View Full Version : Acura Integra
- DA 1 PIECE HEADLIGHTS
- DB1 WINDOW
- WOULD A DA6 EXHAUST FIT??
- db1
- OEM ITR susp. on DA?
- need help orlando gsr owners
- Side Mirror Styles 94-97 and 98-2001?
- HELP ME !!!!
- JG cams or Skunk2..?
- Help: 98 Integra Temperature Rises to HOT, BUT car "NOT" overheating!
- **misfire at idle** help please
- Urgent Help Needed!!!
- New member from Sacramento, Cali
- Velocity stacks
- b16 into a dc2?
- need ecu help
- 96 spec cluster into 00 issues
- Integra PWR Folding Mirrors F/S
- PLEASE HELP with this flywheel
- ignition coil
- getting back up
- 06 Si wheels ?
- gsr idles real low...help!!!
- good 5 lug conversion dealer...
- b18b1 pistons/rods
- Clock Spring / Cable Reel?
- O.E cd-player not working
- B18B1 LS Integra Spedometer Fluttering Issue
- My New HID's
- AP2 s2k cluster in dc help.
- OBD1 93 integra ecu help!!!!!!
- Skunk manif and intake
- no interior lights work on DA- bad icu?
- DA Question
- Will ITR torque mounts fit a B18C1 in a EK
- help with window adjustment
- New Block or No?
- custom heatshield?
- looking for db itr lip kit????
- guage cluster problems
- Spark Plugs and Spark Plug Wires
- tps code prevent vtec from engaging??
- can i get some sizes for low offset wheels that woulg go on a dc2
- WHAT SIZE BULB FOR GAUGES
- type r oil pump on 94 gsr
- 5 speed or JDM front
- integ responds cai vs sri
- mechanical ?
- need rocker arm help
- oil catch can??? where do the vacuum hoses go?
- Coolant problem. Radiator. Integra
- how to remove quick release steering wheel
- Mishimoto Fan + Shroud Installation
- 90 Integra LS Code 43
- the DA sounds like it has ITB's.
- Ran motor without dipstick
- Need help (s2k cluster in dc integra)
- skunk2 pro s coilovers
- EVO IV Recaros in GSR??
- Aem cai
- would you trade for a WRX
- Failed SMOG Test help please
- 2 new problems, fuel and guage and trunk
- HELP BLEEDING BRAKES/ABS
- installed arp main studs, now the oile windage tray dont bolt up
- Overheating Issue
- need pointer for my gsr all motor build
- Why does jdm b18c have higher comp ratio than b18c1?
- Which full coilover set-up should i go with on my 95 Integra LS? Under $800 please.
- Post pics of your front Lip! JDM front end preferred
- ICU For Sale?
- MC2 B18C4=B18C1=GSR from Portugal
- vibration ?? help??
- trunk makes squeaky noises
- Inegra ABS delete and other help questions
- turboed ls fuel management
- engine running rough and bad rpms, and rpm gauge goes crazy
- *No Vtec ( 90 psi at sending unit, 25 psi at vtec pressure port at 5000rpm)
- gen2 b16a in a DA. lots of Q's wit pics! help!
- db2 with 98 b20b p8r head, couple questions
- automatic ls ecu work in a stick
- Is steering Column ruined due to theft?
- Startup Humming???
- Acura Integra Keyless Entry???
- ABS light came on, rpms now all over the place
- Rear trailing arm bushing
- Seatbelts not working in G2
- Hazards don't work in G2
- HELP!!!! REAR Suspension PROBLEM!!!
- DA WONDOWS??? Power to Manual??
- WTB MI Cable drive vehicle speed sensor (VSS)
- Please help.... weird lighting problem going on. Any help will be appreciated.
- Squeaking coming from engine
- B18B1 compression problem.
- Need help,Cars acting funny .
- Passwordjdm floorplate install pics needed.
- integra part?
- OFFICIAL Reject Squad v2
- 1999 GSR ACT HDSS Clutch Blew Apart
- door wiring help please
- popping while trying to start ?
- DA Integra 20 years
- Which Axles should I get???
- b20b Question need help! And b16 head V.S Gsr head?
- d16z6 in a integra?
- Transmission component question
- another broken lca bolt
- injectors problem
- Tach not working right after ECU Swap
- Left turn signal staying on, front headlights out, no left turn signal when applied.
- misfiring when the engine is cold and backfiring
- Knockoff/OEM style 94-97 Integra foglight harness
- B16 tranny internals in an LS??
- Timing Help with Lsvtec Turbo
- Engine & electronic shutoff / stutter issue (weird)
- Need help quick
- take a look at my dyno graph...
- 96 integra SE starting problem. Sensor help please.
- any brackets to lower oem seats?
- Doing door uphostery
- is this a itr axleback?
