2001 Acura Integra Issues
Old 03-28-2019, 10:49 PM
Soliate's Avatar
Default 2001 Acura Integra Issues
Hello, I have a 2001 Acura Integra and it's been giving me issues.
It's an automatic and i'm getting 3 codes.
When I drive it, the car will rev really high but it'll barely grab and wouldn't really move until it's at like 2.5-3k rpm.. but very slow and has no power.
Here are the codes?
How do i fix these? Is it difficult?
1) P1607 - Engine Control Module (ECM) / Powertrain control Module (PCM) internal circuit malfunction
2) P1337 - Engine Speed (RPM) Fluctuation Sensor No Signal
3) P1768 - Problem in Torque Converter Clutch Solenoid Valve B Circuit
Old 03-29-2019, 06:11 AM
Fish Twig
tony_2018's Avatar
Default Re: 2001 Acura Integra Issues
Check your tranny fluid levels?
Old 03-31-2019, 04:52 PM
wunfstgsr's Avatar
Here are the codes?
1) means you need a new ECU! try another ECU from the same years and model and see how it runs but it sounds like a wiring issue or break in the wiring.
2) does your tach on the cluster work? does the rpm needle move as the engine revs? if it doesn't move there's a wiring issue from the distributor rpm signal its usually the blue wire on the plug, or a problem with wiring in between connector "d" and the harness that connects pcm and tranny. If the VSS is working and the PCM sees it then it will not set a code. Might be a wiring issues where the speedometer connects, or the speedometer may be faulty.
3)Try replacing the solenoid if there's no wiring issue found.
Old 03-31-2019, 05:07 PM
tamboo's Avatar
this eric the car guy honda vss vid is worth a skim:
vss and plug are both known issues.
bring some contact cleaner and dielectric grease then
buy new plug if still fooked.
manual trans vss are pricey, autotragic is relatively dirt cheap. what gives?!? 8(
TranceAddicts
09-18-2011 11:57 AM
da9leo
02-28-2011 06:33 PM
01_ITR
Northeast (Sales)
01-20-2010 02:28 PM
MidnightB16
Northeast
03-11-2009 03:32 AM
Quick Reply: 2001 Acura Integra Issues
