake system
- quick exhaust Q
- Test Pipe ?'s
- need to know asap! difference between catback lengths....
- B or C piller bar?
- Rear brake caliper help...
- foil and 2nd o2 sensor
- H22a into a GSR Integra
- 52 Rear VTEC Pressure Switch P1259 VTEC System Malfunction, Rear Bank (Bank 1)
- Need sum 'back-seat' help :\
- teg owners in: NOVA, MD, WV
- 1/4 mile time what should it be
- the cost of GSR internals
- going to get my first gsr can someone run a carfax please?
- HELP! car wont start ...
- 94 DC2 or 92 EG6?
- Civic Seats -> Integra
- I was gonna adjust the coils and I see this...
- Clicking When going straight
- How Fast Am I Going?
- Valve Cover question
- would a GSR fuel injectors help
- some question about rev limiter - does it exist?
- 1/4 inch of water on my floor!
- flowmaster mufflers
- quick 02 sensor question
- How to replace your alternator without taking off your axle
- Zex Nitrous and 1/4 mile time
- I'm a trial user. Could someone post this for me?
- Crank pulley problem....
- new rotors and brakes
- Custom Exhaust tubing questions
- anyone ever run an open header and have this happen??
- front lower tie bars
- Anyone w/ 2000 Helms supplement, i need HELP.
- momo steering.... horn.... how?
- how long does it take to change oil pan?
- Need help with S2000 seats?
- Icebox install questions
- engine swap for GSR???
- Apexi dunk for 4 door GSR
- my 1st vid..
- My car's been stolen!! and found! sort of...
- which lip is lower?
- i need help real bad...
- 90-93 integra & 94+ integra suspension interchangeable?
- Headlight Brightness Fluctuates up and down
- Start problem
- illuminas/skunk2 setup
- GC coilover and upper mount review
- will a ctr steering wheel (with airbag) fit on a integra?
- B18c1 in a 91 DA Integra
- Where to buy timing belt and water pump
- Kamikaze header questions
- quick question, LS throttlebody on a skunk 2 b16 intake manifold.
- brake pad replacement How to???
- i have a question?? does anybody know?....
- Anyone ever hear of Stromung Exhaust?
- bad IACV?
- Car died, some kind of alternator/electrical problem
- GSR Integra boosted 12.3 on street tires....
- 89 integra performance parts
- gauge cluster light went out!
- Pulling?
- GS-R vs, Type R.....my conclusions
- more power..?
- found some 94-97 type R Lips for cheap but.......
- tein springs!
- dc sports header??
- Integra ABS problems..
- Which exhaust is good
- How much brake fluid needed for complete system flush ?
- What is the best fuel injection cleaner?
- where is my nut
- Hidden Leak....
- grinding going into 5th gear
- building my motor need some imput
- 215/45/16 falken AZENIS fitment?
- will 99 teg doors fit on 97 ??
- Tire/Rim Size + Rubbing?
- drilling holes in high-flow cat?
- please heLp
- safc settings
- DA Roll Cage
- Help! Anyone installed a NOSzle setup?
- i need clutch options for street driven turbo b18c1
- look whats in my car now!! 56k careful!
- Thermoswitch woes?!
- What Tire Size, and Tire.
- those of you w/ crower 403's or 404's
- Quicker Tranny For GSR/C5 motor Options/Ideas/budgeting
- Importance of rubber fins on radiator?
- Thinking of all-motor..
- Help!!...I think my engine's blown
- please someone with helms
- How do I remove speedo needle..or reset mileage, or both!
- Whistling under the hood, please help.
- Energy Suspension Bushing Kit Install, How Hard, How Much Time?
- throwing a CEL code 7 and 14, what can fix this?
- brakes wearing unevenly
- Custom DC2 Harness bar/rollbar Anyone want one?
- Damaged Fender - AGAIN!
- Best Overall After-market Manufacturer?
- stock cat...
- Funny Bog or sputter?
- What handles better, springs or coilovers? Should i switch?
- New to Integras, I'd like to find some info
- skunk2 v. ground control coilovers?
- How the hell do i remove the 02 (oxygen sensor)??????
- Apexi header- anyone using it?
- JDM B18c
- Need your opinions on this car? Is this a deal or not?
- Well, not sure what's causing this.....
