Are Da and Ef Cat the same?
Old Apr 14, 2019 | 11:52 AM
Timothy Yhtomit's Avatar
Default Are Da and Ef Cat the same?
Made a post in the 88-91 forum but no one answered. I got a 91 ef hatch with b swap LS. Was told I can pass CA bar with my stock 91 civic cat instead of having to buy a DA cat, anyone knows if that’s true?
Old Apr 14, 2019 | 04:52 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Are Da and Ef Cat the same?
Just get it welded up its a cat it should work.
Old Apr 14, 2019 | 05:03 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
No. You need a cat from a 91 integra LS with the proper carb EO number stamped onto it. Pro-tip, just go to a muffler shop and tell them that and have them weld in a new one.
Referee will look for and run the number to make sure it's correct for the motor swap.
Old Apr 14, 2019 | 06:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
I didn't know they had a carb EO number stamp any pics of these on the stock cats? I never seen one or heard of them checking the cat stamp during a BAR reff.. on a aftermarket cat yes I seen the stamps but on a stock cat?...
Old Apr 14, 2019 | 08:02 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
For Aftermarket cats, yes.
Unless you’re buying a new OEM cat you’re buying an aftermarket.
With the swap, the cat needs to be carb compliant for an integra. His is likely a carb legal cat (by this age of the car, the cat has likely been replaced) for a conviction. It may have the same number, but OP should do his due diligence and make sure he has his ducks in a row.
Old Apr 14, 2019 | 09:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
I was under the impression he wanted to use a OEM cat from one car on another car so i was implying he should get it fabricated at a shop and he would still have a OEM cat on the car that should work just fine its deff better than a aftermarket cat in my opinion. But i could be dead wrong..
Old Apr 15, 2019 | 02:03 AM
Thank you all for the replies. I found someone local who is selling a oem Ed/ef catalytic converter and since you guys said the OE number doesn’t exist on stock ones I’m going to pick it up and hopefully it’s still in good condition.
Timothy Yhtomit
Apr 11, 2019 10:30 AM
924doorEG
Dec 3, 2009 12:22 PM
Charlie Moua
May 21, 2003 02:12 PM
