Engine to start
If you're having trouble getting it started, specifics will help.
That's a pretty vague, open-ended question. What engine? For a B18, you need the engine wiring harness and the ECU connected and powered. You'll obviously need gas lines and ignition switch wired. If it has a chip key, then you'll need the chip reader connected.
https://honda-tech.com/forums/acura-...agram-2473173/
I'd also check the fuses and main relay. Some background would also help. Are you swapping engines? Is this engine in the same chassis that it was designed for?
JUN.
21
Feb 5, 2006 01:30 PM
