B18A1 / B18B1 OEM Complete Gasket Assemblies Compatability
I'm in the process of rebuilding a 1991 B18A1 motor to OEM specifications. Unfortunately it appears that the OEM gasket kits for a 1991 Integra are discontinued.
This would be PNs:
061A1-PR4-A01 GASKET KIT, CYLINDER HEAD (NOT AVAILABLE) 1991 Integra
061B1-PR4-A00 GASKET KIT, CYLINDER BLOCK (NOT AVAILABLE) 1991 Integra
061A1-PR4-A00 GASKET KIT, CYLINDER HEAD (NOT AVAILABLE) 1992 Integra
061B1-PR4-A00 GASKET KIT, CYLINDER BLOCK (NOT AVAILABLE) 1992 Integra
I did notice that Acura dealers still have inventory of the 1993 B18A1, and 1994 3G Integra B18B1 gasket assemblies
PNs:
06110-PR4-000 GASKET KIT, CYLINDER HEAD 1993 Integra B18A1
06111-PR4-030 GASKET KIT, CYLINDER BLOCK 1993 Integra B18A1
PNs:
06110-PR4-010 GASKET KIT, CYLINDER HEAD 1994 Integra B18B1
06111-PR3-000 GASKET KIT, CYLINDER BLOCK 1994 Integra B18B1
Does anyone know factually of any incompatibilities between the these gasket kits? The only thing I could think of is the map sensor moving to the throttle body. Anything else?
Thank you,
This would be PNs:
PNs:
PNs:
Thank you,
Re: B18A1 / B18B1 OEM Complete Gasket Assemblies Compatability
This would be PNs:
PNs:
PNs:
Thank you,
This would be PNs:
PNs:
PNs:
Thank you,
I have never had any failures with FelPro HGs so far (out of ~5 repairs), so that is what I would do. I always use new head bolts, or ARP head studs. I always make sure both surfaces are clean, flat and within spec.
Eghatchgsr8
09-19-2014 02:24 PM
