View Full Version : Acura Integra
- LS/vtec? is it worth it?
- what do you think its worth??????? need help
- drag races near L.A.?
- lsvtec with pr3 pistons and b16 head with only 100 miles $1200
- advance timing????
- good all season tires for integra stock rims
- any DIY sites for making obd2 to obd1 conversion harnesses or cheap places to buy?
- Philips Ultinon 6000K kit VS. 4300K kit...
- What brakes to buy???ASAP
- Clutch adjustment
- building head for big boost or nos
- East Coast Meet!
- what is a reasonable drop.
- PSI for 17s?
- Would these skunk 2 parts fit my motor??
- Dyno Tuned today!! hehe...
- Radio Antenna
- smog in ca
- Need help with a couple things.
- Charcoal canister help!?
- Overheating!
- Front sway bar size
- CTR pistons in a B18c1
- Will 215/45/16 Azenis (on 16*7 Slipstreams) fit a 94 RS
- Maintenance Required Light - how do I turn it off?
- Clutch??
- how do you remove driver and passenger ac vent?
- What exactly is knock and ping?
- All motor/street legal
- Air conditioning craziness
- Alliement
- Pro's and Con's of Ls/Vtec
- Parts cars for gen 3 Teg???
- fix it ticket
- Hey guys, I wanna know sumthing?
- crack in radiator
- info when snapping an axle / cv joint
- 2.5 or 3 Ton Jack for Integra?
- a bunch of questions that i really need help with? PLEASE HELP
- question about check engine light?
- ##Who has a low price on a Fluidyne radiator for a 1994 Integra GSR?
- Pardon my ignorance
- Painting a valve cover on a integra and the side moldings????
- Stuck bolts on rear LCA
- Question on Stock Fuel Preasure
- LS/VTEC, what kind of pistons for a B18A1
- Cams Super Charger or Turbo
- What Type of Engine Is In The Integra Ls
- Where do you guys mount your alarm sirens at? i got stuff all over the place
- Gsr Synchros
- Headlight aiming...clockwise=up or down??
- Will S-AFC correct my rich idle caused by cams?
- H&R sport springs with stock or KYB AGX shocks...
- gsr motor. help!!
- A/C PSI spec for refrigerant..
- Quick Question About The Integra
- Removing side moldings
- new cars for me
- aerospeed front mount intercooler
- AEM CAI or Comptech IceBox?
- Coolant overflow tank problems
- A/C not blowing very cold
- LS/Vtec or new GSR block
- Good shops in North Jersey for suspension work?
- Wanna know why the integra craps out on top end?
- pressure switch code 22
- V-AFC Tuning tips and/or good sites?
- help with brakes quick!!!!!!!
- Sat, July 27 North East Meet!!!
- how do i check fluid level for tranny.. b18b?
- About the Skunk 2 coilvers
- Anyone running NOS in their LS?
- OBX SS headers any good?
- center console expansion holes - usage model?
- Cheapest Brake Upgrade on 95 GS-R?
- Cam Seal Problem: A Change in OEM Design?
- bilding a b20 or ls crank for vtec
- Rear brakes
- self locking nuts> best place to buy
- Coolant flush probs need help!!
- what kinda of pulley and short shifter should i get
- Automatic Integra theft deterrant maybe ?
- CARS NEEDED for dyno testing! NJ/NY Area.
- 94 RS
- steam carpet cleaner on interior/seats?
- How to fix rear window washer
- 94+ springs on 90-93 teg?
- Changing brakepads -- Is bleeding necessary?
- racinh harnesses
- Rear Upper Strut Bar; Coupe = Sedan
- b18 head removal
- ference is CTR cams
- Skunk2 Throttle cable bracket part2.... pic intensive
- damn damn damn. I hate engine noises... helP?!
- Ok... one moment of your time.. what clutch do you use? comments optional
- Tanabe Sustec front lower tie-bar
- 9006 to 9005 headlight conversion.
- ITR Side skirt
- does anyone know what a tdc sensor does?
- field sfc-vtec, your thoughts
- cam install gone bad....HELP
- What do they do in an engine rebuild?
- Spark plug wires
- **Fram SureDRAIN - Anyone try it out yet? - drain your oil with no tools**
- Swapping seats with ITR
- R1 "Intercooler style" intake
- Mitchell on demand Factory service shop manuals covers 1983-2000 integra
- Removing Power Steering and A/C?
- Distributor differences on OBD-1 and OBD-2 GSR motors?
- Need to learn
- JDM 91' Integra Xsi pics (right hand drive)
- Squeeqy brakes
- K&N or comptech drop-in filter???
- Soft Clutch Pedal
- Car overheated, need help :(
- where to get itr LCa's
- Lookin to autocross
- 5zigen Fireball Exhaust
- would an LS bezel fit in a GSR and work properly?
- question on comptech icebox
- Is the vtec crossover too low
- 90-93 integra fuse box.............
- icebox ?
- Did I burn a valve ?
