View Full Version : Acura Integra
- Brake problem
- eradic idle...HELP
- Where's the pin on the ecu for the vtec pressure switch?
- 2 or 1 resonator?
- Jdm Acura parts for a 4 door.
- honda/acure LCA same?
- Cluster Problems
- DC2 Rear Winshiled Wiper! Please Help!
- Tokico HP Blues
- bypass vaulve for aem v2??
- Problem with intsall of springs
- o2 Sensor problems
- signs of blown headgasket?
- About upgrading a Flywheel and a New clutch kit
- Please help my identify this clutch disc...
- ECU code 20&23 on jdm b16 92 RS
- Where to get Coil Overs?
- Does anyone have the Halo lights?
- need b18a1 wier harness
- will a 98+ integra front bumper fit in my trunk?
- Quick question
- Energy Suspension Hyper-flex Bushing Kits
- tranny mount?
- B20B vs B18B throttle body...
- I WANT ONE OF THESE! Anybody know where to find them and the model they came on?
- So I had a horrible oil leak, I've never seen anything like this.
- radiator leak..
- Ground Controls Or Skunk2's?
- conversion automatic to a manual......is it really worth it???
- Will an Integra hood fit in the trunk?? Need help ASAP!
- Camber Kit
- throttle body
- johnyracer intercooler pics?
- Front Clip Welding in Northern VA
- got 2g's, what should I buy
- where to get this?
- integra Motor w/ highest miles?
- soundclips of cherry bomb reasonator with muffler??
- y80 Transmission confirmation
- New Guy here and have a question
- whats the fastest n/a gsr?
- Door/Handle problem
- ls IM on b20
- is the shift linkage suppose to be loose?
- Adjusting a Hydro clutch
- shift linkage slightly bent?
- Anyone know where i can get Racing Hart 16 in Gunmetal CP10s for a good price
- quick rear lower tie bar question:
- Acura Shop manuals
- integra turbo setup ideas
- does anyone know where i can DL the helms manul in pdf for 90-93 integra???
- Possible all motor setup here....
- GSR CAI
- exhaust inlet size, what is it???
- maintainance required light flashing
- SoMe PiX oF mY rYdE!
- JDM integra websites
- manual conversion
- What is the Differences Between the ....
- how far can u lower ur car be4 u need to get a...
- how far to lower before you have too...
- catback exhaust weights
- Brake Problems. Quick Question
- b17 turbo build
- Should i Install Clutch/Flywheel now???
- WTT/TT: trade 03 Civic ex rims (same as 99-00 si rims) for other rims (socal)
- Here are the dyno results
- How long will I last with a leaky clutch master?
- Suggestions w/ changing my Tanabe to RSR Exhaust
- RHD conversion cost
- How to get a ZC DOHC tranny to work with single cam axles?
- Venom Fuel Rail-Think i bought WronG one
- O2 wire
- can't hear vtec with new exhaust
- Suspension for racing/show???
- Removing OEM GSR spoiler
- anyone have any teg 4dr seats leater
- Koni Yellows
- Integra bilstein shocks with skunk coilovers
- hey im picking up a gsr tomorrow
- New Car Need Help With My Jdm Front End Conversion.
- ECU codes on 1989 Integra LS
- Fujitsubo Exhaust...
- crx radiator in da??
- LS crank in my GSR block???
- Type R Shift Knob
- anyone with exhaust clips driving by?
- Integra problems! (LS with GSR swap) Please help.
- Ripped off on Ebay need help!
- Putting head together, Helms anyone?
- Gas Leak!!!
- NEED HELP ON CIVI FOR A 16 INTEGRA ENGINE SWAP
- ignition control module
- UPS + Mugen = Me and Teg HAPPY!
- LS/VTEC serious issues..
- restriction????
- Will A JDM Si cluster from a civic fit?
- oil feed line
- help -_- need some bolts
- Teg still not starting
- HX wheels on teg?
- Rubber Covers for Springs
- cel code 67
- Bushings upgrade
- Anyone have pics of Milano Red w/Azect Kit?
- Help! Can't figure out compression!
- I have searched------bogging when weather is hot........?
- Someone needs to make an SIRG lip for us...
- motor and tranni noises?
- My car is making a wierd noise!! scaring me
- I'm getting a LS LongBlock....
- 2nd GEN Window Visor/Rain Guard??? Ventshades???
- GS/GSR parts Interchangeable?
- Buying an integra..??
- do they make an oem kit for 94-97 integ's?
- Speed Sensor???
- Will 98 civic ex 14 inch steel wheels fit on a 98 gsr?
- what kind of cat-back is this?
- brake light came on the dash board
- Poll: just tryin to see what % of us drive g1's, 2's and 3's y0
- ITR throttle body v. GSR throttle body?
- car is eating up gas!!!
- ***New to the Import World need help ****
- anyone do a valve adjustment for me in the 909 riverside area?
