Stereo/cig lighter power delay
So I've been having this issue for a while. Sometimes after I start my car (1994 Integra LS hatchback), the stereo and cigarette lighter socket do not receive power right away, but will then turn on after a delay of anywhere from a few seconds to several hours. In rare cases, it doesn't even turn on at all for my entire trip. The issue predates my stereo upgrade, in which I basically switched from one aftermarket stereo to a much better one. I found another thread (link here) from a Del Sol owner describing a very similar issue. Assuming that all connections are proper and that the fuse that controls power to stereo/cig lighter is functional, what else could cause this issue?
I noticed that the power will always come on when I switch the ignition back to the I (one) position, shutting off the car in the process. Does this indicate an issue with the ignition switch? I should also say that I have no problems starting the car at all.
Re: Stereo/cig lighter power delay
I have the same issue, but found that when it doesn't turn on if I turn the key back towards me ever so slightly it comes on I have a 95 LS
I got a new key cut by the dealer, that helped a little, took a lot of play out of the tumbler, but next I am going to try replacing the following.
Interesting. I was going to try to see if my other key (not cut by dealer but fresh cut) would help, but now I'm thinking it is more likely the ignition switch based on your experience. Please update when you do the replacement...I'd love to hear if it fixes the problem.
you can also try cleaning it up.
i definitely noticed a difference but they're so cheap i just replaced anyways.
https://www.team-integra.net/forum/1...-cleaning.html
I had the same issue as in the link tamboo with an accord, I can post a pic of later, but the metal disk inside had a really high point or a hotspot. So you would only get a connection at very small spot
I suppose the test is if it can actually open a door or start the car. I'm sure there have been cases where a key was so worn that copies of it were not functional so a new original had to be cut by VIN. Is that so?
I ended up getting a key cut from the VIN. I've had it for about two weeks now and I noticed the same thing egsleepercivic did, namely that it helps but doesn't eliminate the problem. The delays have been more infrequent and don't last as long, but I might notice that it gets worse over time.
egsleepercivic, did you ever replace the part you linked? Did it fix the problem?
jetspeedz
Audio / Security / Video
06-07-2010 07:58 AM
