View Full Version : Acura Integra
- Exact differences between the ITR and GSR suspensions...
- i got a problem advice needed
- falken azenis on national backorder !!! WTF
- FS: lots of parts!!
- 2000 Integra battery dead??
- Has anyone ever done a seat belt swap on a second gen?
- What kind of CAI/short ram do I use for B16A1 swap into 91 GS?
- itr lcas the same as...?
- Teg Pricing
- werid noise form right rear of car
- 0-60mph
- Removing door panels
- NEED HELP MAKING SRS ON CLUSTER GO OFF & INSTALLING HORN FOR MUGEN FG-360 STEERING WHEEL?
- part number or size of plug for trunk hole?
- how to tell the difference between a gsr block?
- Do these calipers fit a teg
- JDM ITR Front end conversion...
- will this short ram work properly on a ls?
- Where you mount oil cooler
- What to look for when buying..
- what controls the maintenance light
- Skunk 2 intake manifold on OBD 2?????
- What is the story with polyurethane bushings with a B & M short shift?
- anyone know where i can find a cheap w/g dump tube?
- Lookin to tidy up my suspension...
- By Baby
- maintenance for integra's?
- which one should i get
- bad MSD
- Should i get rid of the teg for a wrx?
- My teg is totaled, please help!
- V6 VTEC engines: will they fit?
- Climate Control Slider Light - Difficult to change?
- How Do I Take off my stock Steering wheel?
- Will 195-65-R14 fit my integra with H&R sports?
- tsting waters for fully built gsr motor fs
- for suspension guru
- XenonDepot 6k HID pics, 56k friendly will take better ones w/ good camera!
- Wierd A/F Gauge issue.
- HID Install help
- Which helms manual for 01 integra?
- Type of gas in GS-R
- Alright fellas, I need a straight across the board answer....
- b16 in DC; what mounts?
- Sway bar and Subframe Question
- buddyclub seats in an integra, anyone have them?
- Spoon Drop-in air filter
- To those with Walbro intank fuel pumps...please read...
- Ignition problem
- 98-01 integra going wingless
- Any Problems with Falken Azenis?
- a qeustion of rubbing on a 2 inch lowered gsr with 215-45-16 ?
- People in Atlanta I need help
- Happy Thankgiving
- Mugen or Spoon seat
- OK, got the AKT body kit ad scanned. umm, it's not on a site though.......
- how much is my GSR worth
- dealerships suck! - can anyone here assist me with my coolant leak?
- how to "turn" a flywheel , like sand it
- block guard
- just bought a Griffin radiator AND I NEED HELP
- Who has the lightest street DA??? ( weight reduction tips )
- B20 vtec
- re-threading your shifter
- BSQ or Beaks? Issues wit ITR sway
- CRX Si seats in G2 Teg
- ITR Sway HELP!!!
- Look at this bullcrap....
- clutch?
- i got scammed by michael vu
- $1,500 Home Made Turbo, Any Oppinions?
- Speedo problem at high rpm's
- New Header
- i need a suspension
- Verification needed: Does DC2R's coilover appicable to other Tegs?
- I think i have a problem; I'm a ricer... Detailed pics inside (56k, i dare you)
- XenonDepot 6k HID install issues, HELP!
- Weight of the B18C1
- Retorqueing Header
- for all those with jdm front ends
- JDM ITR Rear Sway bar
- Defrost not working properly
- GS-R Chasis Question
- lsd question.,.
- just got Nitrous
- Need help with suspension
- Who has the best price on a OEM or Replica Type R spoiler??
- Need ECU pinout for 99 integra gsr(Fuel Tank Pressure Sensor Circuit)
- might be stupid Qs, but diff between pr4 and obd1 p75 ecu??
- Any information about the Venom 400 Module for GSR's....?
- OEM Acura Skirts - Weather Strip
- Just got my Philips 6K kit from XD, question
- RS*R EX MAG Just received
- gearbox question
- diff between 94-97 power steering pump and 98-01
- skunk2 with agx
- bushings in the shifter
- Which way to go with GSR
- how to adjust timing on b18b1
- Check out what I bought for $950
- insurance?
- Last skunk manifold question
- rattle sound around 3000 rpms
- Happy Thanksgiving!!
- Bent Valves, or just need an adjustment?
- Which engine should I get? (more complicated than you think)
- civic coupe piping to 2dr gsr
- Is this the correct gasket?
- Few quick Skunk manifold questions...
- tweeter help
- Help, Brake pedal sinking, whats a good Master cylinder
- Hp for mid-to-low 13's?
- Yarg!!
- Controlling Butterflies on '01 with RPM Switch and VAFC II
- RPM IDLE and 100k tune up
- Anyone know anything about this THROTTLE BODY?
- placeracing's passenger side motor mount wont fit on b20/vtec 92 teg
- Crank pulley help
- GSR header on a Type r b18c
- H&R or Neuspeed
- h23a in an integra
- does a 99 gsx turbo mani fit on a bseries
- skunk2 or jg edelbrock manifold
- Any difference between the 94-97 and 98+ side mirrors?
- What is the color code for the FBP and SBP?
