Need ideas for my crank / no-start issue
Back story; 1995 Integra GSR w/ LSVTEC. Ran previously, but cannot get it started and running out of ideas. Cranks, will not fire. Plenty of fuel, has spark, compression 225 even across all 4 cylinders (well #3 is like 215..)
Timing = good, checked, re-checked so many times Ive lost count.
I have 6 fresh, sanded to bare metal clean grounds, two off thermostat house, two off tranny, one off the head, one off the valve cover so lets not even go there
Tried 2 different dizzys, two different coils, two different ignitors. Have spark, not sure if its "white" enougfh, but I do have spark.
Plenty of gas, hear main relay priming. Can a main relay prime the fuel pump but still be bad? Or is that basically its only task?
Tried two different (known good) ecus
Checked all fuses.
Tried different MAP and IAT
Harness is new, custom mil-spec
Have good spark, plugs getting wet with fuel, plenty of compression
But not even trying to fire, just cranking cranking cranking
Seems like it would be something so simple and obvious but I am out of ideas.
All I can think of trying or testing is an alternator, main relay but Im sure neither will help
Any new ideas from anyone?
Checked all fuses.
Re: Need ideas for my crank / no-start issue
You're getting decent compression, so the physical/CAM timing is at least close. I'd still check TDC vs CAM(s) to be sure. Valves seem to be seating.
You're getting spark (how do you know that, did you take out a plug and verify spark?)
You're getting fuel (How do you know that, are the plugs soaked with gas when you pull them?)
make sure the engine-side of your set-up is properly grounded. also, make sure ur wire harness is grounded at the thermostat housing. I had a friend buy an eg for $400 because the guy couldnt get it to start. we paid him and started the car right iup in HIS yard...wireharness wasnt grounded at the thermostat. then he wanted MORE money after we already had paid him, got the keys AND the title. too bad, so sad
You're on the right track. You need compression, fuel and a properly timed spark.
bad coil is #1 cranks but no start problem. always have a new spare.
75k miles is about as long as they've lasted for me.
good guide:
https://www.team-integra.net/forum/b...eshooting.html
the honda coil (made by tec) is the best but even a well rated cheapy will keep you from getting stranded:
the universe favors the prepared mind.
good guide:
I would also suggest putting BACK the oem engine harness if it was removed. Your back-story seems to be missing a lot of info. Theres actually NO story, except "ran previously and now wont start". But reading your original post again, i saw "Harness is new, custom mil-spec" .. so i'm thinking you changed some stuff on that car and NOW it wont start. start undoing whatever you did, one-by-one until that bad boy cranks back up. Then you will find ur culprit.
Check your fuses and replace the ignition coil, $5 says its the ignition coil.
If you changed the TB make sure the gasket is on correct its very easy to flip the gasket when installing and it will prevent the engine from firing up!
Great news guys - finally got it firing tonight. I keep trying to think of what was there I havent tried yet? Finally I just thought it has to be something with either spark or timing. Since I had spark, I focused on timing. For some reason my LSVTEC is super touchy about timing belts and even one tooth off it wont start. Took me about 8 tries of taking the belt on and off to get it right. So played around with that, dried the fuel off the wet plugs and what do you know, it started popping. But it was 18 degrees here, and it looks like I need a starter too - so I called it a day. Thanks guys for all the suggestions and help. Its supposed to be 35 degrees next Saturday, Ill try again then and reposrt back.
ive heard that ls vtecs are never really in time so it might be a good investment to get adjustible cam gears
