What size injectors would be best for a b18a1/b1 turbo build
Hi guys I'm trying to figure out what size injector would be best for my b18a1 build I have a fish scaled crank wiseco 8.6:1 com 8.3:1 compression pistons golden eagle rods apr2000 rod studs and bearing for the bottom end a b18b1 head with forged valves and springs with 282 turbo cams with a ported intake and a 70mm skunk throttle body I have a 60 trim turbo trying to get the best build out of it my first turbo build so I need a little help?
Re: What size injectors would be best for a b18a1/b1 turbo build
All that matters in sizing injectors is how much power you want to make and what fuel you’ll be using.
Ok thanks for the input I'll jump to the turbo forms and as far as fuel 110 oct ./e85 im running a mixture of 93 and 110 oct at the moment a 65/35 ratio runs like a dog on straight 93 and once in a while pings 93 just doesn't cut it anymore.
I'd recommend some FIC 1650's, or if going for 600hp+ you may as well just get some 2000-2200cc's and not have to worry about them anymore.
Richardvr1
04-09-2019 02:44 AM