- debating gutting CAT on obd2 car, worth it?
- oem side skirt and rear valence
- what cam?
- PLEASE someone answer this exhaust question?
- which exhaust to get
- Gauge Set Up's
- Rear Crossbar - Unusual chasis stiffner
- best turbo kit for stock ls motor w/40,000k?
- ls/vtec links search friendly (for the lazy ones)
- how long is the throttle cable....
- jdm 4-1 dissapointment
- Where's my car?
- my gsr wont start any help
- does anyone hav a pic or diagram of the fuse panel for a gsr 2000
- changing steering wheel
- Random Technologies Cat - welded flanges?
- how to start a car without a tranny on car???
- 5zigen header?
- vtec controller
- how much ft/lbs of torque for the valve cover bolts for ls need the anwser quick
- Header Rap
- Acura Warranty Work
- pic request: Cypress green teg with circuit 10's
- stripper
- JDM Type R Conversion?
- Q: Auto transmission filler plug??
- Looking for itr8 from bayarea regarding your recaros for sale
- trial?
- ls vtec
- HELP.. need pic of a usdm 94-01 integra pedal assembly
- ***Idle Problem***
- Turbo ls
- 5 lug conversion on DA6
- brake sqealing
- JDM B16A auto control unit fit in 90-93 TEG?
- what size wheels
- questions about motor work ?
- Will 93 Rear GSR LCA's fit on 95 integra/93civic?
- Anyone know if the center caps from 95 GSR rims are the same size as center caps of 98-01 GSR rims??
- wheel spacers..how wide can u go??
- vortec supercharger or turbo?
- rust on rotors?
- GSR ECU plugs?
- Hello to all!!
- Need Help With My Heater - Wont Warm Up
- Does anyone have pictures of where the shift boot screws in?
- motor mount insert installed
- need help with my s3 light blinking
- 500 bucks what should i get for my G2
- JE PISTONS WITH STOCK GSR RODS
- please help with exhaust rattle
- Car starting prob
- WTB: 1 right rear tail lamp for 98+ dc2... will trade for a pair of 94-97 dc2 tails...
- Carbon Headliner and Deck Tray
- ABS accumulator questions, Which will fit, where is it, how much? HELPPPP
- Need help ASAP. Do all integras use the same ignitors?
- 92-95 Springs on 90 Integra
- Wiper Issues
- Do you have to have a particular Clutch Master Cylinder for ABS and non-ABS?
- exhaust rattle issue
- Ls/Vtec NEED ADVICE!!!!
- GS-R Rim weight??
- Ideas for my GSR...
- Surging idle and CEL 14 problems
- Calling all H-T memebers in NYC/NJ memeber needs help !!!!!!!!!!!!!!!!!!!!!!!!
- Any Washington State Auctions?
- obd1 check engine flash codes
- hoe much power?
- any1 with a Roll Cage in their DB8's???(tried a search)
- ls timing belts snaped, will it bend valves
- seats? wondering if this swap can be done. searched!
- Synchro's in 1st and Reverse?
- Brospeed catback for 95 gsr
- Will a ITR clutch fit a 92 GSR
- anyone know of a good DIY for gs-r alternator install?
- rear hatch question for teg?
- stay with boosted LS or get a 97 GST.....
- B17A tuning
- best pistons to use in a b18c1..gs-r motor for those who dont know.
- I cant find poly-urethane upper motor mount inserts for my GSR!!!
- Speedo gear on differential removal
- Best Idea for 92 GS
- I dont usually ask this but is this a decent deal? ( 97 LS )
- crank pulley power results
- 90 integra dc header fitaments from a 94 LS dc header
- Traction control problems
- differences in bore sizes in b20 and b18b head
- how much power?
- JDM tranny LSD rebuild parts?
- Cluth problems. Any thoughts?
- tranny shifting problems CEL Code 6 ECT starting and other TIPS FOR THE WEEK
- Trubo vs NA.
- which spark plugs and wires for my 93 gs-r?
- Gsr spoiler?
- jdm pics
- jdm front end.
- chip for 97' gsr obdII.......or they dont make it?
- car is getting drenched with water
- computer chips where to buy???
- Anyone have problems with DA's?
- Is the LS Skunk2 manifold different in size than the GSR or ITR one?
- Carbon Fiber hood chip.
- do pulleys help at all?
- new member
- who had the quote about fat people wit camber wear on their shoes?
- Transmission Mounting Bolts
- Which way down?
- Brake/Gas Pedal installation question
- rattling from below
- ITR Exhaust
- Vtec solenoid, is yours rusting too?
- people in NY Have issues with rust on your tegs?
- Difference between the 90-91 and the 92-93 g2 teg
- radiator leak
- JDM Front nearly done, couple Qs.
- Can you Help me???? Anyone??? Please????
- rota
- need help changing rear motor mount on 92 teg
- Skunk2 Koni Coliover Ring Adapter????
- Bye, bye 98 integra, Hello 04 WRX!!
- What to do if water gets into your engine and it wont start
- turbo question on a '90 teg
- would b18c1 pulley work on b18a1?
- Help with Integra build up
- experience with h&r coilovers?
