View Full Version : Acura Integra
- Yet another water pump/Timing Belt question.
- just bought 92 LS.Need sugestions on the parts that put out the most power for my teg.
- Timing Belt change...
- Weather Stripping Removal
- Driver Side Door Lock Problem
- Auto to Manual basic concern
- my effing tranny blew DAMNIT
- Can a JB Weld hold this together?
- Jdm Side-Makers On Usdm 2nd Gen Teg
- DC stuff for sale
- bar behind seats (middle pillar)
- Darton Ductile Sleeves (inserts) not a good choice!!!
- 94-96 white integ same white as 97+?
- Torque settings for 17' rims
- Ouch..DAmn rain..Help please.
- Anyone have a valve spring compressor for a B18B i can borrow?
- Good idea?
- Wings West Sides/ Type R lip Q's(fitment)
- WHATS WRONG WITH MY CAR?
- someone help with oem fog light setup
- Skunk2 IM install help
- What's up people
- Car is not starting (Clicking Noise everytime I turn the key)
- engine dimensions
- i need a rollbar
- Info: Tein HA coilovers
- torque discussion for gsr
- interchangable o2 sensors
- guage cluster question.
- car overheated to the max, ac blew hot air
- 81.5 head gasket???
- service connector ?????
- someone that knows about ecu codes help me
- Not running smoothly
- how to take out bolt?
- size ratchet for removing spark plugs?
- intake maniold question
- front bumper sagging
- 10mm spark plug wires?
- Considering buying a GSR
- what is the correct way to remove this??
- Water in Trunk
- Where to Buy New TPS?
- where to (misc) hardware for head?
- 94-97 to 98-01 Difference?
- B-Series flywheels
- solid cel after getting codes...
- Are these good sparkplugs?
- Fuel Problem ( i think ) Car dies randomly then starts fine within minutes?
- gsr tranny
- RSX steering wheel in DC2
- Some questions
- Aftermarket steering wheel screws! HELP!
- energy suspension master kit part list
- Anyone have the new Kosei K1 TS wheels?
- which mirror is it?
- energy suspension install (anyone done it?)
- question on skunk2 cams
- Driving to Denver, Colorado with my ITR
- Type r lsd on gsr gearbox
- all parts needed for ls/vtec conversion
- any can help me find baer brake kit
- Electrical Problem ? ABS/- SRS
- Suspension set up?...SHOW US WHAT U GOT..!!
- type R center caps on GSR blades.will they work?
- Antenna doesnt work at all, but isnt broken
- adjusting 98+ headlights
- LS vtec is worth it
- Think flywheel is over machined, need help please!
- what c/r is good for toda b's?
- SQUEAKING COMING FROM CAR!
- ODB1 to ODB2 conversion
- Skunk2 Coilovers Vibration
- Help! Is it possible to fit or relocate 96 gsr abs with jdm itr oem HID headlights...Don't want to r
- Just got my car tunned...well kinda...take a look fellow non-vtec bros..
- question about 6 puck Disc
- who on honda-tech chip ecu
- $500 titanium catback
- My friend has a 94 teg with a p30 head.. is this stock?!
- Weird vibration in 5th gear
- Rear Tailight Amber help!
- Swapping ITR final drive into LS tranny?
- Is it a good deal
- Which Header????
- People that have done manual swaps
- Rear seat options for 95 LS
- Boosting a SOCH integra
- What do i need to turbo my car?
- 95 gsr
- Question about 92 GSR cable trans
- is this crap or not
- Request Hks Hipper exhaust pics or vid?
- damn splash guards
- Clciking noise when decelerating... more details inside.
- oxygen sensor
- Need someone to make a custom shift boot for me - help?
- Motor Mounts inserts?
- starter question
- AEBS Intake Manfiold for GSR (coming soon)
- new pics of my car
- distributor compatibility
- HID.. Wire Install...HELP!!! (PICS)
- anyone dealt with RPM RON's Precision Machine, Inc???
- Transmission problems, need help please!
- Ripped motor mount stuck in tranny
- i need parts #
- need help
- Need help on radio code
- distributor cap and rotor replacement
- Help:- P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
- spare tire area
- 2nd Gen Exhaust
- would you buy a salavged gsr?
- standard Bosch platinum part# please for '96 GSR
- Body kit
- Can you make real POWER with out V-tech!!!
- Cluster Question...
- 1991 LS integra, purchase suggestion
- possessed brake light? wtf help me
- Resonator Box
- I Want new axels (CV joints) What kind???
- Engine wants to die.....Help!
- spark plug replace
- Messed up c/f hood
- RSX Type-S PARTS FOR SALE!!! (Washington only)
- 2.5 header or 3 inch header for Ls
- ricer's - can someone explain why...??
