View Full Version : Acura Integra
- how to clean ac air filter
- will it fit ?
- Stock GSR TB port matched with stock IM
- HELP. I'm having a honda crisis! I need backup.
- vtec problem
- 93 gsr UCA hitting shock tower..anyone used adjustable upper control arm??
- Code 19 A/T lock-up control solenoid on a manual
- integra with duckbill?
- engine wiring harness?
- Vtec
- KYB AGX for a DA
- jdm front
- help installing cam gears
- Mystery motor.........
- amp not powering off
- electric belt thing on DA integra help
- need to speak to a moderator about unlocking trial user options help!?!?
- B16 In integra, Gas in Oil, Wont start
- Transmission bolt on Acura GSR B18 from transmission to the bracket on the firewall
- Sputtering, Misfire, Die.....
- Photoshopped my integra into a transformer.
- tanabe vs. greddy
- Removed some alarm wiring, Now car wont start...
- some b18c1 DA swap questions!
- IAB!!!
- throttle cable...
- finally i got my new car...
- Newcomer
- i am lookin for 91 acura integra partsfor sale
- Using MSD 6AL set-up, do I need a MSD Fuel/tach adapter???????????????
- Got computer problems on 95gsr..............check engine light
- GS-R Bore
- Car was broken into. Questions on ignition
- B18C7
- ac in boosted teg?
- Engine Spec
- head unit wireing
- Check Engine Light Code 54
- arp torque
- Glove box lock
- fuel sensor (floater) different from gas light sensor (gauge light)???
- Firewall mounted OBD0 MAP to ITR TB mounted MAP wiring change?
- Undercar fuel line question.
- integra seats
- anyone h22 supercharged making good numbers?
- Need bolt lengths/sizes for b18a/b motor
- Ls Vtec swap Questions, Smog, and ECU and more...
- HONDA-TECH ADMINISTRATORS@MODERATORS
- Car starts 80% of the time
- which exhaust?
- 02 stimulator
- need help!!!!!! noob in distress!!
- cel?/vtec not working.HELP!PLEASE!
- What to do with a B18c1 with bad LMAs?
- looking 4 1 piece h-l's
- I need help on some specs searched but couldn't find it
- Main Relay - No second click for priming fuel pump
- 91 integra wont pass 3000 rpm need help
- Upper Control Arm
- rebuilding block need advice.
- Invidia v. Apexi
- Bore Size
- T1r Exhaust?
- fuel injection cleaning...
- did a tranny change today
- dangerous to remove tin / heat shield?
- Tranny differences
- obd1 p72 question
- Headlight restore
- Headporters-LA Santa barbara
- Type-R Tranny
- antenna removal
- Type-R 5 lug conversion
- flywheel?!?!
- misfire at 3000rpm
- clutch fluid...
- Looking for patch panels for a 90 integra
- Would be Good Exhaust Setup??
- Rear Defroster Doesnt Work on my 1996 DB8
- Best Stock-replacement Muffler DB8
- Stupid Thieves!!!
- 91-92 B1.8A1 start wont start
- new to ht and new import owner [lookin for ls engine]
- Air Conditioning Blower problem -
- ITR 23MM Swaybar and ITR LCA problem
- help. huge scuff mark on my car.
- leaky da
- what headers are you guys using for your DA's?
- JDM slant
- dumping power steering?
- Where to get the best muffler/exhaust system for DA INTEGRaS?
- B18 accessories on b20 block?
- is the search down?
- Stolen 92 Integra in San Diego!!! check this out
- Repainting side mirrors
- L.F. Obd2b to obd1 ecu harness
- Which tach is right?
- exaust too close to gas tank
- help Hubcentric Ring for Spoon SW388
- '98+ tail lights. how much?
- Pistons???
- engine mount inserts!!
- oil burning, valve adjustment, compression test
- WHAT CAR DOES THIS OEM MUFFLER BELONG TO
- How hard
- jdm hood
- intermitent vtec
- Ecu conversion...auto to manual?
- gsr b18c cams vs b16a2 vc b17 cams
- Just changed my oil... but something weird happened...
- Quick Question 98 Integra gsr smog
- INTEGRA STOCK DECK CODE
- Could it be wheel bearing?
- search feature
- Steering Wheel Question
- 9005 headlight conversion
- Radiator!!!!!!!!
- cruise control
- Front Lower Ball Joint
- type r muffler
- bumper question
- quick question
- B18C swap ? passing inspection in ny
- good deal?
