GSR will not shift into 2nd, 4rd or Reverse
So this morning i started her up everything was fine. Went to work all gears worked fine including reverse. Then when i tried to park reverse didn't work. All the others were fine though. Then on lunch it wouldn't go into 2nd...or 4th. No grinding. I'm supposed to sell her in a few days so im really praying y'all will give me good news haha don't exactly have the resources or time to drop the trans
Re: GSR will not shift into 2nd, 4rd or Reverse
check if you have fluid in your clutch master cylinder. if not, fill it and then you probably need to replace the CMC b/c it's leaking. IF you do have fluid, then it's probably a broken clutch disk
Check the shift linkage boot under the car its prolly blocking the linkage from moving.
99hondadx
02-10-2017 05:35 AM
charjacq
06-08-2004 11:19 PM
