wire tuck?!
Old Dec 19, 2018 | 05:38 PM
hondakook's Avatar
Default wire tuck?!
Is it possible to pull the passenger side light harness through the firewall without removing the dash? so i have pulled the driver side through the firewall and ran out the door harness grommet and around the fender but when i try to pull on or feed the passenger side harness through the firewall it seems like it wont go anywhere. Im trying not to have to remove the dashboard because then id have to remove my cage and its a pain. it almost seems like the hvac box is in the way. please help.
Old Dec 19, 2018 | 10:02 PM
Poppers's Avatar
Default Re: wire tuck?!
Wat kind of car? I have a 92 Integra and I was able to do it on mine
Old Dec 21, 2018 | 07:22 AM
dvsjay's Avatar
Originally Posted by hondakook
Is it possible to pull the passenger side light harness through the firewall without removing the dash? so I have pulled the driver side through the firewall and ran out the door harness grommet and around the fender but when I try to pull on or feed the passenger side harness through the firewall it seems like it won't go anywhere. I'm trying not to have to remove the dashboard because then id have to remove my cage and its a pain. it almost seems like the HVAC box is in the way. please help.
i mean its possible but you going to have to remove some stuff depending on the location on where you are running it from. there are quite a few things there like the blower motor maybe you can at least remove the glove box and drop the blower motor and see if you can see the wire. have you tried using a flashlight on the hole of the engine side of the firewall and see if you can see the light under the dash?
Old Dec 21, 2018 | 07:25 AM
dilbeckskate's Avatar
yes you can pull it all through without removing the dash... same note if you are doing a wire tuck pretty much all name brand tuck harnesses have gotten pretty cheap or somebody custom ex: Monotech are all affordable and dont have to worry about the mess of things
Alex Flores
Sep 5, 2015 01:00 AM
b1699dx
Sep 24, 2012 10:03 AM
Doctor EG
Jun 21, 2010 11:09 AM
slowcoupe93
Jul 3, 2007 05:05 PM
