GRINDING NOISE SOLVED
Solution to the grinding noise in my 1995 Integra Sedan: The whole time I have had the car, it's had a terrible 'grinding' sound. I rebuilt the transmission when I replaced the clutch, and while the bearings were destroyed, the sound didn't go away. I just replaced the water pump and did a Gates timing component kit as well, hoping that was it. After starting the car and still hearing it, I was at a loss. My brother said something I thought was dumb, "It's coming from the front bumper!" Then upon leaning on the bumper to tell him it couldn't possibly be coming from the bumper, the noise went away. Lol Turned out these plastic pieces in the front bumper were the cause. (In case anyone else is having this issue.) The noise was made worse in my case due to the Yonaka Polyurethane engine mounts I installed. Hope this helps someone else who is worried about the same noise. Good luck!
Re: GRINDING NOISE SOLVED
gates is on my sh*tlist after one of their coolant pumps failed after 5 years.
aisin or npw is the way to go for the pump.
now also rocking a bando timing belt and koyo tensioner.
no more gates chinesium junk ever. 8( f u gates!
tbk timing belt kits do not contain gates products or other non-japan trash, hooray!
Fish Twig
https://www.amazon.com/s/139-0133576...tag=mozilla-20
I just got a t-belt kit from Amazon that came with a Mitsuboshi belt, and NPW water pump, plus tensioner and a bunch of gaskets and oil seals. Also picked up a Fel-Pro Permadry blue oil pan gasket with the metal frame. Hope everything holds up. After years of spending tons of cash on OEM Honda parts, at 365,000 miles I just didn't feel like spending $300+ for a timing belt job when the Amazon kit with Japanese parts was less than $100.
I hope it isn't. Pan has only been off of the engine one time, back in 2008 when I replaced the original gasket at 270,000 miles with a new OEM gasket. The engine was out of the car, upside down on a stand so I was able to set the new OEM Honda gasket in place on the bottom of the block, then drop the pan down on top of it, and (carefully) torque to spec. 10 years later now it's leaking again, at least I think it is, unless it's something above leaking down. Engine will be in the car this time, but my gasket came with those ingenious little plastic Felpro things that help hold the gasket up in place while you lift up the oil pan.
if fel-pro could just rip off the hondahabit gasket theyd have a winner.
until then the latter wins.
the snap up thingies are genius though, hanging on to mine for the next
sh*tshow. found these oil pans on the cheap that come in a honda box.
total steal since most stealerships want $200+!
https://www.ebay.com/itm/Engine-Oil-...nn5W:rk:1:pf:0
Since you seem to be trying to do it once and do it right, you might as well invest in a set of oil pan studs from Honda habit
i think the felpro permadry steel core gasket is similar to the one on hondahabit
Btw, $120 for a pan? Ugh. I bought a new pan for my 93 integra from autozone for $70.
What's the advantage of having all studs on the block?
i think the stock setup is a mix of studs and bolts which causes uneven sealing characteristics... also repeatedly removing and installing those bolts can lead to stripping in the block which would be a terrible, horrible, nasty thing to deal with.
18 years and 190k kms on mine and no leaks. I just retorqued my oil pan bolts and nuts as some were looser than others. Using the oem gasket is easy just use a jack to hold it in place as you torque down the bolts and nuts at your own pace no need for anything else despite the felpro gaskets having added features.
I also got the oil pan gasket, a new OEM Honda oil pickup gasket, and a new OEM Honda o-ring for the oil pump (not in this kit).
kenskii
07-08-2014 08:33 PM
