Mechanic put ATF in my '91 Integra 5-speed
Old 11-30-2018, 07:45 PM
262dbrink's Avatar
Default Mechanic put ATF in my '91 Integra 5-speed
Will this cause damage to my transmission? Do I need to drain it and change to MTF?
Old 11-30-2018, 11:47 PM
MotorMouth93's Avatar
Default Re: Mechanic put ATF in my '91 Integra 5-speed
Yes you need to drain it ASAP, refill with Honda MTF. Try to avoid driving as much as possible until this is taken care of.
Old 12-01-2018, 12:42 AM
-Intl Steve Krew
Caoboy's Avatar
If he’s a mechanic take it back to him and have him fix it.
if it’s your buddy who thinks he’s a mechanic, tell him he’s an idiot and learn how to fix these things yourself because he doesn’t know any better than you.
Old 12-01-2018, 07:14 AM
zeroptzero's Avatar
They've been doing that for years to help quell differential noise in sharp turning conditions. I had a 94 LS one year and the dealer installed ATF as I was getting differential noise, it was a recommended fix by Honda. I personally do not like that, so I would prefer to have a good MTF in there, it won't harm anything in the short term, and maybe not even in the long term but why chance it.
Old 12-01-2018, 07:33 AM
O.G. triple O.G.
NVturbo's Avatar
There is a reason why they make ATF and MTF. Use the correct stuff. As for the so-called mechanic, tell his *** he is INCOMPETENT
Old 01-18-2019, 03:28 AM
90turbols3431e's Avatar
In my truck I cut the gear oil with atf so I can shift it in the winter. Atf has a friction modifer, the oil moves off surfaces where friction is needed. I can't say is right eather but It will work. There is a lot of manual transmissions that take atf like the t56 and the zf5 Ford recommends mercon v. How did it shift anyway?
Old 01-18-2019, 07:16 PM
Fish Twig
tony_2018's Avatar
find new mechanic.
Old 01-18-2019, 08:04 PM
milano2kdc2's Avatar
Originally Posted by zeroptzero
...the dealer installed ATF as I was getting differential noise, it was a recommended fix by Honda.
Can anyone verify this?
Old 01-19-2019, 04:31 AM
zeroptzero's Avatar
yeah me, I took my 94 integra (back in 94) to the Acura dealer due to differential whine in tight turning situations, they drained the mtf and installed ATF as per Honda's recommendation. The vehicle was still new and under warranty back then. It did fix the diff whine As noted above many vehicles including BMW and Mercedes use ATF in manual trannies, the Tremec tranny known to power some of the heaviest torque vehicles in North America uses ATF. I personally prefer a good MTF but running ATF won't kill your tranny so no need to panic. I would still dump it at some point in time for peace of mind if you are no comfortable with it.
Old 01-30-2019, 12:07 PM
UndergroundTrev's Avatar
The old cable 5-speeds can run engine oil (I forget if it is 5W30 or 10W30) or Honda MTF. I have Honda MTF in mine. I work at a Honda dealership and I've never seen ATF used in the manual transmissions. However, as stated in some of the above posts, I have seen ATF used in some manuals to correct noises, and my Camaro's factory T5 manual transmission runs ATF.
With all that in mind, I'd say if you are not experiencing any noises or issues that ATF might fix, I'd recommend flushing it all out and filling the trans back up with Honda/Acura MTF.
Old 01-30-2019, 02:07 PM
zeroptzero's Avatar
Not too much to worry about in terms of possible damage as Auto tranny fluid is designed not to thin at higher temps, it has lots of anti-wear additives, and is friction modified to allow smooth shifts, so it can work fine in a manual tranny. Also Honda MTF2 tranny fluid is very close in viscosity to an auto tranny fluid, not far off. The older Honda MTF was a bit thicker, but when they changed to MTF2 it got thinner. But as I noted previously I would still want to run a good MTF in my tranny, I've actually gone thicker with Redline MTL.
Old 01-30-2019, 02:24 PM
dilbeckskate's Avatar
drain it and just literally stick a funnel in the fill port and pour 5w20 synthetic oil in until it comes out the fill port and you are done
Old 01-30-2019, 06:37 PM
wunfstgsr's Avatar
The Honda manual calls for 5W20 oil as replacement MTF.
93coupe91hbTY
01-17-2012 09:36 PM
91akira
03-08-2010 11:41 AM
lmccammon
02-16-2005 03:52 PM
dheerajacura
Acura TL, RL & ZDX
09-01-2004 06:43 PM
onyx00
09-26-2001 09:23 AM
Quick Reply: Mechanic put ATF in my '91 Integra 5-speed
