View Full Version : Acura Integra
- Annoying braking sound
- what's with the bumpy ride ???
- weight dif between gsr and JDM ITR seats?
- front discs in the rear?
- auto to manual
- steering column - 2 dr vs. 4 dr
- Broken rear seats!!!! Wtf
- What parts do we share with the Civic?
- More random worthless stuff that I did recently
- help! disappointing dyno results
- gsr vs ls
- ABS ( ANTI LOCK BRAKE SYSTEM )PROBLEM
- HEADERS - GREDDY OR DC SPORTS
- JDM clusters
- SPOON N1
- 450 hp my dyno vid pic and carf
- B17 motor boost
- ECU Swap...but dont' knwo what to get
- Best ECU
- would these headlights be suitable
- Turboing a G2
- New to the integra world, clock don't work after changing deck
- Torque specs
- ecu?
- b18 LS on bottle
- gsr stock track runs
- Any took apart a bumper light?
- 94 LS distributor assembly repair -Opinions needed
- alternator light is on
- who has the most power on a bolt on gsr????
- Did they ever make a black 4 door Integra for 96-97?
- battery keeps draining.
- removing mudflaps
- gsr question.
- a1 tranny?
- Differences Between Clusters?
- dashboard, armrest, centerconsole same on 2 & 4 door Integra?
- need help guys
- Apex-i N1 muffler coming this week, should I wait until spring to put it on???
- running lean in cylinder 4
- what cams should i get??
- lca
- 1st time at strip and disappointed
- shifter nut fell off @ shiftlinkage!
- RS*R
- Car bogs down between 3k and 4 K when I'm daily driving?
- can't get into topic
- code for factory stereo?
- Valve cover swap?
- hood fitment?
- LS wheel size vs GSR wheel size
- need to switch springs - advice
- installing gauges today need help
- i would like to learn how to put my motor to TDC
- Installation on ITR front strut bar?
- squeakin problem
- Rebuilt Title?
- What next...
- How'd the Integra lose 7hp in 1997
- Oil pressure light on startup in 3g integras
- what bulb type are 98+ corner lights?
- 94-01integra rear seats in a 90-93?
- breather filter size ?
- new clutch
- B16 tranny with LS motor
- Check Engine Light Flashes when i start my car..
- s-afc on obdII
- test pipe
- Will 90-91 bumper fit on a 92-93 front end?
- I need a 94 LS distributor
- Can I use a 94ecu in my 90 integra
- Coil-overs
- NEUSPEED HELP! PLEASE HELP. its about the neuspeed bar
- N1 vs Skunk2 vs Invidia
- Crower 403's on LS
- Random H-T forum question...
- Where do you find these?
- Crower 402's on a LS
- JDM B16A Manifold Help Please....!!!
- is this a good deal
- itr shift linkage mod
- Integra Window Visors
- is an Exceeds Mechanical Limits title on an integra BS ?
- ecu question?
- 17 INCH RIMS WITH 2 INCH DROP
- cold outside, yet i did a cluster light mod
- Please help fellas.....
- Integra LS/VTEC Turbo
- Will this tire size work?
- Yokohama Tread Depth?
- Type r cluster repined to work on gsr
- 11.1" Rotor Upgrade (4x100)
- headlights suck, need new ones
- are the mounts the same if i swap a b18c-r in a 2nd gen
- Header comparison?
- u got maiL!
- b18c block identification
- cold weather and the teg
- Replacing Timing Belt
- side skirts
- anyone got 96-97 Spec R in teg?
- Get your car rated
- So does anyone use Marvel Mystery Oil?
- STock GSR Springs spring rate?
- Who has dynoed thier greddy turbo'd GSR?
- Thinking about going OBDI... what will i gain and will it be worth it?
- PIC REQUEST-Integra with gunmetal/bronze volk TE37's
- HELP!! my car got broken into. i need a passenger side window for DC2
- springs question
- **---------------- Removing ABS - 96 SE
- Should I buy it??
- How light can an integra get?
- JDM ITR conversion
- How Should I Build Up My 2000 GSR Engine?
- APexi SI exhaust on Teg?
- What are the differences between the 90-93 integras?
- hanyes crazy compression #'s
- Code 90 fix?
- anyone knows integra offest???
- Carfax Needed ASAP
- What cam gears?
- Stock GSR header on LS???
- OT: Place to buy Touch up Paint in a spray can?
- Carbon Fiber Bumper and Trunk
- Where to mount VAFC?
- crack in tranny case..how to fix?
- ITR 5 LUG & S2K WHEELS?
- About to buy this Harness, Who can vouch for this seller? Plz.
- STOLEN: 1998 Green GSR from Elizabeth, NJ
- Can someone CarFax this VIN # for me... Please
- 95 GSR suspension opinions
- Snow shoe teggys???
