View Full Version : Acura Integra
- civic strut bar
- quick question.......
- How do i turn off the Maintance Required light?
- For all DA integra lovers
- Ls turbo boost gauge reads 2 psi on 9lb of boost
- Who has whistling intakes on their car? please Vote
- Mugen Exhaust
- Buddy Club spec 3 cams or Skunk 2 stage 2.... anybody have them??
- aimco nnk(nippon) clutch kit vs exedy???on a 94-01 dc2
- Block Drain Plug?
- ES Tuning Muffler....?
- common heating problems with b18s?
- 92 integra gsr --> front end vibrates on acceleration, NOT the axles, what else could it be?
- s300
- B16 Timing Belt too loose NEED HELP!!!
- Oil Cooler?
- 95 civic coupe catback fit on DC2 integra?!
- Tire size and Advice needed
- what distributor cap and rotor do you guys use?
- transition into vtec is rough... please help
- Need some advice for a DA integra
- what rpm do you guys take your built motor to????
- B&M fuel pressure regulator
- rebuilding motor please help
- Tranny fluid????
- gsr shift linkage
- new motor?
- oilpan
- DA owners
- Worth it?
- gsr oil in cylinder 2
- xtended lug nuts
- Antenna wont go up (help)
- speedometer not working!
- REAR BRAKE CALIPER
- DA is howling!?
- Fuel Help???????????
- should i cut ?!??!
- what do you think about this one
- Headlights...
- Rear Brake Rubbing/Brake Pad adjustment?
- not new...just never had this happen before...
- 98+ rear bumper on a 95?? please help
- is the 90-91 Clutch different than the 92-93?for integra
- What are those parts called...
- Exhaust wrap for turbo - bad?
- Grind somewhere before car warms up...
- A/R??COMPRESSOR HOUSING???INDUCER???EXDUCER????
- ***********please help quick****** timing qusetion
- Need to lower vtec
- distibutor making weird noises
- oil light flashing
- Check this page out!!! it has to be wrong, 1998 itr dc3??
- Valve SeaL rEplacement
- 2dr. and 4dr. splash guards/fender liners(question)
- whats my teg worth now?
- Starting Problem
- help!!
- carfax
- 4 door DA teg Jdm Big Vtec Motor Conversion wat a pain in the ass but well worth it!
- Cam Shafts
- TD-44U Distributor Problem
- Throttle position sensor
- Compression Leak Down Test
- changing steering wheels question
- What type of head gasket?
- car spins over but wont start
- DA with problems!!! please help!!!
- tire size?
- nonvtec dizzy on vtec?
- Best Full Coilver setup for 90% street use! DA TEG
- Are all B-series transmissions compatable?
- just bought an LS, few questions
- Brake master cylinder installed wrong??
- 94' GSR Steering Column Removal??
- gsr tranny on ITR motor
- Got a Flexpipe question...
- 1994 GS-R Bearing
- rear strut bar brand for DC2 that doesnt require panel hacking???
- oil pan
- help please. auto to manual problem
- just finished my b20/vtec swap
- turboing a 2001 b18c1
- shifting 1 to 2 not smooth
- Recycle'd oil ???
- Need help, with rebuild advice...
- question about B16 Block
- Engine
- JDM ITR GRILL CLIPS LOST NEED HELP
- DA Suspension Question URGENT!!!
- HELP!!! How to clean header with spots...
- need a new / use throttle body .....
- Where to buy OEM flywheel?
- gas light
- help...need a wire diagram
- Sizes of the brake bleeder screw?
- What to expect from a turbo 89 LS
- whining noise from engine?
- ITB's on my GSR
- c pillar bar question
- Synthetic Motor Oil Options............
- Gsr??
- new to the honda -tech.com
- Tire rub after suspension install, need help/advice
- What does DC, DA, etc. mean?
- need help with swap wires for vtec,vtec solenoid and knock., what color ?
- New Clutch???
- help with mis fire
- Cams holder or Cams Clamp Torque Specs
- da k sport installation
- brake master cylinder question
- GEN 2 INTEGRA DISTRIBUTOR ON GEN 3 ENGINE???
- slowed down
- Ls head build questions
- need help slight misfire
- wat are differences between the OBD1/OBD2 and LS/GSR distributor????HELP***
- B18b from 97teg will it work with a cable tranny?
- clutch advice...need help
- will a rear 4 lug hub fit a 5 lug jdm itr spindle?
- Skunk 2 intake install problem...?
- bad iacv causing problems?
