need advice from b20 swap
Old 12-14-2018, 12:39 PM
Crayola Nugget's Avatar
Icon4 need advice from b20 swap
ok, I have a 91 acura hatchback with a b20 block, and I am not too sure if I have the correct "L" bracket for the tranny. it seems to bolt up the right way but both of my axles are angled to the rear more so than usual so every time I make a turn my axles sound like they are popping but ive already replaced both axles, with the lower ball joints and a traction bar so I can adjust caster but im still having the same problem. A tech told me it might be the wrong "L" bracket, that it needs to be at least an inch or 2 closer to the firewall so the axles can be straight.
Does anyone have any knowledge on how to fix this problem?
Old 01-29-2019, 05:00 PM
hatmanafro's Avatar
Default Re: need advice from b20 swap
where did the l bracket come from. is the rear motor mount on right? or where did those parts come from?
slo_ej8
03-10-2008 01:06 PM
90DwhiteA
06-21-2005 10:01 PM
warrick
07-04-2004 06:48 PM
Quick Reply: need advice from b20 swap
