View Full Version : Acura Integra
- Honda Fit washer nozzle conversion
- LS Hydro Tranny
- will these injectors fit
- did bad alignment cause this? help
- Injectors not seating properly PLEASE HELP
- B16a into DA axle problems..
- rebuild the b17??
- B17 idle problems
- Keep getting CEL 91 on 96 integra rs
- 1990 integra LS problem..
- aem v2 installation questions
- Crazy day
- scraping noise while making turns
- Bolt broke and pulley fell off... Can you tell me what this is for?
- OBD2B to obd1 CEL codes
- DC2
- jdm b18c1 tranny code is what..?
- oil in spark plugs!
- DC5 itr brakes and 5 lug on a DC2...need help
- What flywheel is this?
- b16 running badly, odd problem, 90 integra, help please
- Greddy SP2 cat-back exhaust for LS/RS Sedans (DB7)
- High Idle Problem
- Oil gets black quick, burning oil.
- Cheapest place to purchase Sportmax??
- safe to drive with 2 belts? need help ASAP
- new here, not to Honda
- internal car antenna
- Requesting Sway Bar Picture
- Integra swap without hoist
- 1996 Integra H22A1 swap problems HELP!?
- starting to work on the teg again
- What did you do to your DA today? CONTINUE...
- Will K-series injectors fit?
- o2 Sensor Questions
- Broke thread nut inside inner subframe
- Car is acting stupid!! cant explain plz help
- personal steering wheel adapter hub
- ALL JDM FRONT INTEGRA OWNERS!
- changing the timing belt
- need some clutch advice
- torque specs
- Gsr tan cloth?
- non abs axel in abs car??help asap
- EL PEZ Build Thread
- Throwing 3 codes, MAP, IAT, Coolant Temp Sensor
- cant find ANYTHING to fit this coolant port??!!
- reverse lights help
- 94 GSR few things i need help with
- new guy
- type r shift boot in a da
- Retrofitted head lights
- 2000 GSR Test / straight pipe question
- knock sensor! p30 ecu help
- great deal on trade 95 civic dx for integra ls
- b20 turbo any advice???
- B16 Idles real high
- suspention problem
- Faded tail lights - refinish to look new?
- Please Identify this sensor, Vacuum Help!
- 91 integra oil light problem
- MY 95 GSR 4DR Build
- B18B1 LS Head Missing Rocker Arm Mystery!
- lsd tranny plez help
- bolts for engine stand
- What brands of exhaust are carb legal in most states?
- Is my AC compressor bad
- gsr fuel rail question
- 98-01 integra bumpers (2dr)
- Loud pop / grind / locking / help! (DA9)
- 98 gs speedo problem
- 98-01 integra rear apron lip fit 94-97 integra rear bumper?
- DA or DC??
- powerdoor wire up searched but nothing
- cold motor throttle stick?
- 95 GSR HELP
- maint' req light?
- b20b with b16 intake mani
- integra oil pan question
- center console for my da
- 96 ls, just picked it up 2 weeks ago
- big problems!! any help will be appreciated
- gsr swap into 1995 ls
- 1993 Integra Intake Question
- replaced clutch master cylinder now hard to shift and grinds at high rpms
- window probs
- gears are hard to get in high rpm
- CEL code 7
- oil pressure
- Axle change on an automatic
- rhd conversion???dc2 integra
- Taillight gaskets for 94 integra
- DA9 Door weather strips *PLEASE HELP*
- 1st gen acceleration problem!?!
- Replace whole Axle or axle ball joint?
- How to Make Your Car Last Twice as Long
- Changing the clutch in a DA
- HELP!knocking grinding?
- carbon kevlar trunk
- How are you guys gasket matching your t-bodies?
- 90-93 DA Floormat question
- rims size HELP
- 91 DA
- Cali CARB part info
- GSR Taking 15+ cranks to start
- New Guy
- 90 DA b18 turbo BUILD
- Radiator Fan wiring HELP
- h22 knockin
- brake problem
- Is it ok???
- what goes in this hole?
- Hytech replicas or Type R 4-1?
- RPMs are running low
- Starting Issues with my b16a OBD0
- Question about E-brake
- obd0 ecu problem any help?
- JASPER GREEN integra looksiee..
- Header question.
- integra surging ..possible iac valve problem
- Help me spend my money
- Intro
- iab delete and PnP?
- no fire cylinder #2
- Need INTERNAL Y80 torque specs
- Getting A Used '97 Integra Maybe, Need Car History Help!
- LSVTEC or GSR?
- need some help for a lsv swap
- 00 integra ls problem please help!!!!!!
- good shop to do a DC2 K20 swap???
- gears a little harder to get into 1998 gs-r
- will 95 integra dash work on 96 integra?
