View Full Version : Acura Integra
- To build or not to build...
- Why wont my battery charge...?
- okay to use regular oil after full synthetic ?
- DA question
- 93 teg, brake question...
- bumber wont fit with IC
- Fuel management for turbo
- WHAT DO I NEED INORDER TO SWAP MY TYPE R INTO A 92 INTEGRA
- Wuh bulb to get when changing color of the gauge cluster?
- H.I.D. blow up?
- Suspension Vibration
- Need to know what rpm you gsr guys turn at 60 mph in 4th...
- clutch master cylinder
- B16A1 FOR SALE 1200 O.B.O
- Please help! Alternator not charging battery!
- aftermarket oil dip stick
- How to test an A/C Compression out of the car?
- ATTN - tim-tim
- boostin!!!
- Clutch pedal stuck to floor
- side skirt help
- help vtec not working
- what distributor!?....
- how much power do these cars lose over the years?
- distributor probs
- A/C!!!
- *sigh*
- is there a difference??
- Replace Dash
- does anyone know if this right??
- What happened to my car? Rumbles?
- just got my 92 GSR, need some help
- need some help with a jumping idle needle...
- Opinion needed on DA9
- Rear Shocks broken bolt
- Need distributor
- will a car kinda idle rough and low with no pcv valve?
- CA car owners must READ!!! It could keep you from getting tickets or at least fight them.
- car wont start after compression test?
- Things to conside when upgrading your clutch.
- obx lsd?
- Vtec\Ls? Something horribly wrong here.
- newbie integra questions...
- Thread Pitch On Transmission Bolts on B18B
- VAFC owners reply need your opinions !
- no speedo
- luminics vs passwordjdm H4H bulbs
- The Terribly Mysterious A/C Pulley Bracket Broken Bolt
- Speedometer / Odometer Problem Integra 96 ls
- 96 prelude hub fit my 96 integra?
- bad alternator? ideas inside
- ABS question.
- freon
- Quick....which wire do i splice for a A/F gauge....
- NOOB here...
- ATTN: Gurus: (Almost) Stock Rebuild: Question 1
- Machine shop Toronto
- JDM core support
- misfire cylinder 2,3, and 4.
- CrUise~
- What oil to use for GSR
- quick ?
- GSR Swap on eBay - this one is odd...
- B18C Crankshaft Endplay
- Foam in Radiator and cooling system bad headgasket?
- is anyone using vredestein quatrac 2s?
- opinion, how easy is an Auto -> Manual conversion
- Anyone else?
- Quick question about wiring. (ECU harness)
- GSR swap
- ::quick idling/rev question::
- 90 Integra LS intermittent starting problems.
- problem with AC blower
- 95' Ls V-tec Integra. Vacuum Problems???
- 98 integra front end(what is needed for swap)
- how to Clear CELs
- GSR swap into a LS... help...
- VTEC an automatic integra
- obd2 gsr manifold....will it work with my obd1 gsr motor?
- intake manifold question?????
- jdm type r cluster..
- car wont go into gear
- Deos it make sense?
- How to...?!
- how to adjust idle
- Unknown Intake System
- Jdm Blue Vin Plate
- Shell Cost
- oil leaking from head
- clutch for 01 gsr
- Integra Drivers....How big are you? Height? Weight?
- Stolen Car *please read*
- I got sent to the REF
- ubredata
- Trust this Universal Muffler?
- teg stalls out when i give it gas?? help
- B16 in DA9. Is it a good idea?
- itr
- 93 integra broke t-belt
- how do people NOT know such basic info?????
- how to convert my 96 bumper to the newer 98+ style
- rc injectors?? searched
- Springs...just need an opinion
- what coil's will work with my obd1 94 GSR distributor?
- i hate american cars
- Installing AEM short ram intake
- usdm type r valve cover
- '94 GSR Head 4 SALE
- some problems wen swappin in lsvtec for my obd2 gsr...PLEASE HELP
- 97 B18c1 Horrbile Misfire
- cluster problems
- Slammed DA ride quality....
- popping
- WHAT TO DO NEXT?
- HELP!!! Heat behind dash and under shifter console?
- Shaft HELP!!!
- wheel bearing
- Dash Change...Cluster Help
- AEM CAI
- ABS bracket/line in way of lower tie bar bolting in. Help Please :D
- Spray Paint or Dye for Carpet/Vinyl
- so i'm drivin along and then....
- Other Integra Forums.........
- What is Legal... ?! as well as smog
- Need help with 1 more item...
