View Full Version : Acura Integra
- b16a2 into a 95 integra?
- buy new PR3 head or used?
- GSR EXHAUST!
- 5 lug conversion
- Hello im new
- hello everyone!
- Need Help ASAP with ARP head studs/bolts!
- 02 Sensor Question, Front
- Are these reasonable prices ?
- car wont start
- OEM .vs. Cheap Plastic Material Bumpers...
- New Integra, Need a little advice
- Type R Lip anywhere?
- Slips Vs. Blades
- looking for lips
- No spare Key? ? opps
- jdm itr heat shield
- fuse problem
- temp sensor
- miscellauois
- Another Main relay question
- passenger side axle or tranny issues
- quick question. OBD2b or obd2a??? 97 integra
- wheel bearing help
- LS Ecu In GSR Swap
- Dieing Battery!!!!!
- Decided to go turbo one questoin
- jdm front mugen conversion?
- will obd2 GSR intake manifold bolt right up to ob2 LS?
- diff in integra front ends??
- oil light blinking
- One big electrical problem...
- Door/light/seatbelt sensor ringing for no reason?
- Is this a fair price for this integ?
- Okay, now does anyone have any rear valences for sale or know...
- knock sensor on an OBD2 integra (97)
- DOnt want my car being Crushed for stolen engine...
- Lost power steering
- quick question about the gsr intake manifold
- B20b into a '90 integra running lean getting a 43 need help
- online owner's manual free for viewing ???
- how do you change out cap and rotor?
- help w head unit installation...wiring weird
- let me see those hid's
- got a question on tranny and high idle
- MY TEGGY DOESNT WANT TO START!!!
- brand new clutch
- New and need some help and opinions.
- auto to man
- maintenance required light wont turn off
- should i buy this gsr
- BAd battery terminal wires??? Teggy-starting problems.. HELP!!
- looking for help w/ new intake, trying to buy catback exhaust and headers
- Can I somehow put a 2001 ignition into a dc2?
- what oil fitting for turbo
- Wont go into gear
- Smog time, opinions on a cat
- LS Vtec help
- main Relay?
- GSR Cluster
- Speedometer works only when I punch it
- seat install help
- ls header in gsr
- Just bought a turbo
- lowering my gsr
- how do i adjust my coilovers?
- Oil light flickers, comes on dimly, intermittently
- pcv hose gsr
- auto / manual vss the same???
- Lowering suspension
- DB8?
- rsx/teg suspension differences
- new to hondas had some wuestiong about my integra
- trunk latch problem
- Differnce between B18A1 and B18B1
- Wiring challenge 4 you guys
- questions about my VAFC II
- need help with head light
- old gas...
- Racing Hart C5's on GSR
- Match revving (aka heel-toe shifting) in an Integra, anyone with difficulties?
- AC fan and radiator fan doesn't stay on
- radiator fan malfunction
- PDF Service Manual/ Helm
- I thought I knew what i wanted to do to my 98 LS...
- JDM ITR front conversion ... Are fender brackets needed?
- gauge cluster not working
- LS Vtec Help
- a/c problem
- trans help
- best ecu chip
- greddy ti-c?
- Turbo install - radiator fan swap to front
- radio anti theft codes
- The rebirth of a stolen gs-r!!!
- New Mod List
- tranny swap
- let me see that H.I.D.
- Tranny fork problem!
- ys1 tranny
- After a hard pull, leave in gear or coast in neutral ?
- HELP>>New swap (LS/VTEC)..now car won't start
- crashed ls
- fuel sending unit?
- 2001 integra motor in hatch, need help with tranny fluid change.
- changing transmission fluid
- GS-R Sedan or ITR Engine Swap in a GS Sedan?
- 95 gsr redlining?!
- 1990 Integra LS overheating issue
- tps sensor and aftermarket throttle body
- need my brakes bleeded or master cylinder??
- Could i put a 98+ ITR engine in to a 97' GS sedan?
- gsr tapped oil pan with no turbo. is that bad?
- Is a Hitachi ignitor compatible with a NEC ignitor?
- *** ok .. searched but didn't really fine a straight answer.
- upgrade help !!
- Temp gauge acting weird
- Which Camber Kit to buy?
- Possible driveline problem?
- ls-v with a b16 head better with gsr cams?
- I need help
- Something Wrong with Car Speakers.. Please Help.