- idle
- does anyone have this 3 pt strut bar...what are your opinions
- Tanabe vs. Skunk2 (exhausts)
- whats better?
- Apex'i World Sports
- thinking about buying one
- Ok, I'm about to try it...
- Knot Sensor Question-Check Engine Light On.
- Header Question
- safe proof bumper lights
- 1/4 Times?
- jdm rubber snow chains? where to buy?
- cv boot replacement?
- Intake/ ECU question...
- Finally found out how to post pics....
- confirmation on 4 dr handles
- Intergra's with HID Kits!! Are they Shit? Very Confused!?!?!?
- anybody know the size of the 02 sensors for dc2's
- Exhaust, 2.5", GSR, Magnaflow, KTeller8
- DA integra TA bushings
- my car is gone!!
- Where to Buy BSQ ITR Rear Sway Bar Kit..
- Is this an OBD1 P72 GSR ECU #? 37820-p72-003
- Helms Question
- ALTERNATOR TESTING
- manual steering rack results
- WTF!! how am I!!
- car not starting !!!!!!!!!!!!!!!!!1
- teg cd deck
- FUSE BOX DIAGRAM 91 INTEGRA
- Why are 15" steel wheels so damn hard to find?!?
- Help with GSR cams
- I searched but to no avail....
- Removing E-brake cable through trailing arm?
- integra LS gearing problem
- !! gRRRR hott steam gushing out from hood radiator area !! helppp
- need help on 98teg with frame
- QUICKIE: how do i tell if my koyo radiator is the OEM replacement or aluminum?
- should i switch back to stock intake?
- 2nd attempt to steal my GSR
- PLEASE HELP ME OUT GUYS..
- Parking Brake Light...?
- FUEL LEAK ON 96 teg
- KTeller8 2.5Inch Stainless Steel Catback for DC2
- Fire in Floorboard of CIVIC , GOOD IDEA?
- Wiring JDM ITR Non-SRS wheel horn...help!
- how do you like your itr rear sway bar?
- stock spring rates for 3rd gen integra
- my gsr shut off while driving
- I have a few integra Q's
- does anyone have a tv in there integra
- fuel filter
- Throttle cable adjustments
- ls
- Which Cams Are the best for street?
- My Hatch (LS)
- Need help on testpipe asap
- changed my rims in fear of snow.. NJ/Philly **PICS**
- idiot of the year!
- Update
- Left-over PS removal kits
- The Brown Truck Dopped off something again
- JDM DC 4-1 Problems
- What's a good price to sell an Integra at?
- how to take gauge cluster off?
- need help quick
- Help: lights
- b20z/b16a vtec vacc. diagram for 92 teg
- does anyone know what size rims are on this teg?
- valve adjustment
- removing paint from/cleaning calipers? - how?
- Warning: Noob post
- i need a gs-r 2 door exhaust
- How pissed will obd2b get if...
- scraping tires on wheel well/ fender wall.
- '01 gsr fuel upgrades,
- teg speaker help
- ECU Up Grade
- is anyone here have project MU rotors?
- (relatively) new member (pics inside)
- need carfax on a vin
- Question about integra stock springs
- i just got a smog test only center.
- OEM Foglights Instructions
- Luis Pena- I need ur addy
- Louis Pena- I need ur addy
- Person looking for carbon fiber trim pieces
- *Got my teg back from the shop. Few pics
- 12.5lb flywheel + stock clutch = ?
- How tight to i torque DC 4-1 headers down?
- 98 teg front bumper on pre 98 integra?
- OT: Need Stock or All season Tires..NJ area
- How to verify your engine is in good working condition
- Shady ebay SPOON cluster..
- Got my Turbo LS with hondata tuned
- building up a motor
- ecu questions
- ECU code #10
- Who's running without A/C or power steering?
- Couldn't resist a bargain.. bought some Recaro's
- What am I looking at here...?
- green powder from battery terminals
- *A MUST READ for those who are new to heavily modding your Integra*
- Has Ne1 Tried This???
- Location of Fuel Pump Fuse
- itr usdm vs jdm piston
- Part Numbers Request (clutch/brake cover pedals)
- JDM one peice headlight bulb replacement
- 93 da9 5speed, if shifting over 4k then clutch pedal is soft like butterr
- S.
- im buying a tranny what to look for and at ??
- New bumper
- What color bulbs would i use to get my stock cluster to glow Blue or Red?
- integra 9005 conversion?
- are all koyo radiators all-aluminum?
- skunk2 and invidia
- anyone have the NOS plate injector system just for the GS-R?
- PROJECT COMPLETE 12sec civic(hopfully) Let me know what u guys think