- 96 Integra Cranks really slow
- Coolant Changing half ass
- ABS light...w/ a goofy code?
- Can't accelerate higher than 15 mph and 4,000 RPMs
- Ideing problem on lsvtec after new timing belt .. help
- ef springs on my da
- Ta0301 on stock gsr
- tech question obd1 H22a swap in 95integra. please help!!! LS
- Oil filling up spark plug tube/cylinder..
- 94 integra going turbo
- Help me find a nice set of RIMs
- Anyone running itr rear sway bar with a brace?
- b16 wont run right; 90 teg, please help
- Anyone using a skunk 2 camber kit for dc integra
- 1994 Integra LS Reverse Bulbs
- Manual steering rack into DC Integra question!???
- ITR Mani install on B18C4
- How do I recconect the ABS sensor wires in the rear??
- rear brake caliper
- b16 head vs gsr head
- Recaro seat brackets and replacement parts
- What year gsrs are same
- 94-97 Foglight Switch
- What was your latest bill at the shop?
- Converting tan inerior to black Need help
- Fuel problem
- ELECTRICAL ISSUE(S) !! !! 95 Integra GSR
- AR CONDITIONER / HEATER COMPONENTS
- integra wont start because of the alarm
- So i have a rod knock, now what should i do?
- help with getting a new intake manifold
- 98 integra ls with greddy turbo kit??????
- ITR HEADER ON B18A1...o2 SENSOR
- OBD1 95 Integra with OBDII 00 GSR Swap - What Distributor?
- B20Z into a 90-93 Integra?
- Lost Integra key...had acura cut a new one...still wont work
- 01 DC4 squeak when cutting ignition?
- How do you know when you need a new flywheel
- Integra retrofit?
- need help cus i cant pass emissions
- Fender mirror on DA Integra
- Back in the game son!
- cl front end conversion?
- Installing AC on my integra?
- side mirror screw
- Rare? What are these wheels?
- suspension question
- DA Integra Climate Control
- b18b1 engine
- Door Lock Actuator??? What all do I need?
- POST YOUR SLAMM DB7-DB7 (INTEGRA SEDAN)
- NEED HELP ON 91 INT PARTS!!!
- MY 95 INTEGRA WONT START
- fuel injectors
- Oil Pressure Question
- opinion on spoiler
- power steering rack to manual?
- Help me with my '98 GSR
- Drivers side sits lower than passenger...WHY?
- is something worng with my motor?
- da auto trans in dc2???
- Blown head gasket from car sitting in garage over winter?
- towing with a 94 gsr
- Fantastic420's Need Help build. Need it running asap!
- OBD2 JDM Engine VTEC Issue
- Axles for 92 Teg GS.
- 94 integra RS using too much gas?
- stock LS t3/t4 hybrid turbo???
- windshield wipers dont work on intermidiate
- Teggy Problems When Accelerating
- DC Rack and pinion help
- check it picked up 91 integra gs
- my teg bogs down at 7k then starts hitting at 6k help me plz
- Can Someone Tell Me What Color This Is???
- spot welds broke loose
- Does the 2DR/4DR LS share same cat?
- swapped heads now fuel in every cylinder and wont idle
- Hondata S100
- JDMshi7 mounting screws
- Hood pin install on CF hood...question for those who have done it.
- Trunk leak still
- what tire size should i get for 16s
- 94 Integra wont start.
- help im sure its someting simple
- 1991 acura integra vehicle speed sensor
- Im a noob
- do someone know if this would fit? or help me find the part
- JDM Front end conversion, which cable to use for the hood latch?
- Idling problems with my 98 gsr
- i think i blew my motor?
- My 95 gsr needs help
- Help With Integra
- what clutch to use?
- 95 gsr integ problems.. help me out
- 1996 integra, with Jdm gsr tranny problems and idealing problems
- oil pressure
- hasport mounts, need some opinions U70A VS U88A?
- HELP PLEASE! i have a really bad water leak in my DC
- 99 Integra Problems
- where to get a rear window spoiler?
- New clutch kit suggestions?
- 94 integra plastic rivets in cowling
- soft, mushy pedal feel after clutch install ?
- rod question? which way tangs face?help!
- LS motor
- NEED HELP: Missfiring 94 ls no cell code....
- water in the gas tank please help
- fluttering rebuilt gsr engine
- ENGINE HARNINES OBD2A HELP. anyone dealt with this before.
- da integra heater no work!!!!
- clutch question HELP PLEASE!
- ef b-series mounts/ef gas tank
- Wheel Hop while accelerating. Tried numerous fixes. Stumped.
- Wanna Do Blox Cams. Missing Anything?
- "You know you own an Integra when........"
- 1992 Acura Integra GSR B17 info please help
- 95 integra gsr shell
- Interchangable parts ??
