View Full Version : Acura Integra
- Price for my motor?
- bought my first integra =)
- WTB...Skunk2 Short Shifter...quick question...
- car is losing a large amount of oil, need advice
- cat rattle
- stupid question...
- My horn won't work
- how much would you pay?
- cost to put a k20 in a '00 dc2
- Who here bought their Integra new and still own it?
- spacers
- Part # for OEM head gasket?
- nos fogger system ?????
- Bad 02 sensor without CEL?
- FS and WTB for February
- I need lowering shocks for my DC2..ill buy in LA area
- Code 21 (VTEC Solenoid Valve) This a problem?
- B series Clutch question
- what next...
- grounding kits
- hatch with a b16a2 throwing coed 51
- lightened flywheel...
- instrament cluster
- 1992 Acura Integra GS with B16A throwing code 22, help needed
- abs light
- Tranny
- need some help, check engine light is lit up constantly
- water pump tools??
- espelir jgt500 on a dc ?'s
- speedo replaced still not working
- any one do a querter panel on a gsr (need help)
- stock injector specs??
- 98 Integra - Front Driver Side Water Leak at my feet
- pic of a DA with J-Mags
- my clutch popped out a spring....
- fog light
- Help Needed ASAP LCA Bolts ... i hate em!
- new setup tell me what you think
- Jumper harness required for a B20 engine swap?
- How To Change Header Studs
- weird overboosting problem
- Will this 3 point front strut tower bar fit into a DA??
- engine wont start
- trouble with starting 00gsr
- Went to Dyno finally.
- turbo questions
- i found me a virgin..
- non srs ITR horn button...searched
- Test pipes!?
- Getting to big for my integra
- gsr brake pads
- cam specs?
- JDM ITR header replica
- Start problem!!!!Video incl.
- Need B18B to B18C1 wiring diagrams
- Every resurfaced your head?
- Car stuck in park
- tell me if i can do this
- ls integra
- 2 motors: b16a and b18a. What to do..?
- is it the CV axle?
- Gasoline Smell
- Boost controller not working
- WTB DA brackets
- Cam Question for GSR Head
- Stuttering at 3500rpm
- WTB : A.S.A.P !!! ROOF RACK
- opinions:has this happened to anyone? rusted(N1)
- JUSTINS integra build
- LS/VTEC questions???
- iQuestion about my DC2's V-tec,,,and new pics!
- ctr camshaft in gsr
- Auto to Stick Conversion:90 Acura Integra 4-Dr Sedan
- maintenance
- Electric Oil Pressure Gauge Installation Question
- Dont' know where to put this...I'm sorry.
- MY TEGGY WONT START... HELP!! PLZZ
- weird reverse noise...
- DA9 gotta go
- Wheels?
- steering bushings
- LS Exhaust
- Rough Idle on LS
- skunk 2 full catback?
- window switch for nitrous?
- Hey im New, and i need sum tips
- rear valance molding?
- Looking for some ideas: Side skirts w/ JDM front DC w/ Mugen bumper....
- 94-99 integra gas tank???????
- Unsteady Acceleration - Help Please!
- p28 ecu in a 94 gsr??
- Driveshaft / axles - Did you go OEM, remanufactured, or aftermarket?
- 94 ls into gsr
- Oil drain plug.
- CEL 54
- N/A or turbo?
- Gauge Mounting in Cruise control or Light Dimmer switch location (95 Intgegra)
- How Much Did You Pay?
- won't start/Code 15
- If you need Floor Mats for your integra...
- 93 DA with obd 0 B16
- b20vtec into a DA
- Stock Sway bar and blox lca problems?
- Black DC Integra's on Gold/Bronze Wheels..
- idle screw wont adjust idle
- wont stop spinning bearings....
- RATTLING NOISE...HOW TO...
- Recaro Speed Mounting Options
- Apexi N1 turboed on a N/A teggy?
- B18 OverheatinG!?!
- Exedy Stage 1 for turbo?
- Integra Tail lights Interior gauge lights
- overfilling oil?
- oem vs sri?
- Handling
- Map sensor Clip.
- fuel cut off switch wiring question
- aem v2 cold air intake vs. comptech airbox
- What the hell is going on with my GSR???
- ATF Fluid question already searched.
- Need a favor from a G3 owner with an ITR rear strut tower bar.
- swaybar bushing brackets for JDM ITR 23mm swaybar?
- Part #, Rear Bracket Bolts
- TORQUE MOUNT???
- looking for wheels rota slips or group n
- im new here please help me out on how to use this
- My radiator needs refill everyday
- Integra modifications w/ itr internal? Questions...