- hood won't pop, help
- Freshly built engine break in using what ECU question? (already searched a lot)
- Spraying on my LS
- Intake Manifold help needed
- SRS light on
- GS-R emblem location
- HELP: Axle stuck gsr
- DB8 Rear Seat Lock is Stuck and Won't Open
- Weird Grind noise at 3000 RPM
- boost question
- horn doesn't work
- ACURA INTEGRA GSR VS 91 HONDA CIVIC B16
- Passenger Power window trouble
- Coolent temp gauge problem?
- 96 LS some problems, new to site.
- door ajar light off when door is oen
- DA horns not working???
- hey guys im new!
- HELP!!! Integra sunroof
- DA Axels same lenght?
- ABS leak....Help needed
- Lower Alternator Bracket
- y isnt vtec woring???
- Check Engine light, and oil light blink simotaneusly....'94 ls///// transmission fill
- Vtec not working
- think of getting.......tell me what you think....
- PBD-0 PR4 Question
- 1995 Gsr, Should I buy an Intake, or not
- gas tank touble..HELP PLEASE!
- integra motor
- Cutting GSR wiring harness?
- Attempted wire tuck, looking for a better wiring diagram....searched
- 90-93 RHD DA6 Honda Integra RSi front clip
- power steering vs no power steering
- ITR axels in an ls?
- HELP!!!! car wont' start
- sythetic oil question
- integra for sale
- VTEC Kick In?!
- Installing an O2 Sensor
- Should i sell it or restore it
- What T/W
- safe rev limit on jdm b18c
- gsr turbo kit help?
- Leak down test issues.
- Head lights?
- SKUNK2 SPORT SHOCKS SET
- Cleaned IACV, what else could it be???
- gsr with SI wheels
- Rear motor mount replacement
- rusted brakes (i drive car once a week if that).
- TPS sensor CEL
- What traction bar / lower subframe are you using for you DA?
- CODE 43 FUEL SUPPLY
- Car burning oil
- 1994 DB7 w/98 GSR swap
- Fuel Filter help
- Axle Question need help ASAP!!!!
- exhaust??
- manual transaxle oil for integra
- Passenger window won't go down on 93 GSR.
- i need help quick!! O2 sensor wont come off
- lower timing belt cover bolts???
- Door Lock @%%#!
- Drag Track
- buying the whole rear bumping assembly
- has spark, no pulse on injectors?
- Howling sound coming from my head
- DA Master Cylinder Question
- what part is this??
- stiffy mounts?
- i need help! emission problems.
- what is the difference between the gs and gs-r
- coupe window the same as sedan?
- Help...
- struts
- Replaced cams, now car will not start. Will be taking a bat to engine in 15 mins.
- vavle cover has a small crack
- how much dose it cost for a 90-91 integra tcm
- Oil Pressure Sensor casting snapped!! Need help!!
- 9005 and 9006 connectors?
- FS B18C Parts
- Cold Air Intake?
- supercharger/turbo charger help.......
- changing bulbs in a 95 integra
- Car dies, ignition problems?
- Fuel keep going low!
- Thoughts on adding this......
- cracked tranny
- installing tranny
- HOW to remove and replace A/C blower?
- what are the signs of a slipping clutch?
- Need Help. Check engine light on!
- Need a Little help on some stuff...Integra GS-R
- 94 integra gas tank trouble?
- how to remove steering wheel?
- How high can I go? (rpm)
- Another, "my car won't start" thread (DA)
- Keep burning my gasket between my high flow cat and exhaust.
- Help....oil leak from tranny
- new timing belt?
- B to K transmission....
- OBD2 with header and exhaust question
- differences in CAI
- engine swap
- integra oem optional advice
- replacin valves should i replace cams
- Integra Type R vs. non-R side skirts: debunking the myth
- turbo or no turbo???
- [searched] how to remove rear brake line
- reverse lights stay on
- probably a dumb question...
- electric problems
- 91 Integra B16 Alternator Question?
- defrost probs
- DA wont start! Need help!
- LS/VTEC fuel problems HELP!!!
- pulley system gsr
- srs light
- throtel probloem
- SHOULD I BUY A 1993 GSR AZTEC GREEN INTEGRA (RICE)
- Just got a 96 GSR
- help with rpm tach.
- Dc2 Code P1359
- How to remove spare tire? Not a noob question
- p28 ecu
- alternator pulley help!
- Blown radiator? Replacement blown too!
