View Full Version : Acura Integra
- Throttle Body trouble
- Integra radiator hoses
- Code 45 On........Then...............Off Again??
- Quick question on fitment of tokico shocks from a 99 civic SI to a 94 Integra LS
- Those with green 94-01 Integras
- 00-01 Type R header on 00 GSR...?
- opinions on msd.......?
- Skunk2 intake manifold GSR....???
- what model integra do i want??
- What do I need to shave one full second off.............
- Gas/Clutch Pedal feels weird...need help please.
- Roll Call- Who here has a 4door GSR
- Does anyone use KYB GR-2's???
- Gas Mileage??
- New toys! Kosei K1 v700, what psi to use?
- PIRELLI P7000 vs. YOKO A520
- I want to get a manual
- rear strut bar - notice a difference in chassis stiffness?
- Did I get screwed
- ran over a median when turning
- How to make the gsr strut tower bar fit with the skunk2 itm
- Could my fuel pump be the problem?
- why does the SI have a single stage IM?
- Tokico Shocks question
- The classic A pipe rattle!
- How often to tune-up?
- One problem after installing ITR rear swaybar.
- i want your headrests
- Squeaking from the rear of my 95 teg.
- Dunlop SP5000s vs Kumho Ecsta 712s
- Integra LS motor. IB "killer" block, with a turbo. 10 PSI and 5 PSI charts.
- Vortech Supercharger?
- Stock GSR Shocks, what's the limit?
- why is the SI so loud in VTEC?
- gsr and b16 pre-vtec cam specs
- 2.5" b-piping
- does acura still make side skirts
- Biggest injectors on stock ls motor?
- i need a vin check
- What clutch would you recommend???
- busted lug
- Valves
- Power loss with AEM short ram intake...
- medium grade cam gears, not too cheap not to expensive. Any opinions would help.
- having trouble deciding on what year to get.
- To fellows who has TEIN HR~~
- where is the cheapest place i can get a decent ls tranny?
- ls questions....
- tenzo r rally seats??? where do i find em cheap?
- b18b mods
- Clutch Opinion
- Energy Suspension Shift Bushings???
- Help!!! Can't shift into gear...
- short ram vs. cai (whp difference)
- manual tranny swap question
- Anyone using stock shocks/struts with their lowering springs?
- gutted rear of car - holy poo it's loud!
- want to run low 13's high 12's NA
- California Speedway tommorow + Rain = ?
- JDM ITR Red-Stitched Shift and Ebrake Boots !!! GREAT STUFF!!
- Eibach Sportline?
- Good/cheap suspension combo?
- You figure a company that can make over 100 HP/L...
- Release Bearings
- Clock and Radio not working after ECU reset...
- protecting Koni adjusting tabs?
- exedy clutch?
- Brake help needed! Caliper doesn't fit over new pads
- Quick Question
- Kumho Ecsta?
- GSR fuel pressure..
- Oil and Water pumps- Vtec vs. LS
- My project
- GSR CRANK price?
- is it safe to use used Prelude rotors re-drilled to fit Integra?
- My car dropped on H&R OE Sports with Koni Yellows.
- Throttle body spacer?
- coolant overflow
- I have a pair of targa rs seats and might keep them but...
- Clutch Install Question: Nachi Release Bearing in ACT Clutch Kit
- Koni shock, broken :angry:
- Woohoo....I picked up my Rota Subzero's today!
- Ls Vtec vs Gsr Turbo
- Which suspension mod will give me more benefit?
- Help: brake caliper bolt
- Is there a site like this .....
- does the integra RS and LS have the same engine???
- Show me pics of your lowered Integra...
- Which DC 4-2-1 header....1-piece or 2-piece???
- FYI - Some used stuff for sale
- Which suspension setup is best for my intended use?? please help
- front and rear strut bar and short shifter question ?
- Rear Bumper Removal - NEED HELP NOW!!!
- SCCA racers and other people who know about suspension
- how much for a port and polish job?
- Racing Hart Centercaps! the plastic tool.. need advise quick
- Ground Control Install???
- anyone have comptech springs on their GSR?
- NJ/NY/PA HONDA/ACura MEET MARCH 9
- Header??? What to Get???
- Hey all, funny how things come full circle...(and request for sedan pics)
- will my 2 and 1/4 exhaust piping on my 00 gs be able to be bolted up to my friends 95 ls integra
- Valve Adjustment
- Header on b18b
- My VAFC Install
- Did the 98-01 GSR came auto & without spoiler?
- DAMN DENTWIZARD!!!!
- Pistons, GSR and compression ratio
- my 9006 bulbs are dirty, how do I clean them?
- Members from Chicago, can you recommend a reputable place to do suspension installation work?
- Noise just when motor is cold and putting pull on motor?
- OEM Body Kit
- '96 GSR Won't Start
- Carlsbad raceway, Need Info !
- Today's Dyno plot for '96 GSR I/IM/H/E
- 88 crx hf/92 integra gs ??????
- some lights are out in my new car....need help
- I am intrested in changing my transmission fluids form my 96 gsr, but i need help!!
- Acura Integra 1993 H22a mounts
- will a Comptech middle pipe (after cat) bolt onto a axleback 5zigen fireball
- pistons to use w/jun3s
- Question about JUN cams, (not the usual)
- vtec in reverse
- is it Ok to buy used calipers?
