Auto to Manual question
O.G. triple O.G.
Re: Auto to Manual question
you mean...how can you wire it up so it will let you remove the key out of the ignition?? All the wiring is near the automatic shifter.
Its very odd because the shifter almost fits perfectly, I am doing the swap for one of my buddies and I did not realize it was converted to manual but its just a shell .. If that makes any sense lol
O.G. triple O.G.
once you remove the center console, you can see indentions on where the mounting holes are. Best thing to do is use an aluminum plate with a hole cut out for the shifter. The plate helps reduce road noise and debris, etc.
jdmhondamotive
09-07-2007 06:21 AM
JDM-EJ1
05-02-2005 06:59 AM
consolidatedbord
01-28-2005 02:08 PM