- 15 inch tires for integra, what size?
- type r/sir-g front end?!..
- ITR Flywheel pins removal - how hard is it?
- installing neon tube help????
- Cam caps!
- How rare is factory EQ 87 Teg
- what to swap??
- Good Tinting place's in So. Cal, post experience location, price, type, shades and pictures
- Really wierd tire wear!! Help!
- ls/vtec --what to use for maintaince
- water in taillights
- compression results gsr
- Integra tan leather seats? worth selling?
- Taking a trip to texas in my 91 teg, what kind of tune up should be done? HELP
- Spoon Strut bars
- Speakers
- Car wont turn over...help
- What Should I Do??????
- passing smog with jdm type r motor
- 04-05 tl hid retrofit in stock headlights?
- Detination
- clutch got soft?
- apexi avc-r help???
- DA Teg not driven for a while. NEED SMOG
- ecu questions
- 90 integra question and 92?¿
- B&M Short Shifter Install into a 00 teg GS
- iab help for newbie
- smokin bad
- motor swap
- do motor mount inserts make a difference for launching and what else ?
- idle cycle not starting
- Need help with fuel problem
- WHY IS EVERYONE OBSESSED WITH GSR BLADES????
- My 91 integra runs like crap
- Turbo Exhaust
- Probelms With Cyl #2
- 150 mph + integra...?
- Would you Fix it?
- Look at my brand new header, is this a defect?
- Black or Charcoal Grey on a 95 Integra 4DR?
- integra lower lips
- quick hp??
- Failed smog at the CA ref
- brake leak need help?!
- rattlering in the intake manifold????
- Longblock too heavy?!
- bouncing idle need help
- swappin out an alternator
- gsr headgasket same as all b series?
- Good tranny? 1993 YS1 GSR cable tranny with Quaife LSD
- hey guys check out my gsr type-r conversion
- Project: My First Motor Build
- 91 Integra PR4 ECU pinout doesnt match the car im working on?
- ebay water pump
- DA console
- Pin-Lock for crank pulley...Reusable??
- my friends transmission problem..
- FULL RACE Turbo products... opinions? Experiences? Comments?
- Low oil pressure.....Won't engage Vtec...????? Please help!!!!!
- 95 Gsr quarter mile
- Anyone with a b20 stroker kit? or b16 crank???
- Difference between LS and GSR front seats?
- Transmission Switch Parts
- cant find mtl
- "Please help me w/ mph......"
- other ways to accelerate faster
- 96 GS-R hesitates intermitently when warmed up
- Exhaust
- HOW IMPORTANT IS CAM GEARS AND CAMSHAFT?
- Type R Rear Sway bar on an LS
- is it true a BONE STOCK motor can........
- identify this part
- Getting into the honda scene.
- Omni Vs. Tein
- steering problem?
- How many miles does your gsr have?
- PA Inspection, OBD-I in a 2001 GS-R
- Lowering My 91 Integra
- "trial" user
- NEED RACING AXLES
- DC2 Front strut
- Thermostat going bad...
- To make a hatch exhaust work on my sedan...
- ignition switch
- obd1 p72 info neded (searched and looked through the FAQ)
- steering wheel question
- car won't start after resting for a while
- wheel bearing question between da+dc teg's
- Buddy Club Pro-Spec
- What are Dowels???
- Power locks & components in RS
- ANYONE IN THE BAY AREA can CHIp my ECU i have tHE KIT ALREADY all i need labor done!
- Random stalling on idle help?!
- Starter bolt
- Phearable.net- Any dealings with them?
- some new picz!
- Goodbye Dc2
- b18 stroker
- new here!!!!!!
- Power Antenna clicking noise when going up and down...
- Rattling
- Best Way To Boost A B18A
- Bulb information.........?????????
- New to the site
- Whats the best way to get out dents and scratches?
- Rattling
- Racing Sports Akimoto needs a donner K-series powered DC for test fittment
- OBD Problem...any help is great!
- Wheel boot
- 96 GSR Under Dash Wire Hareness
- Questions about transmission!
- GS-R Screwed by my Distributor! What should I Do?
- my klaxon horn is gone. what part do i need to get?
- Spring set-ups?
- gsr blades (wheels) question
- Difference between USDM and JDM 90-93
- mods
- Tranny
- signs of a dieing fuel pump?
- dizzy problems
- Please help...LS smoking problem TIA
- Oil leaking... need advice on repairing.
- weird idle at stops... searched
- vtec head!!
