Is using a 76mm Inducer turbo from CXRacing on a K24 engine a good idea?
I am building a k24 for boost and I was looking around for a good size turbo to use. I came across a cxracing 76mm dual ball bearing turbo and I wanted to know if that was an appropriate size. the ar is .81. my power goals are around 700-900whp. would a turbo that size take too long to spool? Would it be effective? Any feedback would be appreciated.
https://www.cxracing.com/turbocharge...RB-T76-P81-RRB
Re: Is using a 76mm Inducer turbo from CXRacing on a K24 engine a good idea?
I enjoyed CX for a MUCH smaller application. I would not trust them for anything over 400hp. 589.00 exceeds the threshold of cost per part that I personally wanna gamble with, but it's your cheddah!!
Might hold might break. Who knows. The problem is that with 650$ s366 on the market, cx turbo is an unnessasary gamble.
my random $.02 of a reply...
I would "assume" that you are new to this, which is perfectly fine. It's great to ask questions. It also seems like you took the "most turbo for the least money" search route...which isn't going to end well in most cases. The "would it take too long to spool"...I would think that would be negligible on a car making 7-900...especially when looking at a turbo of that size. Power and "spool up" is a give and take. You could do a lot more, with a lot less. Would it be effective...IMO, no, not at all. It would be like a 3 legged dog running a race... You don't want that turbo
As mentioned, a good 62mm will cover what you want power wise on a solid build and actually be "enjoyable" to drive, even a 64mm...dang sure not a "76mm".
yes
yes
Thank you for the info. I will definitely be looking into something that is more appropriate for my build, and will be more effective. I didn't see any reviews on that cx turbo anywhere, or any other information of that matter. I also didn't feel like taking a $589 risk. So I asked before I bought. And given the amount of people telling me not to get it, Im gonna go the safe route and probably go with an s366.
Anywho.. As for reviews.. They are becoming harder and harder to find. I have been trying to help that as I have reviewed a good deal of items I've thrown on the civic. The vendors I've recently purchased from will receive reviews on what I've purchased when the time comes; in hopes I can get a ball rolling..
You don’t find much reviews or advice because people usually don’t listen anyway. People used to want to save and get the best parts depending on what they were doing, now people go for as cheap as possible. For example I just watched my buddy tune a street driven Civic that made 720whp on a Borg and the thing was so damn laggy.
If I was going for 700-900 I would save my time and money and get a PTE 6266 gen2 and not look back. See I’m patient and will wait and save to get the right parts, not many people can do it because they just want cheap and rush to get going.
I lost a motor about 18 months ago and worked, saved and was patient to not get back going real fast but right.
It seems there is also greater disparity between cheap knockoff parts and high quality parts. It's more difficult to find solid middle-of-the-road performance with good quality at a reasonable price. It's one end of the spectrum or the other. Which may not make a huge difference when looking at parts individually, for example spending an extra $500 for a Garrett turbo vs. an ebay one. But when you consider an entire build, these parts all add up to thousands more to do a quality build. This is why so many end up cheaping out on parts and not listening to advice, they simply cannot afford to do otherwise.
Ball bearing turbos seem to lower bang for buck value unless money isn't an issue and your hard pressed to spool a turbo a few hundred rpms faster. A $1500-$1700 turbo will always come off as a luxury expense to me because I never plan to race professionally. And theres only a reasonable amount that I would like to drop into a Honda before it just makes sense to move onto another platform.
The balance is off between "those wanting to save and do it right" and those wanting to buy the cheapest part possible (which typically leads to a part out a few months later )
That’s the problem, racing and building a car to get 400 or more horsepower isn’t cheap and doing it right isn’t cheap but that is why you work and save. As for middle ground it’s available. I ran a Garrett t3t61 and made 715whp with that turbo and it lasted and is a good quality turbo and cost me about 900 bucks. I ran a lot of different journal bearing Garrett turbos in the past with great success, you don’t need BB or water cooled.
Or buying the good **** to replace the cheap **** later down the road, spending even more than it would have cost in the beginning..
Dorikamu
11-04-2002 12:21 AM
