View Full Version : Acura Integra
- 98-01 ls mesh tire size?
- Fuel Filter Banjo Bolt snapped.
- Help with code 43, fuel filter and o2. ASAP
- car wants to die
- Need wirig diagram for 96 spec JDM ITR cluster into 97 LS Teg
- help
- (91 acura) heater switch on 1 and 2 doesn't work
- 93 Timing Belt-Water Pump Repairs
- Can anyone guess this header?
- DIY on RS POWER DOOR LOCK AND NEEDED PARTS
- vision technica carbon fiber mirrors for integra dc2
- Vtec vs. Non vtec [ls vs. Gsr]
- pushed in clutch, went straight to the floor :(
- 95 DB8: VTEC off and on and sputtering at mid RPM's
- No spark, whats the problem please help!
- autometer gage
- wheels and susp
- input shaft bearing or new trans
- DC wiper and antenna delete plug...Just cheaper!
- clutch?
- any green acura's with gold rims plz post
- test pipe . . . . . o2 sensor?
- Engine Dates
- axles mishaps
- What causes code 16 and cyl 2 no fuel?
- Coilover/suspension problem
- 91 da question
- Question about Earls inline fuel filter
- Failed Emissions- 94 GSR
- Looking to change my Manuel Transmission fluid...
- rebuilding head... need input
- Steering Wheel Removal Issue...
- water on my passenger floor?
- cranks but wont start
- valve spring id
- manual conversion
- LSD question
- Little black tank under the battery rack?
- DA integra seatbelt??
- DIY Aftermarket steeting wheel install on 90-33 integra????
- Tackling short shifter rattle
- Recovering door panels......
- 94+ cluster into 90 integra?..anyone?
- leaky block?
- Rough idle
- Door Latch stuck on "lock"
- Reusing head gasket?
- What Motor fits in a 92 Integra?
- Help Side Markers
- Tranny or clutch problem on '95 Integra
- p72 a gsr head?
- 2001 integra MAIN RELAY what color wire is the fuel
- B16 3rd gen Integra
- em1 help
- Problem 1991 Acura Integra
- Best Setup for Daily Driving (lots of noob ?'s)
- Remove spoiler question
- OBD1 DA Trouble shooting help
- my ls sedan engine shuts off
- Cleaning Headlights
- deciding between 17s or 18s volks te37
- apexi n1 for teg
- GSR wheel hubs
- Wheel Bearing Question.
- Reasonable numbers?
- B18C Crankshaft Material Composition?
- B20 VTEC or Built GSR????????????
- fog light troubles
- b16a headgasket fit on b18c?
- oil smoke issue, uncommon
- si vtec lip
- 95" Teg Fan Motor for Heater/AC stopped working ????
- Interior Diagram pictures plz!!!
- Need some info's
- Auto to Manual converion question well HELPPPP ACTUALLy!!!
- Can I use a pr3 power steering pump on p75 head
- TPS Question, Idle Problems: out of ideas
- blown head gasket???...
- Whats the real chances of hydrolocking?
- Another "what is it worth" thread, sorry.
- Still cant rebuilt GSR to run on its own
- gsr seats
- 98 Integra, car stops on freeway, now wont start
- write up on s2000 cluster ??
- best motor
- Snapped Timing Belt.
- Tranny Conversion QUESTION??
- built k24 01 teg
- HID mounting under bumper cover?
- clutch question
- Idle problem for a 90 integra sedan (b18a1)
- strut bars
- test
- 91 DA/ Honda noob help/questions
- GSR radiator
- oil
- converting 94-97 hatch to 98-01
- Noob Question: DC and Da Exhaust Parts Compatible?
- 94 integra coolent lines ????
- water in oil!!! bad Cam seal?
- Another TPS problem thread
- Replaced engine, Now it won't start.
- What should I do next to my GSR?
- Look what i just picked up for FREE
- DA integra ???
- What's different in the 94-95 Rear Trailing arm
- ?recommended method to plug brake line during caliper swap???
- service manual
- high idle on 95 ls
- direct port or wet kit?
- What do i need? Engine Conversion
- COMPTECH VS. Apexi WS2 VS. GReddy SP2
- Pics of t3h turbo install on muh GSR!
- Another reason i love H-T!
- Running rich and weak vtec with Skunk2 intake manifold.
- 90-93 Short Shifter Fit 94-01 ?
- radiator brackets
- Need help starting over on DC2
- Help please
- left turn signal flashes quickly
- check light dont know why
- exhaust rattle
- HOW TO: S2000 Cluster Swap In 92-93 DA Integra
- 94 RS mount questions
- What to Do?
