- how do i wire up gsr in 00 ls
- WHICH BRAND CHIPS TO YOU GUYS RUN
- does a skunk 2 intake manifold bolt right on a 2000 gsr
- GSR gen2 Questiion
- VIDEO!!@!
- Help with the Lower Control arm + Steering knuckle
- bell housing
- exhaust problem
- Uh OHH. Massive clutch chatter.....
- taking tint off
- CARfAX PLEASE
- O2 sensor question
- ls/vtec questions
- Roll back GSR Cluster? Read before flame
- timing retarding - b18c1
- has anyone done b16 into a g2 ?
- What mods will help this setup?
- will 205/50-15 tires too wide for stock GSR blade wheels?
- Another victim of hesitation! Bad gas mileage and very sluggish...
- ITR springs
- ITR pisons on GSR rods?
- integra rotors
- intake experts... need help....
- bumper support
- Accerlation problem...
- Head pull times?
- any one selling anything for a 2000 gsr
- 2000 gsr ?S
- what's a good suspension setup?
- need help
- body part help
- TEST PIPE QUESTION? 99-00 Si test pipe? will it fit 2nd gen integ? 1992?
- OBX BX-72 camber kit on my 91 teg
- Odd loss of power in wide turns....
- mysterious electrical problem
- Average cost of LS/VTEC conversion?
- VTEC head.
- GSR TRANNY OR LS TRANNY
- quick side molding question...search didn't help....
- I have a Tanabe Racing Medellion, tell me whatcha think about this exhaust!
- itr armrest elimanator
- Some of my DA...let me know what u guys think...flame if u gotta...
- transmission noise
- ground wire
- Selling my G2 on eBay. Any guesses what it will go for?
- Is anybody can give me some information and specs about B18C6 engine?
- Whats a good web site for cheap wheels.!!!!!!!!! HELP
- BG MOA
- DRAG Gen 4 Turbo Kit Prototype Vehicles Needed!!!
- camber kit
- timing belt position question
- bushing kit
- Best NOS Setup
- safe compression
- HELP ASAP::: Im installing shock/spring
- help me with my ls set-up
- Tuning Question
- sedan chassis vs. coupe
- My new LCAs
- How Much $ Do U Think?
- Need power window advice / pics of wiring diagrams - help!
- weight of complete swap.
- Clutch Clicking - Squeak in engine compartment
- Need GSR sway bar mounting brackets
- Crazy?/! Shifer burning tranny
- Can Apexi Power FC use LS wire harness?
- 15.5 LS....
- will it fit? Exhaust
- Valve adjustment guestion on gsr
- Axle question
- tranny problems, need some help.
- Clutch fluid leak from tranny! help please..
- RAD
- Got a Strieght pipe. And Now what do i do with the Air Sensors?
- hondata s100 question
- Pics of your greddy sp installed
- 94-97 itr lip install
- what's all of yall opinion on remanufactured brake calipers?
- trannytroubles
- OBD2 to OBD1 LS distributor repin diagram ?
- JDM ITR 4-1 vs comptech
- koni yellow w/ prokits riding a lil too stiff
- obd question
- Monroe Struts in DA9 Integra
- ctr style lip on del sol?
- Glove Compartment problem
- acceleration stumble....?
- Is my Clutch Broken?
- Very bad thing happened to my car today.
- Maint. Question
- Turbo install??
- Anyone using this setup or knows if it works?
- Exite Professional 3 STEP Fuel Injection Tune-up [Sea-Foam Alternative]
- fishtank in the trunk!
- BACKORDERED!!!!
- Header setup Complete!!!!!
- put gsr in 2nd gen. need some help.
- Falken Factory Performance Parts?
- apexi vafc vs vacf2
- installed aem cai on my ls
- DA Integra Roll cage pics please??
- What rims are these??
- Does anyone know how to fit Ep3 Seats in a Integra?
- I'm a newbie, please with my antenna?
- obd1 p72 oem ecu on skunk2 IM....
- ZC DOHC in 87 teg?
- SoCal-Jdm tv filming at Car Meet @ Volcano Tea!
- how to become a member
- misc. valvetrain upgrade
- Help!!! weird noises after quaife install
- URGENT: Four-Door rear bumper on a Two-Door Integra. Will it fit?
- Long story short... JRSCed Ls Teg. Problems....Help!!! Over reved.
- brake torquing
- Does this sound right?
- Ls w/ GSR tranny?
- axle/cc joint...bad or what?
- Momo Hub Question
- Help!! I just installed my tranny and now my car doesn't start!!!! WHY??
- 2000 gsr
- Who sells Wedge Seat brackets and sliders?
- Vtec wiring ????????
- ALPINE SCREEN
- Other than Honda ATF what can I use ?
- car wont start..
- Small Hole in Tranny....