- Suspension Q.. thanks a lot guys..
- all b series headers match up???????
- Five lug itr hubs.
- I HAVE A NEW PROB!!!! PLEASE HELP
- Pads... still good or not? *pics*
- codes?
- 1/4 times in a ls
- how can i tell what kind of comp i have?
- Rota Subzeros
- THEFT!! -- 95 LS integra
- Valve Cover??
- golden eagle oil line trouble ls/vtec
- Big wireing problem please help
- JDM Integra Headlight/Fog Light Wiring
- Car used to burn oil, now it doesn't?
- G2 engine swaps??
- Skunk2 rear lower strut bar for DA
- F/S: Stuff
- Apexi WS or RS-R Exmag
- Tire pressure
- car trouble... starts then dies.... please help.
- Wheel well rub
- Doin tune up on '96 GSR, what are the platinum spark plug #'s for NGK & Bosch?
- Type R tranny on LS?
- itr header and skunk2 IM install question
- skunk2 IM pass smog?
- 1990 integra exhaust question
- Spark plugs for LS/VTEC
- tranny pick
- '96 GSR. Which is the correct Bosch platinum plug? #4201, 4227, or 4417?
- ECU options
- Looking for ITR stuffs
- Help Identify some problems.
- car dies out at 3000 HELP PLEASE!!!
- Swap it or built it??
- DA automatic seatbelts and bucket seats (searched)
- Buying ITR cams
- car trowing strong fumes from exhaust..help
- Stupid CEL!!!
- Fixing curbage on blades
- NEED HELP ON BUYING PARTS!!!!
- chipped p28 what sensor
- has anyone done 9005 into H7 projector housing?
- Beaks Rear Lower Tie Bar
- H&R sports for 99 civic fit on my gsr?
- IM Question for 94 LS
- question about axles
- '96 GSR 120k svc due. Any upgrades???
- throttle body
- paint question..
- 00 ls head on 96 ls shortblock ??
- oil pressure lights on.
- B18c5 Possible in 90 integra?
- Which exhaust?
- Is there a 3rd Gen Integra Club (94-01)????
- Pic Request: Hardware for DA9, Front & Rear Sways
- head swap question
- Turbo question...
- How to clean a turbo engine bay
- stolen stereo PICTURES
- FS/FT *BRAND NEW* skunk 2 gsr intake manifold
- NEEDED BADLY: HELMS for b17a1 engine
- Water coming from the vents behind my center console?
- Injen Intake
- Found pads... what about re-surfacing rotors?
- What are your 1/4 mile times with a STOCK gsr?
- RAZO AT SHIFT KNOBS
- replacement panels
- Exhaust Question
- new drive axels anyone?
- 94 vtec... Squeak comming from boot(extra loud in cold weather)
- culd u guys list performance parts websites?
- Hood Latch Wire Relocation ?
- Brake Pins Seized - Need help fast - Braking integrity has gone downhill!
- obd2 car obd1 motor and obd1 harness.
- any hid kit plug and play for dc2
- are all Integra trans share the same parts ie. inter. shaft, clutch, flywheel ??
- bought a Motor????
- Intrax lowering springs
- Looking for an oil pump
- WHITE SMOKE FROM RIGHT SIDE
- GAS MILEAGE
- car theft question
- Bleeding Clutch on 98 GSR
- stock RS integ curb weight (searched)
- Just installed fuel pressure regulator and now car wont start!
- just got the tranny on....now what!
- Alarm system problems
- best swap for 92-93 integra?
- Comptech vs. ITR
- Leaking Radiator
- fuel pressur for my set-up
- b18c1 oil pump on b18a1
- anyone have angel eyes for the g2 integra?
- Brake Light problem
- Brighter Headlights
- Car dies when humid :(
- 92 civic with a 94 GSR motor what intake will fit?
- June 21, 89 Teg gets a B16 transplant!
- 94+integra and 99-00 Si parts interchangeable?
- ne one kno how to fix housing in center console?
- Transmission
- OEM equalizer/power booster in 1989 Integra LS
- finished brake kit installation
- Timing Question
- 1989 Integra LS AC question
- Spoon Spark Plug wires....will they fit an ls..
- piston to valve clearance
- where to buy throw out bearing seperate
- Question about 98+ conversion
- best place online to get a skunk2 IM?
- integra transmission fluid
- new memeber
- quick teg question.. 94-99 exahust same as 00-01?
- 94 integra LS wont start just makes clicking noise
- which pulley to use? b16, b18b, b18c????????
- i need a stock axle back for a 94+ integra/ civic in MD
- help please
- whats up people: can i get some input?
- gas question
- boosted gsr overheating ....
- RS-R ExMag restocked for DA6
- guage needle plz plz help
