Power window not working
My driver's side power window is out, it doesn't make any nosie when i flip the switch. I replaced the switch and it was still not working then I replaced the window motor and it still doesn't work, it doesn't seem like there is anything left to replace. I also made sure the fuse was in good condition
Hi there fuses definitely get tricky and there are lots of variables, I'm wondering if your battery has a full charge or good connection? My power locks and my passenger window power got very weak one time where it was a gamble to use it, it ended up being stuck down and couldn't get it back up. Since I had a newer battery, I ended up rewiring new battery connectors, haven't had that problem since thankfully. As for you if you suspect it is a master switch and it is expensive have you tried to see if a wrecker has one in good condition? Just a few ideas, I hope it helps. Good luck
kptrk06
Honda Civic (2001 - 2005)
Jun 29, 2014 09:26 PM