- Hondadistributors.net
- Tranny swap help: Confused about mounts
- Need of Carfax Please.....
- s2000 radio in integra????
- lowering question
- Idle issue
- Does anyone know the code on a b20 head and a b18a head?
- Better head, B16 or b18c1?
- Where to buy: FULL RACE TURBO KITS
- shifter kind of notchy after quaiffe.
- Need torque specs for rebuilding GSR motor
- Tanabee Racing Medallian Exhaust
- can anybody runs me a carfax? i am interested to buy this type R
- Door Panel Inserts Measurements on a 4 Door???
- ITR Lip with WW Side Skirts; pics???
- and mechanic says cv boot is broken...
- all motor setup for 2000 gsr
- coil overs
- GSR engine bogs
- carsound cat problems
- What kind of power???
- Ebay header any good?
- can anyone take a pic of their USDM P72 head dizzy side.
- QUESTION: WELDING JDM RADIATOR SUPPORT @!@!@!
- My Integra RS - Ls/Vtec 184 whp 13.6 1/4 mile :-)
- Accessories lights stay on
- missfire when warm
- Anyone stripped the top of a strut?
- CEL code 9 :-(... what is it?
- jsut bought 94 rs tranny probs already need opinon
- install shift boot help
- broken bolt, the rear strut 14mm bolt
- NEED HELP !!! windshield how-to
- Need a 90-93 gauge cluster diagram for the large and small plugs!!!
- how to adjust headlights?
- clutch master cylinder questions
- plastiguage says .002
- Pressing out vs. Honing out Wrist Pin.
- can axels be rethreaded?
- Kaaz yay or nay
- skunk2 im question
- Slow ticking noise coming from my exhaust.
- GSR hard to start (only once a while)
- Compression Test Question
- valve clearance.... vtec... checking valve clearance...?!
- what u guys think my car is worth?
- Damn stock FPR!!!
- Base RSX vs Gsr???
- Turbo Oil Lines
- help !
- coolant hoses where to plug?
- Thinking of hondata
- all motor on gsr here is where i plan to start
- some video! tell me how it sounds
- this goes out to all who needs a FREE CARFAX!!
- Best prices for after market parts via internet?
- Sipeing tires??
- LSV-tec or GSR???
- one more quick turbo question
- yes another Seafoam thread! :P Questions inside!
- Khumo ECSTA ASX vs 712
- Advice?
- Would I rub with this setup? and a couple other questions...
- Speedo cable install...HOW?
- Will I pass Smog ?..I Had misfires b4
- GSR Cams Peak Power
- EBAY SPOILERS>>>>Never Buy
- Power steering pulley the same
- fuel injectors (remove/install) G3
- Selling trying to scam?
- QUICK!1! What are tranny torque specs?
- Suspension noise - speed bumps etc.
- Alternatives besides Roll'N with my white 17's....
- New Comptech swaybar brackets
- torque converter or manual tranny?
- cleaning fuel injectors
- clean out headlights
- jdm type-r steering wheel question
- ws hanger question
- How do you know if an integra door is OEM HONDA or not?
- fuel pump
- TYPE R REAR SWAY BAR?
- Will ITR caliper bolt up to a DA Kuckle/hub??
- K&N Drop in filter (almost)?
- please forgive me
- Acura Wheels: Oxidation??
- Having trouble figuring out which model of exhaust I bought.
- 16" or 17"
- ABS plastic lipss Question
- please HELP 90 integra problems
- Illumina Question
- Mad Air Comes out Oil Filler Cap after Adjustment, WTF is goin on here..........
- jdm integra type r FIVE LUG question on a gsr
- New Guy On The Block just saying hi
- New to Htech/Free carfax
- GSR SUSPENSION Q
- 2001 headlights
- what kind of cam gears for my steup ?
- pusher fans w/ac condenser?
- FULERTON RACES @ HARBOR & ORANGETHROPE
- Tokico IllumniaR yay/nay?
- H&R 5mm Wheel spacers
- help..
- stage 2/3 cams on itr valvetrain?
- twin loop mufflers
- will it work
- anyone know the stock bore of a 1.8 ls motor
- LS/GSR Interior Questions
- "T" connector on maual power steering rack
- hey guys i decided to go all motor on my 2000 gsr
- Piston question. searched
- Gas mileage going down
- HELP!
- Idle Control System Failiure..... help :)
- diff btw jdm and usdm throttle
- 00GSR CTR or PCT pistons? CR 11.6:1?
- throttle body help!
- anyone have a VAFC on a all-motor???
- Need Help Identifying Eibach Sportlines
- need a b16 vtec solenoid and a obd1 p72 gsr computer and oil line ls/vtec
- gsr retainers
- awesome birthday gift story
- Isolated my problem.. rechecked OBD2 codes... and it's the ICS malfunction
- sway bars...22-23? Which ones are good
- need help with turbo piping
