View Full Version : Acura Integra
- 98 INTEGRA GSR FOR SALE
- EG exhaust on a DC?
- My Car Died... Help!
- turn signal/headlight wiring harness.. question
- Cam GEARS questions
- 3rd gear grind
- DC4 tranny is thia lsd
- Wanting to make an exhaust louder
- how much boost can a gsr handle?
- whats better for the teg ls
- WOULD it work?
- 94 gsr code 43
- My catback fall off today while driving!
- 91 integra ls help needed.....
- So i got my lip and Studs today :D
- Yea so here's something new, I'm stumped.. (Help me HT!)
- 94-01 teg tein suspension kit
- ABS speed sensor. Searched
- battery relocation kit???
- Should i install a turbo in integ LS?
- Phillips HID
- any pics of cars 3 wheelin...
- Type R to GSR throttle body swap problems please help
- crankshaft and camshaft seal question
- Fender Liner (JDM vs USDM)
- ECU HELP NEEDED........
- Need help with climate controls
- loading suspention using traction bar
- Good bye guys!!
- gsr head itr block
- 90 integra LS - no pedal pressure and its hard to engage into all gears
- Taking off the butterfly plate
- who had done a k20 swap
- 97 LS head onto b18A1 converted to obd-1, any changes needed??
- WTB ys1, j1, y1, etc
- wiring help!
- STOLEN MUSIC! PLEASE HELP
- My car won't pass smog!!!!
- gas tank interchangeable from 94 to 01 seden to hatch ??
- cable to hydrolic trans
- clutch question. any difference between gsr and ls?
- WTB 90-93 integra front lip MINNESOTA
- Axle question!
- How to tell motor is OBD1 or OBD2?
- skunk2 IM stuck, fitment issue
- Wire diagram of how to wire up a b16 in my 1993 Da .
- DC sports website?
- Ignition question
- top rev without a blow out
- Im a noob to ht...and need help!!!
- 92 gs-r header? what fits?
- Fuel Filter Mounted Pressure Guage
- welp stuff got jacked...
- given this scenario, what are the chances of damage being done?
- Vss replaced now what???
- Question about Tail lights
- Fast DA's!! are they out there?
- ECU Question. obd2 p3f ecu but plugs are obd1
- bouncing rpm on turbo b18b interga
- What is the difference between Main And Head Studs?
- Electrical stuff
- BOOM! axles broke.
- turn signal wiring
- Interferance Motor
- Is this what a bad clutch does?
- going to check my compression
- Which brand sway bar?
- Need Help! dont know were 2 bolts go?
- how long did it take you to buy your integra
- fuel problem
- Silverline Mufflers?
- The LS & GS-R
- turn signal wiring harness.. wtf?
- HEAD UNIT HELP!!!
- link for how to:
- 99-01 conversion and trans questions
- primer removal help
- Are Inner Tied Rods Replaceable?
- gsr long block
- da cluster diagram
- Searched but can't find what i was looking for. Coolant problem.
- e-brake handle
- axel tools ????
- CEL code 90
- Help car keeps overheating
- How much are my gsr cams worth?
- Will a B18A1 go into an OBD2 chassis
- Apexi Dunk Exhaust
- Automatic to B16 Tranny Swap
- Pistons replacement
- VTEC and NON-VTEC distributors the same?
- how to tell the difference between ITR and GSR and LS Oil Pump?
- New to the Integra scene, help me out with some ???? please
- 92-95 civic fogs onto zenki bumper (94-97)
- door window problem.......
- b18b gsr tranny....
- idle problem
- Question about h22 swap
- HELP! differences btwn b16/gsr automatic and ls automatic
- at to manual trans swap trans mount
- Distributor Cap/Rotor Question, 90-91 vs 92-93 vs 94-01
- signs of my headgasket goin??? need help!!!
- I Need Some Trans Help
- power antena....
- CAM Specs!?
- Engine temp & revving issues - supercharged manual LS
- ABS Problems....help please!!!
- rear wheel bearing.
- gas tank removal.
- timing belt off 1 tooth!!!
- Best Opinion On What To Do With My 93 Teg GS With 186k?
- speedo question
- cruise control (removal)
- i NEED HELP!!! How do u hook up vtec
- Possible to clean 90-91 tailights?
- My integra..PICS let me know
- What are the minor differences in the '94-'01 integras
- Is this hood fixable?
- Integra transmition
- ABS problem in snow
- question about spoon N1 exhausts
- G2 Integra Exhaust Suggestions
- Engine Problem???
- What kind of build would be good for a B18C1?
- How do you remove the cruise control thing on the steering wheel?
