integra gsr radiator fan mounts
so, i had to purchase a new denso unnit from rockauto a few months ago and my stock radiator fans mounting holes didnt line up on the passenger side
the radiator i purchased was for the GSR but i am curious if i should try using the GS/LS radiator instead, as i had an incident and need to replace it again.
has anyone experienced this before?
Re: integra gsr radiator fan mounts
They should be the same as a GSR. Just get a Mishimoto radiator and fan shroud. Mishimoto has a lifetime replacement on the radiator even if its broken crushed ect..
Based on the OEM parts diagram, my guess is acura had two different radiators that originally came on integras, SAK and Denso, and the fan mounts depended on which one it came with.
I bought a 1 1/2" aluminum radiator, for my 2000 LS w/auto.
Everything lined up, except for the 2 very large mounting holes on the bottom.
I used the ends of a thick black rubber bungee cord (the ends that usually hold the "S" clips).
They were big enough that they didn't push through and I set the lower radiator posts on the bungee ends.
That was back in 2006 and they are still there, keeping the radiator from rattling around.
I think the GS/LS radiator should fit. I had the same issue with my 97 automatic integra, the fans didnt mount to radiator mounting holes on the passenger side, even though the radiator I bought had the automatic transmission cooler lines, the mounts didn't work.
Yes i know what you mean. i recently just flip flopped radiators between my 2 integras. Installed my aluminum Koyo from my 2000 GSR to my 96 RS and my 96 RS oem radiator into my 00 GSR.
I tried installing the 96 RS radiator into the 00 GSR with the 00 GSR fan but the fan was not cross-compatible. I had to keep the 96 RS fan with the 96 RS radiator. The Koyo had provisions for either fan setup so it didn't have problems. There are differences for sure. Just go online and compare the part numbers to see where the changes were made. Not sure if it's a B18B1 vs B18C1 difference or a model year change difference.
quick google search: https://www.team-integra.net/forum/1...radiators.html
must be a difference of what your car came with originally--Koyo or Showa.
probably be best to input your VIN in an acura parts site and see which radiator your car was supposed to come with, then buy the correct radiator or the correct fan.
Hard2Find
10-18-2002 05:13 AM
