JDM Plwer Folding Mirror Help!!
Old 02-11-2019, 07:42 PM
beamer's Avatar
Default JDM Plwer Folding Mirror Help!!
i want to purchase a set of power folding mirrors but I want to see how hard it is to run the wiring. Does anyone know of a thread. I’ve looked everywhere and haven’t found anything.
Old 02-12-2019, 06:14 AM
UndergroundTrev's Avatar
Default Re: JDM Plwer Folding Mirror Help!!
What chassis are you working on?
This link is from G2IC, it's for installing power folding mirrors on a DA. I don't know how different a DC would be.
G2IC: Teg Tips
Old 02-12-2019, 07:52 AM
beamer's Avatar
Mine is a DC2 but I’ll look into it. Thanks for the help.
Old 02-12-2019, 09:22 AM
thewrai6th's Avatar
I've done it, and I really like the end result, for parking in a really tight garage.
A couple things to note, you have to swap out the entire housing AND glass from the LHD mirrors, unless you just happen to be switching to RHD.
You cannot cut the wires, you have to de-pin them. If you try to do anything like cut and solder or crimp you will find out real quick that you can't get the wires back through the joint. I'll see if I can dig up my old post.
Some good info in here: https://honda-tech.com/forums/acura-...tegra-1658051/
Old 02-12-2019, 04:05 PM
beamer's Avatar
what if Im buying the whole power mirror assemblies? I can just remove my old ones snd instsll the power mirror assemblies correct?
Old 02-13-2019, 10:01 AM
thewrai6th's Avatar
Yes, that's what you have to do for LHD. Use your USDM housing and mirrors with the EDM/JDM power motors.
Old 02-14-2019, 02:54 PM
beamer's Avatar
so just out of curiosity my car is LHD but why can’t I just use the JDM mirrors if they bolt right onto my door? Why do you have to take the motors out of the JDM mirrors and put them in the USDM housings? I’m just asking so I can comprehend it better and to see if it’s worth it.
Old 02-15-2019, 10:36 AM
dc2iggy's Avatar
The actual mirrors on a LHD and RHD car are different due to the position of the driver. If you put RHD mirrors on a LHD car you will not be able to out of the properly. You should be able to swap the mirrors between your LHD and RHD mirrors and just mount the whole unit onto the car.
Here are a couple installs:
https://itr1920.blogspot.com/2013/11...july-2012.html
DIY How to install JDM Folding Mirrors for Integra
Old 02-15-2019, 08:07 PM
beamer's Avatar
this is great help!!! Doesn’t seem too hard to do then. I am mechanically inclined so I see what had to be done in the electrical side too. Thanks for the help! Much appreciated.
Old 02-15-2019, 08:12 PM
beamer's Avatar
one last question, does it matter if I buy the mirrors for a 4door integra? Are they different than the 2 doors since I’m just going to be using the internal did the mirror...?
Old 02-17-2019, 07:51 AM
dc2iggy's Avatar
I don't think there is a difference between the two.
Old 02-18-2019, 10:24 AM
EnjoyTheRideDC2's Avatar
Sedan mirrors mount differently than the coupe. The mirror housing is the same but the base plate is different.
Old 02-19-2019, 09:56 AM
thewrai6th's Avatar
Just to clarify on this, it's not just the glass. The entire plastic housing for the mirrors is angled differently for RHD/LHD. First thing I did was mount the JDM mirrors on my car and try to adjust them. No go, unless you want a selfie mirror.
If you want to understand first hand, go sit in your passenger seat and try to adjust the LHD mirrors so you can see out.
It was not that difficult to swap the housing, as long as you depin the wires.
Old 07-10-2020, 02:15 PM
OMEGA1369's Avatar
Default Re: JDM Where can I purchase Power folding mirrors
Aye new to this site Where can I purchase power folding mirrors for 91 cb7 ?
goldenmustache
04-05-2009 04:35 AM
crj_lll
10-04-2007 05:27 PM
j nepo
08-13-2004 02:58 AM
jonyb
03-29-2004 04:24 AM
HatchBox
02-08-2003 11:47 AM
Quick Reply: JDM Plwer Folding Mirror Help!!