- headlight removal
- ecu reprogramming
- GSR Idling Problem.....
- mexicali baja california mexico
- gauge cluster fuse keeps popping! Help me out please!!!
- trouble installing ITR rear swaybar
- any1 here ever put 87 octane gas into their GSR b18c?
- What turbo kit would be the best?
- How To take THIS Off
- Gears Grnding
- help!!
- 1992 acura integra rear brake pads
- B18 Pulley Removing Problem ( Researched )
- fg stock muffler on the teg
- where is the best place to get 98+ type r lip
- b18c1 ?
- teg vs. deer... i lost
- I have no clutch! Please Help!
- Stuck 2 hours away from home! PLEASE HELP!!!
- Transmisson or cluth problems?
- ABS Light issues
- replacing wheel bearing.
- gave her a bath, took some pics!
- How to convert my DC into RWD.
- gsr overheating
- help.. compression issue in my built gsr
- Regular gas or premium gas??
- Main relay problems in 1990 DA?
- 94ls dc2 to b20z help
- JDM Front End Conversion Vs. DC4 Front end
- help noooob q!
- I need help with a leak
- JG Edelbrock Victor X manifold questions
- gs-r swap on Da Map n O2 sensor questions????
- Code 20, and 43 need help! on 94 gs-r
- 91 da coupe ABS question
- vafc removal
- Auto Transmission+CronePro
- bearing question
- How much is my GSR dizzy worth?
- Where is this hose supposed to be connected?
- '98 GSR value
- adjusting suspension
- LOW HORN - will not shut off!
- need header suggestion
- Does anyone know where to find 94 integra ls fuse box diagram underdash?
- ;;;;;;;;;;(HOW TO) want to build a streetable gsr motor..<~~NOOB ..help me please
- The smokeing pt 2......wtf...
- Problem going into Reverse(Clutch or Shift Linkage)
- Bad Gas Mileage
- integra fuel injectors
- 93' GS-R -- Sputtering engine, pls help
- g3 integra antenna power supply
- how often should a clutch be replaced ?
- Just bought a Integra.....
- Skunk2 vs. H&R
- where to buy replacement quarter panels?
- 1990 acura integra 4sale
- problem starting,and map
- RHD DA?
- car jerking, please help
- Quick question about radar scanners
- unplugging 2nd 02 sensor for exhaust install - Please need help ASAP
- Slight engine bay rust
- i got a kick out of this when i saw it
- integra sway bar bolt
- 94-97 dc2 foglight fitment on a 01
- LOSING POWER...BAD!
- Engine Installation Problems...
- My gsr is acting up
- Does anyone know of...
- Acura Factory Service Manuel
- h22 94-01 Integra hasport question?
- WHAT TO USE ? AND HOW TO DO IT ? // PLZ HELP
- 94 integra wont start
- breaking in a motor???turbo or NA
- Megan 4-2-1 2pc header
- p72-A05 ECU
- gsr ecu pinouts?
- need admin help pls
- cotter pins
- Reseal tranny.
- fuel pump
- CEL code ?? and is it still safe to drive my car..
- Cold engine & gas refill = car dies.
- integra suspension problem
- replacing the head gasket!!!
- LS/Vtec ARP head studs
- removing emblems!
- Warm Start Problem
- 10w30 In The Tranny
- Brakes Make Steering Wheel Shake
- LS/Vtec TURBO HELP PLEASE!!!
- Who makes a good header for an Ls motor?
- B Series Weight?
- 1990 Acura Integra GS Auto to Manual Swap
- Remedy for vtec leaky head gasket, anyone? (oil)
- JDM Honda Badges?
- Head with no cam caps?
- Just Bought A Teg
- the smokeing....
- Chipped p28
- This is a cool video
- Has anyone heard of C Salt?????????????????????????????????
- (crashed) 180k 94 integra auto, what parts should i keep?
- crank pulley removal
- Door Removal
- 3500 to spend
- b18b vs h22?
- Caliper help
- gsr HELP
- Need help fixing fast blinking turn signal
- B16 intake to a D16 head
- My LS/VTEC Build
- broken rear engine mount situation
- Is this a problem??????
- help with changin the Timing Belt and water pump ..!!!!!!!
- Installing cam seal...
- Help me out Im new
- Plugs for holes in my TRUNK! Please help!
- 93 da
- driver side power window switch not working help
- 91 ls Vs 99 Ls block
- rear wiper delete
- battery drains sounds like a relay?
- integra 4 door length
- oem optional lip kit vs replica fitment?
- filter fell...
- B20 swap
