Ignition Cylinder Switch
What's up guys, I've got an issue here. So I have a 1990 Integra GS, We have no key for the car. With that said I have begun the drill out process to remove the Cylinder Lock, the problem I have is that I can't find a replacement? I've Googled "1990 Acura Integra GS Ignition Cylinder Switch" and "1990 Acura Integra Ignition Cylinder Lock Switch" with no luck. Multiple pages always pop up with the Cylinder, but once I type my car in, I get the "this part does not fit your vehicle".
Any ideas on where I can find a replacement? Preferably an OEM... But as long as it's a proper fit then it doesn't matter.
If you go to an auto salvage yard (PullApart, etc), they usually leave the key in the ignition. Remove it and swap it out with the one you already damaged.
chillerice
15
Jan 27, 2013 12:47 PM
Bishop1976
Oct 3, 2012 08:31 AM