- had the revs real high, and now car is real violent when shifting at higher RPM
- vibrating in engine bay driving me NUTS!!!!
- Thinking of 92-93 LS/GS... best upgrades for the money.
- gsr emblems/ tire size
- Battery relocation setup?
- integra for sale
- Where to mount VAFC?
- Any1 with a GSR turbo...help me out a lil bit!
- Ready for your TypeR lips? Here's how you install them.
- Apex RS exhaust???
- Best exhaust for 90 Integra
- Stock B20 Dyno Chart
- well i'm a newb
- what oil grade to use after rebuilding engine..
- just put an edelbrock intake mani on gsr huge idle problems/surges PLEASE HELP!
- what should i do with my ecu???
- what ecu is in a 01 gsr??
- 94 LS cat on 99 ITR exuast
- DOT3 or DOT4?
- Help needed to decide which one is better deal.
- master cylinder plastic bleeding plugs suck!!!!
- removing door molding ???
- Integra G3 Stock height
- radiator cap problem please help!
- brakes making bad noises
- ITR brake booster/master cylinder for GSR. compatible?
- Consequences of changing steering wheel
- how much HP can stock B18b piston and crankshaft handle
- Changing Dash in my Integra....
- Anyone ever change front wheel bearing on 96 rs?
- Now do you understand my title?
- stock momo steering wheel???
- good place to buy internals...
- LS VTEC!!!!
- Going on road trip (430 miles)
- will a b16a header fit a b18c1
- integra suck
- is it possible for me to break 12's?
- got home today and look what i found!
- new!!
- i tryed search...need help!
- Opinions on this N/A setup...
- darton sleeves ?
- AEM CAI + Skunk2 SS review
- weired smell after using AC
- will a 98Ls catback fit on an 95Ls???
- Recent Dyno
- 89-93 integra rs
- Window problem
- How much would you pay for this car?
- Just got a Apexi Dunk...
- adjusting tokico illuminas
- itr gauge faces
- Tenzo-r big brake kit
- flywheel?
- widest tires on 7" rims?
- Might get an integra, please help!
- Spark plug help
- help!!! would 98 gsr brake or suspension fit 96 civic coupe??? help!!!!
- changing tranny fluid on my gsr ASAP
- 92 integra with 94-95 b18c longblock can i pass the state ref ? help?
- Help me, before I go kamikazee on this screw!!!
- spark plug wires...sounds like a noobie question i know
- what motor is this ecu for, jdm or u.s.??? its weird and throws a coolant code??
- Quick question...HELP!
- How to completely flush out coolant?
- MSD CAP
- Spring Rates
- Pulling apart the dash
- Anyone use this ecu tuner?
- Is $ 200 a good price for CTR pistons and rings?
- landspeed racing cat
- Cylinder pressure loss!!!
- just picked up some illuminas
- type r come in black?
- cars knockin and i got no idea
- Moderator Question - I do not have permission
- master brake cylinder question
- OK to machine CTR pistons for LS rods??
- skunk2 camshafts
- getting rid of shitty APC suspension...need help!!!
- Upgrading tires...whats a good brand?
- how do you post photos?
- Mesh Front Bumper Grills for 98+ Integras
- glue for fabric on the seats
- Just installed JG intake on 00GSR ... now idles high. Help please
- overheating..any thoughts?
- VTEC oil cooler on LS
- LS Valve Lash
- HELP !!! 95 GS-R..tailights don't work !!
- I got my car back!!
- used autometer tech~RPM's is off??
- Help!!! Leaking Coolant
- Your opinion on a local dealership's fees...
- Quick (but urgent) Brake Question
- b18c1 v-tec problem
- intake manifold gasket
- question before buying: is $400 a good price for jdm itr header with upper heatshield?
- abs dynamics carbon fiber
- gsr blades
- yo planning to get a swap b4 the end of this monht..
- Turbo question for neewbie
- Newbie
- k&n drop in filter...
- Misfiring code 16 HELP!! bad ecu?? wiring?? need help w/ my teg!!!!!
- Skunk2 shifters
- Help with header gasket
- third brake like wiring question
- Vibration when car is at complete stop
- How Much is a new Head Gasket
- so exactly how much does your wheel weight effect your 1/4 time?
- Seats. Sparco, Corbeau
- Your experience with clutch brands!!! need help
- Need Help!!!!
