View Full Version : Acura Integra
- 92 acura Integra not running right
- Dizzy question
- anybody know if this siR-g steering wheel is rare or easy to get
- HOW TO: Charging your A/C air conditioner conditioning system at home. (crosslink)
- wut kinda oil should i used for turbo ?
- groaning/clunking front brakes
- Hard starting in hot weather, no engine codes.
- Bogging at around 2000 rpm...???
- cr-vtec
- engine swap
- 1/8th Mile?
- Question about cams..
- Spark plug gap
- popping noise in reverse
- My Champ White Teggy
- Could Some One Measure A DC2 side skirt???
- need help mounting my intercooler pics inside
- someone help me please, intake manifold doesn't fit!!
- PasswordJDM strut bar question
- 2000 GSR header question.
- GSR with ACT clutch, LS cable tranny, no engaging
- JDM itr header....real or not? differences in years?
- switch to synthetic?
- 2 or 3 bend short shifter?
- Timing Belt problems?
- stock USDM ITR header vs. stock GSR header
- Integra GSR Problems...
- Darton Sleeves?????
- DA sucking up gas, gettin less than 10 miles per gallon
- smoking
- harness "?"
- wheel options
- header fitment question....
- carbon fiber gauge bezels
- DA drivers side turn signal stuck
- odd noise at 4k rpm
- 98-01 Front lips
- Gauge Cluster
- Recharging my Air Conditioning??? 96' Integra
- suspension help
- Will DA integra axles work on my Dc.?? ive searched and found nothing
- pick which rims
- Gs-r please help
- Window tint %
- I NEED A 92-93 INTEGRA
- I broke something but I'm not sure the part number (Stud/Bolt) for the valve cover
- GSR cam upgrades 14 sec slips?
- JDM Window Visors install
- Oil pump location?? CODE 54-Crank Speed Sensor Where is this sensor??
- 450cc injector basemap
- DB8 C-Pillar Bars
- b18c1 vtec problem
- Integra Stuff
- removing window seals
- any advice on installing a front sway???
- What needs to be changed to use a ob2 dash harness in a 95 obd1 auto integra?? i need info asap!!!!!
- b18a1 and b18b1 oil pan question, need help
- speedo not working
- Your thoughts on this...
- WHAT SHOULD I DO?
- wierd problem with taillights
- Anyone have there exhaust where the resonator is?
- Interior questions
- Drivers side front Brake Sticking. wried problem
- Gready 4-1 vs. 4-2-1
- 2000 front end
- Car running strange...
- 'HELP' question on my ECU
- removing brake booster
- fan switch
- help car making bubling/poping sound
- DA horn not working
- Looking to do a JDM DC2 conversion on a 1995 GSR
- LOOKING FOR BLACK 1995 INTEGRA GSR INTERIOR PARTS
- riding on dif size wheels
- Car is riding slanted...?
- mounting slim fans?
- Im looking for a DIY on removing a b18c1 block from my gsr
- need help lug studs
- Phearable vs. Kenji ECU
- ecu
- B20 head on a B16
- Engine Mount Bushing Inserts
- 4 door seat swap into 2 door?
- new cylinder head?
- da sideskirts
- Sway Bars
- Integra GSR Question
- Does anybody have a pic of a spoon header so that i can see the Decal
- B18a1 header
- DA Pics.....
- skunk2 or blox racing intake manifold?
- WTF?? Every spark plug tube full of water!!!!!!!!!!! JDM B16A swap
- Clear Coat flaking & fading
- Tuned Hondata
- Supersonic Blue Integra Wallpaper
- valve adjustment help
- TURBO GSR
- B18a1 Throttle body size?
- Radiator
- anyone with TSUDO HEADER?
- 98+ Fender linings different?
- 5th gear grind; Synchromesh?
- axleback exhaust gsr fitment
- looked in the FAQ..diffrence between these models? RS,LS,and GSR?
- Interested in a DA...
- P75-A04 LS ecu
- question on my recent belt install
- Fuel Pump Relay Location
- axle popping out
- Header bolt just came out of block, Should I????
- My engine light keeps turning on!!!WTH?
- wiring gauge face???
- bad headgasket?
- Part Numbers for Bumper bolts
- Need help fixing 88 Integra
- exhaust question
- Anyone want a pair of FM901s
- radiator fan shroud left side
- Integra LS GSR JDM swap emissions
- One quick Q'S
- Random missfire?
- Tranny Help Please
- ***720 hp S2000.......Fuk american muscle!!! READ THIS***
- Can Someone supply some part numbers for me?