- b17a1 leaky vtec solenoid or cam seal?
- smog check going to 4th pretest
- ABS light turned on after installing..
- 92 integra timeline. iRockTheDA9
- squeeking noise
- What gauge wire to use for battery relocation to the trunk?
- Adjuster screw ?? Help
- Need rebuild ! Anyone heard of Lab Junkies?
- idle operating backwards
- calling all mass,nh,rhode island imports(cruise&meet)
- Gsr injectors the same as LS?
- Integra Auto Transmission
- JDM front HID fog light install
- 15" Honda Civic SI Wheels Rims Integra CRX Del Sol GSR From Ebay
- ls/vtec
- Needed for Power Steering
- gsr swap into EL
- axles for b16?
- GSR Running/Sounds Funny
- Suspension, bad caster jerking
- CEL code 45 need help
- Window troubles
- Failed smog. Need help.
- changing out a steering column need help
- 91 LS Integra Exhaust question.....(help/opinions)
- ABS help...
- My 1994 Integra LS Updates on 2nd page
- Fuel Rail Help
- b18b starter on a b18a?
- B20B Integra Swap
- leaks..
- Interior wiring guru's please chime in!
- Passenger door will not open inside or out????
- Fuel gauge problem....
- SEAT BELT ALARM CONSTINTLY GOING OFF!!!!
- ITR tranny going out? Or clutch? please help asap!
- manuel rack for a 95 integra question
- oil pressure
- Oil temp, Oil pressure and water temp gauges...
- Can't Shift into Second
- 97 integra timing belt belt problem
- Alternator conversion?
- dc maintenance light
- Help Coilover
- RC injectors question
- 02 rsx type s muffler flow good ?
- Starting with HIGH RPMS
- integra replacing head gasket
- Can these be cleaned?
- LS spindle same as GSR?
- 94 integra starter question Please help , reassembling the starter!!
- What brand names for low offset wheels?
- Stolen recoverd and now it will not start
- Planning to bring back to stock height.
- So someone hit my car today
- anyone keeping track of DA/DB GS-R's? sad day...
- Power Steering Help with install
- Advice on 15" vs 16" wheels
- CTR crank pully on OBD-0 B18A
- skunk2 tb question
- DC2 Trunk noise :-$
- need to know what kind of tool i need
- steering wheel install need help asap
- skunk2 manifold + blox 68mm tb?
- coolant loss and misfire on all 4 cyl...
- 92 ACURA INTEGRA DA LS
- How tight should my timing belt be?
- Vibrating sound, anyone know wat it could be?
- direct bolton header for a 99gsr?
- miss shifted from fourth to third
- CRVTEC HELP
- B series starter compatibility list?
- idle stuck at 3000 rpm
- random CEL codes
- B17A1 swap questions.
- Integra DA traction?
- hey guys i need help on my b20b
- Gas gauge
- Honda-Tech Special Kit??
- da 4 door carbon fiber trunk
- 97 acura integra GSR
- Problems with tranny
- lip kits
- insurance on jdm front?
- New member - lindseyhunt1090
- any pics of 94 95 accord rear lip on 92 93 da rear bumper
- Theft/Salvage title: Can someone school me?
- Gsr engine rebuild
- DA rear window visors FOUND THEM!!!
- integra exhaust
- To hopefully end the where can i get a rear window visor threads
- GSR suspension
- Header brand, need to know
- Oem Replica Lip kits
- ls/vtec help
- Velocity stack in DA
- Jdm itr db8 axel back
- 91 DA Leak w/Pics
- Whats a good drop/height for Function & Form suspension?
- Car Dies when i let off the gas
- GSR IAT sensor CEL.. help plz
- My 2nd DA, 1990 Integra RS
- need help diganose
- Any Jade Green Metallic integras?
- Camber Kits are a MUST: Over-steering and Skidding on 98 Integras
- b18b vs. b18c1
- b18 ls tranny bad? Please Help!
- gsr or ls tranny specs
- Car doesn't start up so nicely when it's hard rain
- Looking to do some Orange
- Seat Fitment
- Interior Upper Half Black
- what suspension is recommended to go with low offset wheels?
- Skunk2 Intake Manifold on a 99 GSR, will it produce a code?
- What's the best HID kit for a GSR?
- What's the best short throw shift kit?
- 90-91 VS 92-93 Integra front bumper
- Looking for simple fix for lagging 3rd gear midrange...???
- IACV
- will I lose power with a ------ exhaust size??
- knock sensor help!!
- pr3 stamp
- Rear hatch wires
- CIVIC SI 00 FD OR ITR FD?
- Sending unit
- DA Question: How do you remove driver side fender
- need peoples opinion on salvage/cleantitle
- DC2 sunroof help
- Will DC2 shocks fit on a EK?