- GSR
- 1995 Integra GSR DB8 Full Tank Mileage? Question..
- Trail User?? Mods can remove once answered
- 2000 gsr 1/4 mile times
- p28 or p72 ecu?
- B18 ?
- RSX exhaust tips - how much?
- Exhaust Question
- DA : What gas you put in
- 94 ls into a gsr
- Oil Pan Experts
- integra suspension???
- change my gasket or put a gsr head
- leaking need help
- 90-93 Integra axle question (searched)
- all motor Ls questions
- any shops in santa ana
- 95 dc2 throwing codes...
- Mileage//Odometer Question.
- Need pic of mugen lip on 94+ integras
- are omni power the only ones
- Car keeps dying
- new to the seen with HONDA-TECH... Just wanted to say hi to everyone...
- vin numbers on 97 dc2?
- post 92-93 gsr wheels painted
- 1997 acura integra taillight help
- auto transmission question
- type r/ prelude caliper brake swap??
- Radiator Hose
- J1 tranny
- ABS code 6-1 help please
- Quick Question
- need help , decisions decisions.. 00 gsr
- best engine for a beginer
- wich tranny is better for my gsr? si or gsr tranny?
- tranny lever loose
- delayed start problem
- WTB: GSR Block
- HELPPPPPPP
- need help:blox b camshafts, skunk2 cam gears, & rm valve springs and retainer
- Can you use bondo on urethane?
- Anyone got this DC-Sports Exhaust?
- popping noise from left front wheel
- 00-01 GSR DC header same as 94-01 GS/LS/RS??? Why Dif part #???
- Look for an Integra to take with me to LA for school.
- i got a speed ticket today.... what would you do if you got a speed ticket?
- Should i buy it? wrecked integra
- Replacing radiator and is it trans fluid coming out of the bottem plugs?
- Knock Sensor Question
- compression test results...
- does anyone have the 93 wheels on 94+ teg
- sup honda lovers...im new to the site....
- Funny story/accident/Insurance rules
- nitous question?
- DA honda emblem?
- P28 ecu used with a B20 engine swap?
- fogs and konis and GCs coming
- Need HT's Help(Is this shop full of shit?)
- integra no start problem
- axel install
- bolt ons for ls
- HOW GOOD IS B20? OR B18B? OR B18C? OR SHOULD I STICK WITH MY B17?
- b series cam gears
- question about tires....
- ls modifications
- what tranny should I run ?
- YS1 speed sensor
- brakes making squeeky noise
- Sparco seats, how to hook up belts?
- Napa Filter Cartridge for AEM Fuelfilter for GSR/ITR
- part search
- shor shift kit installation
- Radiator help
- td225 distributor
- Need part no. for thermostat and vehicle speed sensor?
- My Teggy is 1/2 assin it!
- Blower motor is done
- question???
- what you do today??
- Pic Request: TPS Wiring
- can i use this piston?
- 99 Integra Ls ECU help...
- map sensors is there a differnt
- Bolt ons to get more power out of a B16 Xsi
- Need Help Deciding Fellow Honda-techers
- I want to but should I (2Part ?)
- da headlights what are they
- skunk2 exhaust
- complete list ls vtec swap
- 2001 integra gsr, i need your help
- 98 spec itr steering wheel on 94 gsr
- Stock axles
- B16 tranny swap, vss problems?
- Window Switch Problem
- How do you adjust the projectors on a 98 GSR?
- gas pedal/throtle sticking
- Vtec question
- fijita filters
- 95 gsr vs 93 si(b16a)?
- Chipped P28? Do i really nee d it? See inside for more info!
- Turbo ls vs. ls/vtec what do you think?
- pull engine to clean, paint etc.. what else do ?
- Im New here and had ?'s about doin an LS VTEC conversion
- who's dc got stolen last night? cause i think i found it. SAN JO CA.
- zex nit.?
- Looking for a Service Manual Download for a 91 Integra
- blown Engine.... :( ...Few Questions ASAP
- need help
- how-to transmission fluid reup
- How can I figure out the year of my transmission?
- dc sports header vs comptech header
- Stock Gasket <--- Need help finding !!!
- weird alarm quesiton please help. alarm junkies read!
- K&N filter
- 4-pt harness install
- rusted.. stripped... o2 sensor... any idea's how to get it off!?
- Witch OEM B series cams are better???
- TB: Surf Rack
- Cold engine RPMs - not higher than idle
- What is up with this lip on my oil pan? Pic inside
- over heating problem ...help ASAP
