Water to Air Intercooler, Heat Exchanger, & Pump Needs
In an effort to retain my AC and a few other creature comforts I'm looking to put together a w2a intercooler rather than use an a2a front mount.
I'm having a bit of trouble selecting an appropriate pump for my personal preferences.
I'm in the initial planning of this so I've very little hard data to provide other than goals, so with that said;
I'm looking at between 250 and 270 whp from a 1.5L D series equipped with a Garrett 2554R, Ebay W2A 2.5 in/out mounted in the engine bay where the stock air filter assembly usually goes, remote rear mounted heat exchanger for the W2A intercooler mounted behind the rear subframe, I expect mainly street driving on weekends that last roughly 2 hours in hot (110+°F) weather with the odd 450 mile road trip happening maybe once a year. Fuel will be e54 (shitty AZ flexfuel) which should help. Driving is mostly city, occasionally highway, and some weekend canyon carving.
I don't want to be stuck with a pump that can't handle the minimum 2 hour duty cycle and odd 6 hour road trip at highway speed, or a pump that just doesn't move enough water to be effective.
I am not wanting to spend huge sums of money.
There is a 3" in/out W2A intercooler on Ebay with a somewhat larger core that will fit it's rated at well above my goals however I doubt the rating is accurate. With some modification I could easily change the in/out size to something more suitable to what my aims are if the core would be more appropriate. I am apprehensive at adding any more volume to the charge piping as I would like to retain lots of throttle response. I'm well aware there are better W2A intercooler designs out there, for my modest power goals I can't exactly justify well over double the price of these units.
I presume there is a relationship between W2A intercooler core volume and heat exchanger core volume as well as pump flow rates; I want the heat exchanger to have enough time to reduce the water temperature and hopefully have a lower heat soaked temperature on those long highway road trips.
My assumption is that a larger heat exchanger core volume to W2A intercooler core volume will slow water flow through the heat exchanger allowing more time to radiate heat. To this end I'd like to fit the largest heat exchanger I can if my assumption is correct.
As for pumps, I am wondering what kind of factors I need to consider? I think it would be nice to purchase a pump that will not move water so fast that it fails to cool down in the heat exchanger but fast enough to keep cool water running through the W2A intercooler core.
Thanks,
Maurice
*EDIT*
It has just occurred to me that perhaps the AC condenser would be the better heat exchanger to relocate to the rear of the vehicle considering I'm looking for streetable performance first with a few creature comforts second.
Thanks,
Maurice
*EDIT*
Re: Water to Air Intercooler, Heat Exchanger, & Pump Needs
Water to air IC for 270hp D15. All to save for space? You kidding? Oh.. You're serious..
Get an air to air front mount. There are soooooo many options small enough (for that power level) that will not hinder your A/C.
a) I don't want the giant volume of charge pipe that goes along with a front mount IC.
b) I do want the extra intake charge cooling capability of the W2A in both on and off boost situations.
c) It is my project
I see you. You want that super small charge pipe volume right?
About the heat exchanger to intercooler sizing well it probably has to do with water flow too.
The rate which the heat attacks the intercooler must be the same or smaller with the rate cold water comes in.If not the water temp would act just as battery and climb when you boost and itll need cruising out of boost to cool down.
This pump moves 23lters per minute with 1amp draw
https://www.demon-tweeks.com/eu/davi...p-kit-dcp9050/
I dont have a clue about water to air cooling but i bet a "Smart for two" radiator (tiny 80hp european car) would be enough.
Like all types of air cooled radiators youll want it to be thin and to have big frontal area for air to hit it.
As you said, it's "your build", but you're really over complicating the hell out of what should be an incredibly simple build with a low HP goal. Especially when you're trying to save money and use eBay parts.
Do not overthink the velocity of water flow. The more volume, the better. Err on the side of having more than enough flow, and the biggest heat exchanger you can physically fit. Otherwise you risk heating up the water to the point it is no longer effective. I would also put a good fan on the heat exchanger that kicks on when the water reaches a certain temp.
A 500gph pump should support your power goal.
As you said, it's YOUR project.. Luck to ya..
Not that the JEGs pump wouldn't work, but you said you were trying to keep the cost down, and that would be overkill for the application. Those are made for cooling entire engines, not just an intake charge.