- Another Koni shock question
- Bolt ons
- Skunk2 IM Made for Integra B18B1 LS/RS/GS will it fit a GSR B18C1 ???
- i need some help
- Need a price on ls crankshaft....
- Best cam for stock redline
- Rear Wiper Removal parts
- what would you guys recommend??
- For those with Skunk2 intake manifold
- what are some of the timeslips for you LS turbo's vs. GSR turbo's???
- Does anybody have the H&R coilover kit?
- Koni/Ground Control problem!!
- did leak down test found this please help.
- ***How do you Install a MSD external coil distributor Cap??***
- Hows the ride with Skunk2 coil overs?
- 95 GSR Turbo
- whitch one would you pick????
- Advantages of Putting an SI Tranny in a GS-R????
- what the hell is wrong with my horn
- Maitenence light blinking
- Venom intake Manifold
- Should I request metal valve stems...
- Field's Hyper R
- Koni Reds?
- 3M Adhesive Primer???
- Weird.. How come my car won't start??..
- How to make a GSR handle like an ITR?
- Best internet salvage yards?
- 225/40/16 - To Wide?
- best bang for your buck a/m clutch
- question about civic type R cams...
- Tire Pressure?
- difference between 90-91 and 92-93 distributer
- Quick Oil Pressure gauge questions...
- Is there any diffrence between JDM ITR & CTR catback exhaust ?
- 14" SSR wheels on a GSR?
- greddy headers ? ya or no ?
- what door panels will fit on a 94 GSR?
- Crower cam specs
- Attn. LS turbo cam Pro's
- '94 GSR with '97 prelude motor transplant
- Question about clutches??
- Powerlock...
- What kind of springs is everybody using
- Are these fuel injectors any good?
- JDM Header>2.25 Carsound cat>60 mm Tanabe Super Hyper
- E-mail to Neuspeed: SofSport Spring Rate Inquiry
- B & G Coilovers??
- Anybody know the diameter in mm of stock GSR front swaybar?
- recommendations for 90 teg Exhaust System
- Fixed Head and guess what
- are ls linkage from 92 tegs the same as the ones from a 94+???
- Look what Fedex dropped off
- Spring/shock diassembly question
- Got my Konis, but all is not well :-(
- Where can a buy the Autometer Full Pillar for my TEG?
- Engine Building
- Im having problems getting my rear brake pads on(hurry it is getting dark)
- WTB: 94-97 frost white integra front bumper, fenders and hood
- Installation and Fitment of KYB AGXs & H&R OE Springs...
- wipers acting weird
- OT but could use some help for tomorrow
- anyone experience Bosch products?
- New AEM Computer? Will it work with my setup?
- 3 angle valve job?
- t3/t25/14b g2 setup
- Neuspeed or DC front strut bar for 94Integra gsr?
- Wanted: 94+GSR water oulet housing, Bay Area.
- What should I do?
- 30,000 mile tune up
- Splash guard hanging
- Best chip for an LS
- anyone know of any good AE86 hachi roku toyota corolla GTS message boards???
- Help with Apex VAFC controller.
- ctr piston work in b18b?
- Quick ????????
- Valve Adjustment Needed?
- Valve Adjustment???
- Idle Fluctuating
- lsvtec vs. turbo... prices?
- Where to sell used Integra body panels, doors?
- tire wear
- Car keeps Cranking?
- NEW Integra Type R Lost Motion- ITR JDM Cams What is this? Needed?
- Door vapor barrier
- Difference between GSR and JDM ITR Head Gasket?
- Skunk2 exhaust
- 94-up b18 NOn-VTEC,,, where can i get one?
- need VIN search on GSR please. Need help negociating price.
- improper cam install?
- What is Helms address?
- OEM Kit
- Will a 90-93 Integra stock rear sway bar fit my 93 del sol S
- 93 integ and 94+ integ
- camber kit install easy?
- Drag Races - Sacramento
- Heater problem...
- Anyone elses passenger side seat making clicking noise when...
- What are the best shocks on the market?
- wanted b18c1 short block running or not
- Strut tower bar ???????
- Fitting a 4 dr exhaust onto a 2 dr
- How do you install a water temp gauge sensor?
- Good Deal?? ITR Suspension bars...
- Integra LS Valve cover question
- need some info on a h22 into a teg
- anyone w/ bridgestone potenza re950?
- trying to get some info on a P75 reprogram ECU.....anyone?????
- Sucking up water (Hydrolocking)
- FS: Rota Circut 8's in bronze w/ tires *MINT*
- MPH ?'s on GS-R tranny??
- Type R header
- cams possible with ls/vtec
- ne1 blow their phillips hid bulbs?
- Please i need YOUR help
- What brake pads do you recommend for street use?
- GSR IM on a B18B
- O/T Tired of reading about people getting scammed! Damn!
- LS/VTEC People
- Quiet exhaust advice.
- Dyno Day in NYC Feb 16 this Saturday ...
- What should I buy??
- Uh..stupid me...broke off a piece of the area that connects the bleeder bolt
- DC header with stock exhaust??
- Which one of these shocks is the passenger side *pic*
- my car has gone into shock...