- Relocating oil filter?
- How much for a stock GSR exhaust?
- Port/Polishing Head?
- Question about 93 integra tranny Real quick
- how can i tell if my inner tie rods are bad?
- Anyone have a picture's of assembling transmission b18b, differential!!!!
- Upgraded Radiator
- kyb agx with skunk2 coil
- 05 civic si seats fit in integra
- Spark Plug/Timing Problem!!
- post integra drag times
- quaife doesnt fit in a jdm b18c tranny what are my options
- Slips into gear?!
- Intake Manifold problem
- What is it that supports the axle in the transmission?
- horn and flashers not working???
- NEED HELP ASAP!!!
- AVID axles any good?
- 94 LS and 2000 civic SI same axles?
- Weird Right Side Problem
- Will a 98 integra ls 5spd cluster plug up into a 95 auto integra.
- Searched already but still undecided???
- help why is my da losing coolant
- Keyless Entry
- DA Integra people...I need your help with the fuse diagram
- Outer Cv Boot change
- car resets/wont turn on
- milling/decking and how much it changes timing????...
- Need radiator fan motor replacement
- 16x7 tires with 40 offset rubbing OEM muffler?
- DA Drag Times
- AC Belt
- check engine codes
- There appears to be a ring on one of my rotors...a groove...
- Help-Brake pads won't fit on driver side rear...
- Question about Vision Type MC Mirror lenses...
- problem, please help
- Integra and acceleration question.
- High pitched humm...please help
- coolant leak from my radiator
- Just got my first car: a 1991 Integra RS
- Vibration at 60mph+
- possibly burning oil due to thin oil?
- whats going on need help?
- throttle body question
- Integra Overheating? after 30 mins?
- Project integra front
- camshaft prob
- Coating Apexi WS Catback
- New Mexico, Albuquerque smoke regulations
- how do you remove the crank timming gear
- Is the MC the only cause for the brake pedal not holding pressure?
- mugen replica pix for 94 teg
- Auto tranny cable/linkage removal
- a 90 da for a 93 vtec lude??????help.....
- Need Help on Integra Wiring Harness (headlight, Fan, Horn)
- blown headgasket? bogging? GSR w/jrsc
- jdm b18 idel problems
- exospeed any good
- Studdering and won't start
- There's a hose underneath the map sensor. Where does it go?
- "name that connector!"
- Coilovers!!!!Help ASAP
- I need location of fuel pump relay on 94 gsr or wiring diagram
- need help please!!!!
- 1989 teg has no springs in the front?
- Noob
- 5 lug DA9?
- Cooling fan problem
- intake whistle?
- intercooler ?
- Tranny Trouble?
- Rear brake piston keeps spinning...
- help...tail light harness
- what goes here?
- sputtering
- hood clearance solutions? pic request
- Noisy Throwout Bearing - Replace asap? Can it wait? Urgent?
- integra gurus please HELP!!!
- mph needle jumping
- Which one is the relay for the ac?
- Who has had their
- Quick Qustion. Looking for a car with some ray volks
- Is my car legal?
- Bumper lenses
- 1991 integra door trigger wire. which one theres 3
- Clanking coming from underneath my DC2.....please help!!!
- Integra Halfshaft Needed ASAP!!!
- Swap Problem..NEED HELP!!
- Shifter Bushing
- valve adjustment ?
- Is it Ok to get the (auto) transmission fluid change for a 1993 integra LS
- Friends Car Has Unknown Intake Manifold...
- 98 integra in dash fuse box diagram
- Water on floorboard
- Is this a gsr tranny?
- da alarm install, 2 questions
- Test pip Qestion
- Shifter Boot Change
- GPS Tracking for your car! Make it yourself for FREE!!
- Tokico and coilovers (post your pics)
- post your bumper lights at night
- gs integra fs in Illinois
- skunk2 dual bend short shifter
- Car died twice, need some advice.
- how to remove window trims
- clutch sleeve !
- 4-1 header that fits OEM cats
- GS-R HELP
- ls vtec problem
- ls vtec w/p30 pistons
- Greddy SP2 Exhaust System
- Sweet break
- removing head
- RS strut bar bolts
- timing belt on a gsr
- installed universal pillar pod pix?
- ITR OR SKUNK2 OR BLOX OR AEBS MANIFOLD ON A GSR 99
- STUPID I KNOW BUT, IT WOULD BE FUN!
- Switching doors..
- where can i buy the crome ecu?
- my integra is frustrating me.
- Can anyone post pics of their teg with a greddy evo2 exhaust?
- DC2 headlights??