20gpm is like 1.5Liter per second. It probably too fast.Ad there is also the amperage. I wouldnt run anything over maybe 2-3 amp.But thats me.
The 85 euros pump i linked draws like 1.5 ampere. For the same price you can have 2 in a push pull setup to help the super long water hoses.Maybe its not even needed.
Youre gonna mountthe radiator in the rear bumper area right?
i found this kit with a quick google search.
seems like they have a few kits, sounds easier than piecing it together.
I have built my own a2w setup. I would not do it again. Lots of custom fabrication. Nothing "bolts in".
I run the Bosch pump, this was oe for ford lightning's a2w setup iirc.
I have it powered by a relay and triggered by ignition switch. Same as my fuel pump.
ice box in trunk and heat exchanger behind bumper.
how well does it work? No idea yet, no dyno time. But due to going a2w I spent a ton of time and money on parts I ultimately changed and modified then threw out.
go a2a for ease unless you can fab yourself
As for cost, yes it is something I am willing to spend money on; proper AN fittings too, I'm not going to go cheap on stuff that can't run for 6 hours continuously without concern.
If I can source a heat exchanger that will fit in front of the core support opening and take up half the height I will go that route.
I believe i could then use a similar sized heat exchanger above it to replace the half sized radiator. This idea takes up the entire space for airflow in the front of the car unless I can somehow find a AC condenser that's nearly equal to the bumper opening in size but I'm not so sure I want to get in the way of airflow at all.
Most likely I am going to move the AC condenser to the rear of the car and deal with airflow issues to it somehow.
I'm not going to go A2A, and I don't mind fab work at all. In fact custom fab work is the part I enjoy the most. I know cost of the W2A system is well above an A2A system and complexity is always something that people shy away from but it makes me feel good when an idea works out just like I want it to. If it turns into a mess of leaks it'll be a learning experience.
I wish you the best of luck. I struggled to find a good sized heat exchanger that fit in front of my radiator and cleared my wastegate, I bought 3 total . It will be a tight fit if you can make it work.
but my power goals are 4-500 so everything I bought had to be able to support that, thus making them larger.
My budget is not unlimited I just need to be frugal with what I'm putting out for this part of the project.
I'm hoping that the equipment I get is sufficient to support a bit over what I need for my own goals.
My very basic understanding is that heat exchange from water through the heat exchanger metal and into the air is going to be mostly limited by water flow in my case. I'm sure there is the whole rule of diminishing returns, if the engine cooling pump is controlled I can easily determine what sort of pump is more adequate for my needs by testing the flow rate against temp drop across the core. More controls like air and water temps at various locations would make for a better science experiment but for me and my needs AIT against ambient checked against water flow is enough.
Best of luck running that pump. Will be an interesting experiment to say the least, but yes should provide more than enough flow.
I would be concerned with the amperage too, knowing how much of a voltage drop can occur from running a high amp cooling fan. Changes in voltage affects your injectors, ignition, etc. and unless they are dialed in perfectly could affect performance or cause other issues. I know I had to spend some time messing with injector dead times just to get it right from the voltage drop running my fan, which pulls around 15 amps.
The 8 amps for your water pump may not seem like a ton, but it all adds up.
I would research the LHT JRSC heat exchanger setup or even just give John a call at LHT performance and just ask them what size pump, heat exchanger they used for there B series Jackson kits. I had one years ago it should work perfect for your setup besides the actual intercooler, that wont be hard as there are many different sizes and shapes available, Even something like the Vortech after cooler for the B series vortech supercharger would work fine.
I will leave the argument "do or not to do" A2W alone. I have a rear mounted tank of about 3 gallons and I use a 800GPH bildge pump with replaceable cartridge. They last about 5 years and run constantly at engine on. They are very inexpensive. This is mounted below the trunk floor and I have access via the screw out deck plate.
Alfa, do you have manufacture and part number of your pump? also did you make that tank yourself?
Here is the pump,
In other news I saw a video comparing the generic W2A intercooler I originally mentioned above to another style, in any case it seemed to perform very well in the heat exchange department.
I'm still trying to work out where the actual heat exchanger(s) might go. It would be nice to hear some creative options here.
Last edited by MauricesExoticP; 03-30-2019 at 06:02 PM. Reason: Not bumping my own thread