- Failed Omnipower bushing. What are my options?
- is tranny gone
- Scraping noise while turn at high speed!
- ATT... I need the vacuum diagram of a 1990 integra.
- So I just purchased a 99 Gs-r with a blown motor and...
- i got a question
- whats wrong with the search?
- what do u think
- hy-tech headers
- cOBD2 to OBD1
- After cat o2 q
- stage 3 act kit on gsr
- Swaybar Hunting for a 99 LS
- Ls Motor
- 95 Teg Water Leak???
- This is part 2 of my stupidity got the best of me...
- flywheel cover?
- no power
- head gasket spacer
- compression #;'s
- LS vtec
- Valve lash adjustment Need help please......
- check engine lights and srs.......help
- thread squshed, new ball joint?
- k24 question...
- LS or LS/VTEC
- teg LS wont start
- Hey I have a couple questions 95 gsr...
- So, my stupidity got the best of me last night...
- 92 Integra, Alarm help
- WHO IS THE HT ADMIN HOW DO I POST REQUESTS?
- WATCH OUT FOR SKUNK2GOTOGUY
- LED turn signals.
- is there a manual or a step by step for a engine rebuild?
- Car won't start
- ls ecu
- Taillight bulb number?!
- Auto to Manual wiring... please help
- IAB problem HELP!!!
- Wheel stud replacement????
- Brake caliber locks up?..
- acceleration problems
- oem parts
- Nippon ITR P73 Pistons vs. Honda OEM ITR P73 Pistons
- LSD TRANNY?
- My setup
- Quaife LSD problem GSR tranny passenger side axle
- Opinions on new suspension
- What to ask for this car... not sure, need some opinions
- Please help..Radiator fans only run with AC on..
- GOT A CHECK ENGINE AND SRS HELP!!!!!!!!!!!!!
- hmotorsonline.com
- integra cluster with (white led bulbs) anyone tried?
- Hi New here, 98 BG33P Rahziel, Reborn
- Can't take off the rim off my integra?
- LS block internals in b16a block.
- inteagra coilovers
- CTR Internals
- code 20 (electronic load detector) on 91 integra converted to obd1. HELP!!!!
- Abs removal.
- Muffler shops in the Bay Area
- I need some OBD2 help folks
- what kind of tranny
- someone gotta know this
- Cloth replacement company?( for your tired old crappy leather seats...)
- i need a lil help
- Need Help! Pistons
- VTEC problem help!!!!
- SWAP WANTED / TRANNY AS WELL
- Help Me Out With the Aesthetics ???
- integra brakes
- Need some serious Help/Advice/Opinions
- what the hell
- Need Hel/Have question about rebuilding rear calipers!
- PARTS FOR SALE
- Start problem-cool evenings only
- this ebay item!
- H22 turbo manifold compatible with GSR?
- common problems DA teggy's.
- Engine Additives
- 1996 GSR IN 91 DA RUNNING SOGGY
- Do I need to replace my clutch?
- Invidia v. Apexi
- B20 and B18 pulleys the same?
- ctr vs. itr head
- Test pipe or stock
- Air Conditioning Problem.
- --- help .. brake pads
- custom paint what do you think?
- picked up GSR pistons...install question
- GSR or SI
- wiring a non vtec to a vtec?
- antenna plug
- Front blinker problem..
- major problems/need help for b16a swap
- installing exhaust system?
- Help please! What other transmission will fit my 1998 ls motor?
- auto to manual conversion...reverse light???
- anyone had something shipped from 90 integra?
- hazards not working
- Greddy SP2 Fitment Issues? Other Problems?
- pics/vids of da's circut racing
- cant find EVAP Solenoid in 96 integra....
- help...high idle 1989 Integra
- 96 Integra
- radiator question
- Need help about retro fit relay.
- looking for a drive side door for a integra
- Instal headers or not?
- Bolt on vs. welded, resonator and catalytic conv?
- Best suspension for integra
- DA roll cage and ls longblock for SALE
- LS/VTEC PROBLEM HELP
- brake problem...
- big big firewall problem
- torque specs
- where to go next?
- hi im new want to get to know other teg lovers!!!
- tach wires
- Running a little warm under load?? Bad thermo??
- camber correctors help
- snapped a couple of rear wheel studs - should i try this?
- Starter? Main relay? Crappy aftermarket caps/wires? Pissed off.
- parts... L Bracket for dc2
- Looking for the owner of this car...............
- aem v2 intake for DA?