- b18a1 port and polish heads
- LS plug wires work on gsr ?
- ITR tranny on a LS
- piston/bore ???
- question about 94 ls 4-door brake control module problem
- rainguards?
- trailing arm bushings
- How much is my teg worth?
- jdm latch cable?
- exhaust hanger brackets.
- Aftermarket wheel install info
- Testing Injectors
- does anyone know part # for this?
- swap
- JDM ITR HID Projectors
- dc2 sidemarkers template HELP!!!
- maintnence light?
- Thoughts on Key Stuck in Ignition
- Clutch Problem
- Will a 13" steelie clear the rear of 94' ls brakes?
- has anyone made a adapter plate to use a vtec intake manifold on a ls or b20?
- Replacing Oil Pan Gasket.. Pattern?
- Lift Support for Hatch 98 Integra. What size in Universal Lift Support?
- engine stand bolts (searched)
- IACV cleaning didnt work!!
- AMSOIL MTF for GSR tranny
- Fuel, air, and ECU
- Need ecu picture p75 ecu manual
- Oil dissappearing?
- want to buy a complete head for b18a1...?
- RMtracking.com GPS tracking....anyone hear about them?
- funny noise from air con.
- ECU fuse keeps blowing even after changing the entire harness...plz help
- LS and GSR headers/exhaust manifold same?
- Need some input on a slipping clutch problem
- tach help
- 98 GSR stolen... :(
- jdm front end
- springs installed incorrectly?
- Unusual Coolant Leak.
- Skunk pro series versus regular skunk camshafts??
- oil???
- Question about the bottom block....
- replacement front bumper, hood, windshield, and front fenders.........costs?
- oem fog lights
- LS: When setting the timing...
- Chipping a LS and a turbo question
- insurance help
- Turbo Charge an Automatic 95 Teg LS?
- amber film
- converting 90-93 integra to manual question?
- where can i find this part
- LS motor. Replace head w/DOHC.
- dust cover missing from tranny, how bad does this flywheel look?
- car warm up then die what could be the possible cost??
- which spark plug to get for 98 Teg LS?
- HELP. please
- Jdm Front
- Integra GSR DB8.. Help
- fuel line diameter?
- Oil on Sparkplug?
- Insurance trying not to pay out for my stolen car, please help!
- need some advice on b18a1
- radio code will not work
- 99 gsr tranny need help ASAP...
- Screws for rear bumper
- knock sensor
- teg wont start, distributor cap?
- intake box?!?!?!
- is this good???
- NEED HELP *ALL SLIP NO GRIP*
- okay to mix and match shocks?
- 99' b20 in my da
- Just noisy....
- ACG IG fuse short?? where to look? PLEASE HELP
- i am having a few problems
- What Wrong wit my tegg!!
- Dashboard removel on My da ??
- part number for integra rear mudflap hardware??
- Where to get my ecu chipped
- name this lip
- I want to run mid 13's !!!!!!!
- Anyone Know How to reset the Maintenance light?
- hi flow cat?
- New Engine Questions
- valve cover gasket?
- NO VTEC...MOTOR CUTS OUT AT 5000 ROM Could u help
- ordering my new exhaust tonight.. any suggestions??
- Are db 650 and db 690 Polk Audio a straight swap?
- help!! ball joint REMOVE
- injector flow rates?
- does this look good to you people?
- antenna removal.
- type r interior
- SMSP Catalytic?
- abit of assistants plz
- 1g teg stripped down weight?
- what to do next
- Check Engine light on --> 3 Codes: P0112 (IAT), P0450 (?), P0453 (Fuel Tank Pressure)
- I have a question about Header/cat/exhaust
- OT: 20070119 Marks the 10th Anniversary of Owning my '97 GSR
- Seal Saver for B-series crankshafts
- DA exhaust
- tachometer going nuts...
- Will a DA9 catback fit a 4 door DB1?
- My new car!!
- NEED HELP with my Intake Manifold
- B18C1 w/ Hondata S200?
- 90 integra automatic shift problems
- Testing Water... What should I do? Type R Clone (Many pics)
- buddy club v-con on a 2000 gsr?!?!?
- Motor swap ? need help fast wont start
- Helm's or Chilton?
- Is it possible to purchase wiring pins?
- gasoline smell in oil...
- Valve Train Noise
- 1993 Acura Integra, Comments And Suggestions Welcome
- noob with a noob question HELP
- Mild leaking head gasket??????
- DC cluster in a DA?
- DC4 with Leather and a Sunroof??
- Need pics of Oil dran and filler colts of the trans
- Taillight problem
- question