- DA integra ????????
- motor mount help!
- 180k tune up q's
- anyone had issues with energu suspension SHIFTER bushings?
- Code 43 OB1 Issues
- power steering belt tension
- Brian Crower N/A stg 2 cams???
- 95 ls tranny problems. HELP
- Are there lower temp fan switches?
- Need wiring diagram??? =)
- Q's on 5 lug coversion
- JDM gsr ecu...
- putty oil??
- mugen 1st gen wing
- Smog Legal CAT in CA
- Anyone here have JDM power folding mirrors? I have a question....
- Well I'm Back In an Integra
- doing an engine swap, input please
- crank pulley torque specs
- CRV B20 block and LS B18 head do they work
- LS b18b1 Stage 2 brian crower cams help ?
- has anyone ever seen these?
- DA integra radio???
- smoking after complete rebuild
- My b18b intake polishing *PIC*
- Help Help Help!!! Manual swap question!!!
- Toda Cams
- crank pulley ques??
- Engine removal Oo
- what is this ???
- timing belt and water pump
- GSR Intake Question
- How many 1994 Integra GS-Rs were produced
- Car works at a higher rpm
- Jdm foglight switch question
- cluch probems?
- Tokico HP blue shocks w/ RS*R Race springs?
- axle pop out
- jdm front integra "fog lights"
- Stolen
- DA auto to manual conversion need help plz
- FAST IDLE THERMO VALVE HELP for 90 integra 4dr.
- DA auto to manual wiring need help
- solen... 97 teg gsr
- IABs don't engage tach dies at 5800
- Noob seeking info..
- tranny oil leak!?!
- Surging Issue
- suspension question
- can a cracked header rob power?
- Can anyone tell me what happend
- help oil please
- JDM DB9 Integra AWD
- 90 DA wont rev passed 5500( IS NOW FIXED)
- will a tanabe super medallion exhaust for a gsr fit on a ls?
- 92 teg wont go into gear with car running
- Identify these cam gears!!
- Reputable site?
- EGR Valve
- What is this?
- I need help with my gauges in my 90 integra
- Bad vibration.
- oil pan install
- where did these wheels come from?
- Pulling to the left when accelerating after axle install - Please Help
- new cams
- P73 Piston?
- weird noise from the steering colum... please help
- Gap.....hole
- Car makes wierd noises up to 3500 and clutch too
- Short drive without the rear brakes
- what does getting ur car bar'd mean?
- NEED Help ASAP
- 97 integra need help
- Anyone think theres any coming back?
- mpg ftw!
- car die on hwy HELP
- Question about JDM 94+ integra lips
- whats faster moded rs vs gsr?
- Car shuts on and off while shifting hard lol wtf!
- HELP!!! JDM b16a tranny (STICKER VIN?)
- timing off.. "need help"
- IDLE help? details inside. b18c1
- Under Dash Fuse Box
- 93 dc2 integra where do these wires go :)
- Master cylinder going bad?
- light grinding sound from wheel area.
- 01 gsr ecu question(help)
- 95 ls opinions and help!
- Turbo integra Leaking oil HELP
- GSR overhaul Help needed
- Re-installing stock handbrake lever?
- Why does my Integra keep eating wheel bearings?
- csl/lipped carbon trunk
- look at this tsudo exhaust!!!!
- Heater Core Compatibility (eg into da?)
- replacing driver side axle by removing upper ball joint
- jdm integra headlight question
- Help - compression tester stuck
- 92 GSR Sputtering and breaking up past 3k (searched) HELP
- I hate my integra
- Beware of Innovative Mounts' "customer service"
- 1992-1993 Acura Integra B18B Help
- e Steering wheel jiggling and excessivflexing of motor when driving
- oil on my spark plugs?
- Master Cylinder ??? Brake Booster ??
- Engine dies when I first start driving... don't no whats wrong.
- Engine wireharness beatdown
- Help shuttn off wut the sh**
- Dammit! Not another headlight!
- Front axle assembly or wheel bearing? (pics)
- What color is this?
- 99 GSR Sedan buttery fly valve
- Rmf narrow headers
- b17 block with b18c internals?
- 91 integra b18 head
- 96 GS-R Cam Seals
- Header before exhuast?
- Classic IAC problem or more involved
- Erratic Idle Problem B18B
- 94 Driver side Door window harness Question
- RHD Conversion Question??
- Valve cover specs
- Anyone heard of a Type TI integra in Japan?
- ls oil pump o ring
