96 Stock GSR - Won't start after testing AEM EMS S2
I'm full of stupid ideas today.
So I purchased a used AEM EMS Series 2 for my 96 GSR. It's the correct box for the car (OBD2a - 30-6060). The previous owner said the tune was for an all-motor B-series engine, so in an effort to test the ECU, I decided to plug in the EMS and try to fire up the car. Car would not start.
Problem is, now that I plugged my OEM ecu back in, the car still won't start. It just keeps on cranking, so I'm assuming I fried something fuel-related or something spark-related. I checked the ECU fuse and it's good. Any ideas??
The car ran perfectly before trying to start the car with the AEM EMS.
TIA.
TIA.
Premium Member
Re: 96 Stock GSR - Won't start after testing AEM EMS S2
You had no idea what the ECU was calibrated for aside from an "all motor B series", so trying to test it on your stock engine was a bad idea. The previous tune could have been calibrated for different fuel injectors, cams, etc.
Did you do any troubleshooting aside from pulling a single fuse? It could be something as simple as fouled plugs. You won't know until you start digging into it. If you're not getting a CEL, solid or flashing, I wouldn't suspect that you fried anything.
I pulled the ECU fuse, that was it. I'll test for spark and I'll test for fuel tomorrow. Just looking for additional input if someone has made a similar mistake, so I can start putting together a plan of attack.
TIA.
TIA.
Car runs good as new after replacing the above parts.
0ptimus prime
Engine Management and Tuning
04-06-2019 11:07 PM