- Timing belt & water pump costs??
- GSR Tranny ?
- 2nd gear burn out
- this a good price?
- Help - How do I flush R-12 out of my A/C system (Acura Integre 1992 GS)
- NEW Suspension Techniques Rear Swaybar/Tiebar Combo
- Will it rub?? offset+42 4X100 17X7.5
- Who was the best lookin Teg on the Board
- Rear Camber Washer question...(did search)
- i'm new and need advice
- Engine problem
- posting for a friend....Ls/Vtec problem
- cv boot questions
- What will my HP#'s be with this future setup....
- Help me analyse my dyno plot - JDM B16a G2 Integra
- Which would be a better car for a all motor build up Rs or a Ls?
- <-----SAFC PROBLEM! HELP PLZ!----->
- does CRX springs fit in a G3 teg and vice versa...
- tapping sound in engine under acceleration need ideas
- Don't yell at me but i have another ground control vs. skunk2 coilover question
- integra gsr carfax
- OK im gonna try again! New Member!!!!! Dont Leg Hump Me!!
- Shifting the Automatic (revisited i guess)
- New GURL member signing in
- Bypass valve
- What effect will adding 60 lbs have on the performance of my car?
- Fuel Pressure gauge on Fuel filter?
- help, seats don't fit
- i need a few stock parts....
- ecu chip
- Do you suggest energy suspension bushings?
- Signficance of shifting speed?
- Gapping Spark Plugs on SC'ed gsr?
- Cut Bilstein Bumpstops with H&R Sport Springs?
- anybody have their Air Fuel Ratio for a running 13psi on a b18b
- can someone measure their center console for me?
- Just had A/C recharge &.....
- integra ls special edition
- Koni Reds
- can a 2001 type r block bolt with 94 gsr head??
- Alot questions on correct parts for my tune up.
- Where's the sticky index thread- GSRBoost?
- Teg exhaust question
- Getting Toda Spec A's, Can I use this without valvetrain replacement if I stay at stock redline
- Whats the gap for NGK BKR6E-11 copper plugs (for gsr)??
- Ground Control Tokico Illumna's
- Just finished a rebuild
- Acura Parts?
- those of you with beat in the trunk
- ITR Muffler
- Pics of the C-West kit on any integra 94-up
- I have good luck!
- Old Review of GS-R - get pissed and laugh too....
- Wheel weight for 94 RS (14" steel wheel)
- It's been just over a year....
- camber Kit/Discount tire centers = (
- Trans question again...
- All motor question
- Cruise and Forum
- ls tranny on gs-r engine?
- Procedure to charge ac???
- et for b18c5 equipped 4 dr
- Skunk2 coilover sleeve same as Groundcontrol coilover sleeve?
- My Hazards don't work
- Gsr Cluster help!!?
- full vtec conversion, gude head, good deal?
- question on cat-back...
- where are the oil squirtes?
- kyb agx same for all integras?
- i disconnected from the header
- Resurface Flywheel required??
- I want the sound and power of the mighty TURBO
- AEM CAI 1pcs or 2pcs?
- Couple of questions for you Teg gurus...
- Electronic Fuel pressure guage
- clutch/transmission question
- apexi n1 exhaust
- about to take my gsr in for some warranty...tips???
- help with LCA bolt...
- LS Sunroof in RS, anyone?
- do i need this?
- Is the sir-g guage cluster real jdm
- ticket advise
- Clock went dead
- ???Tire Rubbing???
- anyone know lots about speeding tickets?????????
- Clutch pedal too high?
- are these chips any good?
- ITR Rear Swaybar On Backorder From American Honda
- ? for jdm conversion owners
- I have a carfax account
- Can someone run this vin via Carfax
- how did you get rid of that vacuum line?
- Brake question
- where can i purchase helms?
- Valeo Clutch??? Opinions?
- ls/vtec problems...
- Keeping Secondaries Open
- Air Filters on Performance CAI??
- My bodyshop guy Kicks ass....
- B20B questions.
- Quick Tire Q>>>
- highest psi level for daily/street driven teg?
- How to take headlights off 90-93
- My intake makes no noise?!?!
- dyno charts
- Cluster pinouts...
- Tranny swap
- oem body kit
- working w/ fiberglass
- Squeeky...
- Can an LS rev up to 8k rpm???
- want to put in magnetic drain plug/OK to drain and re-use oil?
- Is it still possible to get 'NEW' teg eingines from acura/honda or other importer?
- missed factory scheduled maintenance
- Blocked - Rear window washer - Help!
- How do you install JDM 4-1 ITR header on 94-99 GS-R? Custom cat?
- MIDWEST Chicago Honda-tech meet!@
- Help my vtec doesn't work
- disconnect from the headers
- Timing belt help, not a new n00b question, pleae assist
- Skunk2 IM question..
- Anyone with a Venom 400 on a GSR
- is the GSR redline 8000 or 8100?
- how to make the antenna not go up when radio is on..