- real function 7 lca's? pics!
- silencer removal??
- ABS MODULATOR REMOVAL 94 TEG??
- Wiseco 8.5:1 pistons (B18c1 turbo)
- 3rd gen GSR into 93 LS???
- JDM Front Conversion
- HELP STOP THE THEFTS.
- strange electrical problem
- possible to fit a 6' 8" surfboard into my car?
- ignition coil
- Anyone in Maryland going to MIR?
- Apexi WS exhaust??
- New to Forum and Integras
- intermediate shaft grinding noise?
- Cant afford expensive exhaust, Knock off way to go??
- Clutch gone bad?
- 90-91 and 92-93 clutch difference?
- Cincinnati anyone near?
- 96 gsr shell for sale
- b17 / p61 wiring pinouts
- Best "Bang for Buck" b-series?
- header problems
- runnin rich correction?
- Engine Wiring harness Fitment?
- GC coilovers from ebay????
- Code 9 how to fix???
- PROBLEM WITH MY B20BVTEC PLEASE LET MEKNOW IF YOU HAVE THE SAME PROBLEM!!!
- aem cold air intake.
- magnaflow vs greddy sp2
- shops to do B18c or B18c1 swaps in bay area...
- Will 14" Miata rims fit over GSR brakes?
- Changing from Automatic to Stick
- torque converters.....
- yokohama es100s?
- STOLEN: integra (604 area)
- pics of my DA chassis Integra **dial-up warning** (perhaps?)
- tuning estimate
- Oil Pan... Use gasket or silicone?
- Crazy police chase video...
- Question: Replacing hatch struts...
- are 4-point harnesses unsafe?
- Sounds like lifters are going!!
- Tranny Fluid?
- Transmission Problem
- jdm center console question
- Need ideas on how to adjust the clutch
- hey fellsa new here and my weekend track times
- difference in cat from 94-97 integra rs/ls and 98-01 integra rs/ls
- DA or EF radiator
- spraco or stock seat
- and so it begins... suggestions for b20 build up
- What should i go with?
- Help, Should I sell my car?? Auto tranny not fun
- Crolwer Cams, and what I need
- gsr guys with secondaries
- white smoke coming from new exhaust
- Problem with obd1 94-95 LS distributor?
- GC w/ Koni Adjustables or H&R Race w/ Tokico Illuminas?
- cherry bomb resonator??
- gsr 92, b17a1 time slips ???&?
- Best headgasket?
- Gsr Injectors and fuel rail on an LS motor?
- 1989 ACURA INTEGRA code reader
- crap...pulled my car in the garage and hit the damn workbench...see the pics.
- bent valve?
- On the 99 Integras what's the difference between the LS & GS
- help with momo hub
- stiffest decently price coilovers?
- 94-97 fenders
- Installed new dashboard (NO BLINKERS! =/)
- Radiator Leaking
- Hi Flow Cat
- Am I losing power with my icebox?
- i guess it was my turn.... let me know if you have any information
- Motor feels like its going to die
- Replacing complete wiring harness?
- Installing Neuspeed strut bar...
- HID experts, please help.
- Wanna know what an apex'i n1 sounds like? click here.
- Failed E-Test, what's next.
- Brembo Drilled, Slotted, or Blank Rotors?
- What Compression Ratio are you Running?
- RSX Shift KNob
- lower strut bolt question
- integra timing belts
- CAM GEARS ON A GSR
- timing problems...need help
- Q: Replacing Piston Rings
- timing issues.....tdc?
- my climate control (hot/cold) bulb blew out?? free 5dollars at radio shack
- Firewall plug?
- problem with cluster
- 1990 Integra GS Coolant Question
- 2-Layer Headgasket for LS? Can I modify the OEM gasket?
- New to boards with some questions
- 1999 Theft recovery question
- OEM ITR lip for DA's
- Ebay coilovers???
- Exhaust for turbo'd teggy LS????
- Quick tranny question
- FS: USDM Type R Integra interior MINT (PA)
- Help. Whining sound whenever I put the car in gear.
- Racing clutch for sale
- Hytech axelback
- Searching for good Northern California shops that swap engines
- what tires are better for race and stability ? 195/50/15 or 205/50/15 ?
- Why does car drive like shit with A/C on?
- PCV routing on 00' Integra LS HELP!!!
- my new setup
- Speedometer gear on Quaife LSD 94' Integra LS???
- I need VAFC instructions
- i dont understand this
- 92 accord wagon - rear hatch wont open
- stolen teg's - where are you from?
- all motor(i think)
- strut bar * * *help
- all 3 lca bolts seased?
- What materials are needed?
- Popping/backfiring while cranking motor
- what head gasket?
- Smog check?
- itr ecu with a ls vtec?
- Steering: Rubber boot imploded?!?!?!
- JDM B18c1 GS-R (sir-G)
- Integra Finder Help
- Car hesitates real bad when I press gas.
