what is the size of the axle bolt?
Old Oct 21, 2002 | 08:39 PM
bocian's Avatar
Default what is the size of the axle bolt?
the one im refering to is (i dont know the official name for it) the one that is right behind the center cap in the middle of the brake disc. one edge is wedged into the axle thread so it wont unscrew itself.
tia
Old Oct 21, 2002 | 08:47 PM
garados's Avatar
Default Re: what is the size of the axle bolt? (bocian)
1-1/4 inch. It worked for mine ^_^ Just don't forget to unstake it.
Old Oct 21, 2002 | 08:48 PM
bocian's Avatar
Default Re: what is the size of the axle bolt? (garados)
sounds good thanks. anyone know what that is in mm?
Old Oct 21, 2002 | 08:57 PM
garados's Avatar
It's either 31 or 32 mm. Conversion from http://www.processassociates.com/pro...ert/cf_len.htm
edit: it's closer to 32 mm HTH
[Modified by garados, 10:57 PM 10/21/2002]
Old Oct 21, 2002 | 09:00 PM
97hb's Avatar
32mm or 1 1/4 This bolt was a biotch
Old Oct 21, 2002 | 09:06 PM
garados's Avatar
Default Re: what is the size of the axle bolt? (97hb)
Oh yeah, huh, get a friend to press on the brakes while you use a giant breaker bar with a large pipe on the handle. Good luck ^_^
Old Oct 21, 2002 | 10:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
32mm is correct. A long bar works great. I had trouble when changing my friend's axle, but as soon as we put a 5' long bar on the breaker bar, it came off without a hitch.
Old Oct 22, 2002 | 03:51 AM
JCushing's Avatar
yup 32mm.. easiest way is to just take the centercap off and put the car on the ground all the way... then get a big breaker bar and stand on it.. it comes off even if the lock is pressed in...
Old Oct 22, 2002 | 02:06 PM
GSRaCeRbOI's Avatar
its 32 MM..we used the above method... have the e-brake on and wheel chocks/blocks... took the rim off.. popped off the center cap... unstake the pin thing (dunno what its called)... then put the rim back on and lugs.. lowered the cam back to the ground... had a friend press on the brakes while slipping on a 32mm socket and breaker bar w/ pipe extension and applying force to it... it was tough but it broke loose...
75aces
Sep 23, 2015 03:28 PM
butter99
21
Nov 27, 2008 09:00 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
antaneus
Feb 18, 2003 10:05 AM
keithv
12
May 9, 2002 07:44 PM
